cletus Posted April 8, 2012 Share Posted April 8, 2012 did you change the bearings or get the diff checked by someone? Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 8, 2012 Author Share Posted April 8, 2012 no, pretty much just filled the oil and slammed all back in. Nothing I am really worried about, now it has 2L of oil in it, probably will get it checked next time when I go for a WOF. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 10, 2012 Author Share Posted April 10, 2012 Small issue: Sheared a bolt that holds the rear shock in place. So I took the bolt to 3 engineering nut and bolt places they can't really find one bolt that close enough. Any suggestions? should I try toyota or see if someone is wrecking a car. Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted April 10, 2012 Share Posted April 10, 2012 You mean the bolt on the bottom? Any fasteners supply shop should carry them, like EDL or Blacks fasteners. It's a M10, with a fine thread pitch (1.25). Can't remember the exact length, i want to say 20mm, but just match up the one you have. Edit. You'll probably find anything local will have a 17mm head instead of the 14mm head on the original bolt. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 10, 2012 Share Posted April 10, 2012 Make sure you get the same strength bolt Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 10, 2012 Author Share Posted April 10, 2012 yeh rob, it is the one at the bottom. Yes I have got one for free from EDL. It's 17mm bolt, and everything else is exactly the same, but just too long,Factory is 15mm, this one is 20ish i think. I have to get few washers or spacers to get it fit for now. But eventually I will have to find one with the same length. Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted April 10, 2012 Share Posted April 10, 2012 Just cut it down. Or go to Toyota, they're about $3.50 each & should be available overnight from TNZ, lengths are different left & right one is 16mm & other is 18mm, no idea why. Quote Link to comment Share on other sites More sharing options...
Evan Posted April 10, 2012 Share Posted April 10, 2012 selling the panda one i see... Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 10, 2012 Author Share Posted April 10, 2012 Just cut it down. Or go to Toyota, they're about $3.50 each & should be available overnight from TNZ, lengths are different left & right one is 16mm & other is 18mm, no idea why. Oh, Hope I knew this earlier, spent all day to hunt down 'ONE BOLT' you serious? then That's bit problem because I have no idea which side the current one is. side note: Rob you're crazy. How did you know all that shxt. Quote Link to comment Share on other sites More sharing options...
beachlander Posted April 10, 2012 Share Posted April 10, 2012 How come youre selling the panda? Quote Link to comment Share on other sites More sharing options...
Ned Posted April 10, 2012 Share Posted April 10, 2012 Edited as per ling lings request Quote Link to comment Share on other sites More sharing options...
J-Calico Posted April 10, 2012 Share Posted April 10, 2012 selling the panda one i see... I want it... Quote Link to comment Share on other sites More sharing options...
Ned Posted April 10, 2012 Share Posted April 10, 2012 buy it then lol Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 11, 2012 Author Share Posted April 11, 2012 Hi Rob, Spent all day putting the front TRD sway bar with TRD bushes on the car, there are two small bolts that holding the bush and the bracket, they don't want to going in, seems too short, spent 2 hours there only managed one side. any tips? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted April 11, 2012 Share Posted April 11, 2012 Is the bracket getting caught on the bush or something? They will prob be pretty tight, try a small amount of grease on the bracket to get her all lubed up like. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted April 11, 2012 Share Posted April 11, 2012 I had this issue with nolathane swaybar bushes, they were taller than standard so wouldnt fit easily. First side I struggled for ages trying to press the bolt upward until it bit into the thread, the other side I went and got a couple of longer bolts and had it done in about a minute Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 11, 2012 Author Share Posted April 11, 2012 I had this issue with nolathane swaybar bushes, they were taller than standard so wouldnt fit easily. First side I struggled for ages trying to press the bolt upward until it bit into the thread, the other side I went and got a couple of longer bolts and had it done in about a minute yep, that's what I did for one side, I got stuffed thumb now. then the otherside I didn't have longer bolts and was impossible to push them in.. man, that's gay. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted April 11, 2012 Share Posted April 11, 2012 Yeah, go invest in some longer bolts, will make your life that much easier. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 11, 2012 Share Posted April 11, 2012 Can you put a strop on it to take of some tension? Unsure if they are anything like escorts. Quote Link to comment Share on other sites More sharing options...
LingLing Posted April 11, 2012 Author Share Posted April 11, 2012 errh, pretty much tried everything tbh. What I can think off now is to take the WHOLE Lot out again, So I can bolt in the bushes when it was still out the car. or buy some long bolts. Quote Link to comment Share on other sites More sharing options...
