Ling's Silver Grand Father ---- Plan B (NOT a SPAM THREAD)
LingLing
  • Replies 822
You mean the bolt on the bottom? Any fasteners supply shop should carry them, like EDL or Blacks fasteners. It's a M10, with a fine thread pitch (1.25). Can't remember the exact length, i want to say 20mm, but just match up the one you have.
Edit.
You'll probably find anything local will have a 17mm head instead of the 14mm head on the original bolt.
yeh rob, it is the one at the bottom.
Yes I have got one for free from EDL. It's 17mm bolt, and everything else is exactly the same, but just too long,Factory is 15mm, this one is 20ish i think. I have to get few washers or spacers to get it fit for now. But eventually I will have to find one with the same length.
Just cut it down. Or go to Toyota, they're about $3.50 each & should be available overnight from TNZ, lengths are different left & right one is 16mm & other is 18mm, no idea why.
Oh, Hope I knew this earlier, spent all day to hunt down 'ONE BOLT'
you serious? then That's bit problem because I have no idea which side the current one is.
side note: Rob you're crazy. How did you know all that shxt.
I had this issue with nolathane swaybar bushes, they were taller than standard so wouldnt fit easily. First side I struggled for ages trying to press the bolt upward until it bit into the thread, the other side I went and got a couple of longer bolts and had it done in about a minute :lol:
yep, that's what I did for one side, I got stuffed thumb now. then the otherside I didn't have longer bolts and was impossible to push them in..
man, that's gay.
