keltik Posted June 27, 2012 Share Posted June 27, 2012 Hey boes, Had a couple questions i wanted to ask about rebuilding my scoots and figured i'd throw them in here to make it all nice and neat. Have a scooter which is a clone of a Madass 50. Its made by the same company in China who produce the genuine Sachs madass and they also produce subtly different variants for different markets. For the Chinese market - they produce the same bike but with a mash up of different bits on it. Some are identical components as on the Sachs bike but most are shoddy sub-standard parts made from cheaper materials. I suspect they did this to save money and make the bike cometitive against the Sachs version. So anyways. When i bought it, it would hit 60kph on the flat. Whipped off the air filter which was full of poo and instantly i could hit about 70 flat out. Swapped the front sprocket to something bigger and got up to 80kph on the flat - tucked. Then i found out the 50 it was supposed to have was actually a 70cc which explained the 'performance'. Picked up a crate motor from trademe for $280 and scored a fat bore 125 from Lifan. Bolted it in and this is where my problems kinda started. First i managed to snap 2 of the bolts holding the front brake disc on. I was doing them up with a 1/4inch drive ratchet and 2 of them just sheared clean off. One of the engine cradle bolts has sheared off inside the frame and since the rear swingarm also bolts to the engine cradle - this makes it handle a bit wonky. Then my electrics shat the bed and the stator on the new motor doesnt have enough grunt to run the projector headlamps. Then the rear swingarm snapped at 80kph with a passenger on the back - so i learned its not really suitable for carrying people. Then i arsed off it at the velodrome and broke a few more bits. So now its rebuild time! Havnt bothered taking any pics of it because its a haggard ugly lump of shit - but you can see it on the left here! Quote Link to comment Share on other sites More sharing options...
keltik Posted June 27, 2012 Author Share Posted June 27, 2012 So first up I've ordered a new rear tire to replace the bald Huangdou which was so hard it refused to leave a black line anywhere and just turned to dust. It was also lethal as all fuckery in the wet. So got a Michelin postie bike tire on the way from cycletreads. Im also slowly going through the entire frame and replacing every fastener with a new item made from steel that doesnt snap if you use coarse language near it. Also repainting the frame in hammerite black. Next i wanna replace the bushes in the rear swingarm. Im wondering if i should even bother having rubber bushes in there or just machine up some solid bushes? Its pretty loose and floppy at the moment and im sure its not supposed to be. I need to rewire parts of the bike to run LED lamps. Im tossing up between running an LED headlamp or HID, they are projector lamp housings so reflector design isnt as much of an issue. I also need to find a smaller rear sprocket, wanting something around a 46 tooth to suit 420 chain. Finally i want to find a nice cam to suit the motor. Its a 1P54 Lifan, pretty sure the head is different to the 1P52 which seems more common. Thoughts on any of the above greatly appreciated. Quote Link to comment Share on other sites More sharing options...
JoKer Posted June 27, 2012 Share Posted June 27, 2012 is it the thing on the left? Quote Link to comment Share on other sites More sharing options...
Beaver Posted June 27, 2012 Share Posted June 27, 2012 but you can see it on the left here![/img] Quote Link to comment Share on other sites More sharing options...
JoKer Posted June 27, 2012 Share Posted June 27, 2012 your left or my left /spam Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 28, 2012 Share Posted June 28, 2012 I DONT HAVE TIME TO REPLY TO THIS AS WORKS GOING NUTS, BUT I FELT I SHOULD COME IN AND YELL! Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 28, 2012 Share Posted June 28, 2012 Well, I can get bronze bushes near the size you need, and machine to suit if you want to go away from rubber? Will transfer a lot more vibration tho. Putting two new bushes on the magic made a fucking huge difference tbh. I dont really know much about any of the rest of your questions tho. Quote Link to comment Share on other sites More sharing options...
keltik Posted June 28, 2012 Author Share Posted June 28, 2012 Alright im gonna go to an engineers tomorrow and get a new swingarm made. My one snapped again on the opposite weld to last time. So im not keen to trust it any longer. Took the wheel off, rested the bike on the ground and it simply mushed itself into 2 pieces. What a fucking terrible steel! Question: Why does my swingarm have a bend in it? Is it purely aesthetics? Can i make the new one straight out of box section instead of pipe? Quote Link to comment Share on other sites More sharing options...
Willdat? Posted June 28, 2012 Share Posted June 28, 2012 New swing arm, done. Must be cheaper than getting an Engineer to build. How far off are the shock mounts etc? Plus alloy bling! http://www.trademe.co.nz/motors/motorbi ... 542433.htm Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 28, 2012 Share Posted June 28, 2012 Yeh, i'd use RHS rather than pipe, makes life a lot easier. Bend will just be for show/shock mount. Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted June 28, 2012 Share Posted June 28, 2012 Lets knock up some abortion of a uni-link shock thing on Feeks milling doofer. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 28, 2012 Share Posted June 28, 2012 I'm keen to do some carbon work, this seems like a safe way to test out my workmanship. Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted June 28, 2012 Share Posted June 28, 2012 I'll nominate my life for first test jump. This card is only valid for one death. Quote Link to comment Share on other sites More sharing options...
keltik Posted June 28, 2012 Author Share Posted June 28, 2012 One call to Clint and hes designed and specced a new swingarm for me. Will see what the local engineer wants to build it tomorrow Quote Link to comment Share on other sites More sharing options...
keltik Posted June 28, 2012 Author Share Posted June 28, 2012 Pretty much going to make one like this; That bottom tension member should stop the main bar from cracking and with the full length gusset - i'll be a lot happier. Quote Link to comment Share on other sites More sharing options...
10Speed Posted June 28, 2012 Share Posted June 28, 2012 but longer? Quote Link to comment Share on other sites More sharing options...
keltik Posted June 28, 2012 Author Share Posted June 28, 2012 but longer? Nah, dont want to run a longer chain. It already flops about enough as is. Quote Link to comment Share on other sites More sharing options...
10Speed Posted June 28, 2012 Share Posted June 28, 2012 I have a spare one of these yours if the extra length happens Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 29, 2012 Share Posted June 29, 2012 That gusset is kinda pointless tbh. You could easy arsehole that and not lose much/any strength. Quote Link to comment Share on other sites More sharing options...
keltik Posted June 29, 2012 Author Share Posted June 29, 2012 Not shown is the shock mount that goes between the top of the 2 arches, i think the gusset was added for something to do with that. Engineer wants a million dollars to make it so im gonna get some pipe and ask VG very nicely if he would be so kind as to tack it up. Quote Link to comment Share on other sites More sharing options...
