CaMpylobacter Posted September 23, 2011 Share Posted September 23, 2011 approve!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 also lever for crotch cooler made me swoon. Quote Link to comment Share on other sites More sharing options...
tortron Posted September 23, 2011 Share Posted September 23, 2011 They make an awesome thunk when you open or close them Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted October 4, 2011 Share Posted October 4, 2011 shit son! best I get to kimbolton and get aprts off those ones in the paddock for you. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted October 4, 2011 Share Posted October 4, 2011 grind the crack out a wee bit then put a squirt of high temp sealant in it and wrap it all up with kneed it. i done it to a xa falcon water pump as a quick fix to get me home when i was younger and it was still going when i sold the car 1 year later. Quote Link to comment Share on other sites More sharing options...
tortron Posted October 4, 2011 Share Posted October 4, 2011 Bit hard to see with all the bits in the way, but the pump is still water tight (also it has broken clean off) That part is basicly a bracket which holds the impeller shaft. Inspection shows this unit has been damaged in the past - possibly a contributing factor to that failure (housing has a part broken off) Its noted in the truck history this one had its blades brased up and re ground. Not fantastic work, but it passed , its even signed and dated on the impeller With the unit off, it looks as if i could just tap some holes and bolt it back together with a heavy piece of steel Anyway Made a new gasket Installed good pump Reinstalled engine fan Shes all happy again. Am going to try motorcycle chain lube on the shaft and see how that goes Yes cam, it hurts me deeply to touch the parts pile. I guess im doing pretty well tho, its been a while since she was used daily Quote Link to comment Share on other sites More sharing options...
tortron Posted October 4, 2011 Share Posted October 4, 2011 actually, looking at the picture i see the confusion That shaft is supposed to be open like that , is an off centre c shape Quote Link to comment Share on other sites More sharing options...
governorsam Posted October 10, 2011 Share Posted October 10, 2011 you need this, vacuum powered coolness... http://www.trademe.co.nz/Browse/Listing.aspx?id=413458154 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 8, 2011 Share Posted December 8, 2011 Coil lead fell off today i held up peak hour traffic i lold, then gradually escaped in a puff of unburnt fuel Quote Link to comment Share on other sites More sharing options...
tortron Posted December 9, 2011 Share Posted December 9, 2011 because i dont have my truck locked away and mothballed, must mean its for sale is getting to be a drag Quote Link to comment Share on other sites More sharing options...
tortron Posted December 11, 2011 Share Posted December 11, 2011 Toolchest is sweet, very happy with it right now. also went around and re attached the tarp tie downs that were once fitted. Eyeballed my hungry boards, but im not sure i want them on Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted December 11, 2011 Share Posted December 11, 2011 I'm sure I saw a truck just like yours being freighted on the back of another big truck the other day in Nelson. It looked tidy. I almost crashed as I stared at it. Quote Link to comment Share on other sites More sharing options...
felixx Posted December 11, 2011 Share Posted December 11, 2011 I saw your truck going up main north road in chch last week. If it wasnt yours, your truck has a doppelganger! I flicked gang signs at it Quote Link to comment Share on other sites More sharing options...
keltik Posted December 11, 2011 Share Posted December 11, 2011 I saw your truck on the internet and also committed some gang sings Quote Link to comment Share on other sites More sharing options...
tortron Posted December 11, 2011 Share Posted December 11, 2011 if it was my truck, its still driving back. not mine someone threw gang signs at me from a wagon the other day too edit* giggled at the thought of an old guy pootling along in his truck - getting harrased by an anglebox gang Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted December 13, 2011 Share Posted December 13, 2011 I approve of the tartan. Quote Link to comment Share on other sites More sharing options...
tortron Posted December 13, 2011 Share Posted December 13, 2011 its pretty much luxury Also affixed sidelight and properly hooked up the temp gauge, plus a light, and modified backing bracket to fit. Cant figure out where i put the bracket marked - found bolted to head, unsure of purpose im pretty sure its for the bistarter throttle control, which would be real nice to have working in the summer so i dont have a million revs when in traffic Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 13, 2011 Share Posted December 13, 2011 http://www.trademe.co.nz/motors/car-par ... 459723.htm Quote Link to comment Share on other sites More sharing options...
tortron Posted December 13, 2011 Share Posted December 13, 2011 have one as standard equipment (along with fuel and oil pressure) dammed fuel gauge is dead now, think iv narrowed it down to a broken wire Quote Link to comment Share on other sites More sharing options...
tortron Posted January 10, 2012 Share Posted January 10, 2012 Just nabbed an original workshop manual, and a copy of a second one score Quote Link to comment Share on other sites More sharing options...
tortron Posted January 11, 2012 Share Posted January 11, 2012 Started the old girl up today (2 weeks of sitting) started right up after priming and runs like clockwork (the brits were never renowned for clocks) pootled over to Te Rapa, parked next to circa 30s bright yellow coupe. Then went across the street and enquired about towbar fitting. "booked" in for next week, had a chuckle - oh we can do it anytime -- well i can leave it with you today if you like - Oh, ah, well iv got that truck in there and then a dihatsu to do and its just me at the moment, so uhh next week Quote Link to comment Share on other sites More sharing options...
