kpr Posted August 30, 2011 Share Posted August 30, 2011 coil = no heater thing = no belts = yeh nar Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted August 30, 2011 Author Share Posted August 30, 2011 its going to be the motueka drags just out of nelson and i have raced a few times so its not new to me i ran my old ae92 fx got 15.9 usually run my evo but to many hard takeoffs has taken its toll on the gearbox thought bout racing the ke30 but the k diff dosn't hold the 4 age power and pops and im on my last diff Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 30, 2011 Share Posted August 30, 2011 Heater blower will do nothing, throw all the AC shit in the bin will give you way more of a gain. If your spark system is in good working order any mods will show no gain Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted August 30, 2011 Author Share Posted August 30, 2011 page 2 and no pics best fix that this is what i usually pit crew for so far ive got pump up rear tyres harder run sticky slicks front at low psi mod inlet (should i make it so its behind the headlight so i can look cool and take the light off for air flow) see about putting 20 valve headers and doing mods to exhaust i ran this last time did 17sec on cromes and started sliping clutch ran 14" alloys and did 15.9 i think Quote Link to comment Share on other sites More sharing options...
Roman Posted August 30, 2011 Share Posted August 30, 2011 http://forums.vwvortex.com/showthread.php?776885 Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted August 30, 2011 Author Share Posted August 30, 2011 http://forums.vwvortex.com/showthread.php?776885 lol mint but some how i don't think the nz drag strips would allow all that to be done and still race lol it basicly came down to weight reduction in that lol Quote Link to comment Share on other sites More sharing options...
tim13 Posted August 30, 2011 Share Posted August 30, 2011 had good results with mine by immobilising t-vis running mega ignition advance (20- 25 at idle , total advance 35 - 40 , I think) and retarding intake cam 1/2 tooth (using other slot in cam pulley) I also ran a bigger throttlebody but that took a bit of engineering , as stated above light weight , tyres , exhaust , practice launching to suss revs and bog/spin ratio , poor mans lsd - big burnout heats r/f tyre then l/f spins on launch should hook up ok (mine went round rwd and 4wd on good days) sound like fun , yay cheap motorsport Quote Link to comment Share on other sites More sharing options...
Bling Posted August 30, 2011 Share Posted August 30, 2011 Sugar / sand mixed into the fuel/oil of the other cars and you'll have a good chance No.1 for me would be stickiest tyres up front on the lightest wheels possible. Then just launch like fuck off the line and hope you get one run before you break something Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted August 30, 2011 Author Share Posted August 30, 2011 Sugar / sand mixed into the fuel/oil of the other cars and you'll have a good chance No.1 for me would be stickiest tyres up front on the lightest wheels possible. Then just launch like fuck off the line and hope you get one run before you break something Break somthing its a toyota will never break Quote Link to comment Share on other sites More sharing options...
shizzl Posted August 30, 2011 Share Posted August 30, 2011 find a set of steels or super light alloys for some sticky rubber.. getting your launches and reaction times right is key... get your times consistant if your doing bracket racing,make your mates pshyc out and break out...win.. i did that to a guy in a crx at meremere, i was doing 15 flat and he was 14.8...so i just pshyced him out and won the class.. owned Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted August 30, 2011 Share Posted August 30, 2011 What about the LSD/locked diff? Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted August 30, 2011 Share Posted August 30, 2011 One thing with grip, 4ages can bog down hard if you get too much, it would nearly be better to have a bit of wheel spin to get the motor up in the revs. I drove an ae82 with a 20V and an LSD it it would bog hard off the line as it couldnt break traction. My std ae101 was way better off the line as it would tahi spin a bit and get up in the revs. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted August 31, 2011 Author Share Posted August 31, 2011 One thing with grip, 4ages can bog down hard if you get too much, it would nearly be better to have a bit of wheel spin to get the motor up in the revs. I drove an ae82 with a 20V and an LSD it it would bog hard off the line as it couldnt break traction. My std ae101 was way better off the line as it would tahi spin a bit and get up in the revs. alot of engines bog down with grip you just gotta find the sweet spot were it bogs but still has enough revs to power through Quote Link to comment Share on other sites More sharing options...
efp0wa Posted August 31, 2011 Share Posted August 31, 2011 the crx with b16a will dick on you Billy Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted August 31, 2011 Share Posted August 31, 2011 I'll lend you the motor out of the 86, that will dick on a b16a fairly well, lols. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted August 31, 2011 Author Share Posted August 31, 2011 the crx with b16a will dick on you Billy lol George you always said that yet you never ran your crx there Quote Link to comment Share on other sites More sharing options...
efp0wa Posted August 31, 2011 Share Posted August 31, 2011 I didn't want to destroy my gearbox again plus too many haters in Nelson. See you there with the S15 Quote Link to comment Share on other sites More sharing options...
bigfoot Posted August 31, 2011 Share Posted August 31, 2011 Make the rear suspension as hard as possible to minimise squat and get a good launch. Rubber spring blocks work well for this Quote Link to comment Share on other sites More sharing options...
