RUNAMUCK 28,943 Posted June 22, 2020 Report Share Posted June 22, 2020 Spill the beans m8 Quote Link to post Share on other sites
bigfoot 1,290 Posted June 22, 2020 Report Share Posted June 22, 2020 3 hours ago, MACKAZ said: Yes. Deals all through my old man and his mate. Frankly everytime I mention it ol boy sweeps it under the carpet. I am really torn but new motor has same power, easier to get parts for, and I know them like the back of my hand Sohc Falcon 6? Barra? 1 Quote Link to post Share on other sites
RUNAMUCK 28,943 Posted June 22, 2020 Report Share Posted June 22, 2020 Barra would be best bang for buck. Worth fuck all, and hard to kill. Pop the slugs out, file the ring gaps a bit bigger, and stick a bottle on it. 1 Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 22, 2020 Report Share Posted June 22, 2020 Bigfoot said it. SOHC 4.0l blow through carb turbo 2 Quote Link to post Share on other sites
CUL8R 909 Posted June 22, 2020 Report Share Posted June 22, 2020 If you're wanting to run Dizzy, you can use the XF Dizzy, you need to flip the drive gear upside down however.. Ooh why not buy this manifold also; Â Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 22, 2020 Report Share Posted June 22, 2020 We've never had any luck with XF dissys in stockcars. I'm going to try find an XD 2 wire. I'm gonna cut n shut curly manifold, just because it looks as rough as possible. I'll have to Google what cfm the Holley is, I'm picking its a 600, but I'll soon find out. Quote Link to post Share on other sites
bigfoot 1,290 Posted June 22, 2020 Report Share Posted June 22, 2020 Just now, CUL8R said: If you're wanting to run Dizzy, you can use the XF Dizzy, you need to flip the drive gear upside down however.. Ooh why not buy this manifold also; Â I can pick it up in september when IÂ to go pick up my car Quote Link to post Share on other sites
CUL8R 909 Posted June 22, 2020 Report Share Posted June 22, 2020 If you were really committed, you could run the SNZ ignition? I think in the last car It was $750, easy enough to wire up yourself, uses stock AU and Crank Angle Sensor too? Â Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 22, 2020 Report Share Posted June 22, 2020 Just now, CUL8R said: If you're wanting to run Dizzy, you can use the XF Dizzy, you need to flip the drive gear upside down however.. Ooh why not buy this manifold also;  Wasn't aware 250 Crossflow bolts up? Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 22, 2020 Report Share Posted June 22, 2020 Probably the best option, but this old timer don't do computerisation 1 Quote Link to post Share on other sites
bigfoot 1,290 Posted June 22, 2020 Report Share Posted June 22, 2020 Just now, MACKAZ said: Probably the best option, but this old timer don't do computerisation I'm sure that between me, @rb drifter and @ruff kunt automotive we can make it go 1 Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 22, 2020 Report Share Posted June 22, 2020 I'm going to rip all the useless shit off tomorrow night, put it on marketplace. I also need to move 4.0l, push Buick out, pull holden out, put 4.0l up front of shed, push Buick in and put holden at door end and get that heap sold, along with all my Holden and Valiant shit. Gonna get busy real quick 1 Quote Link to post Share on other sites
rb drifter 361 Posted June 22, 2020 Report Share Posted June 22, 2020 Have put the feelers out for a distributor for ya pal. Cant wait to see this beast cruising the streets Quote Link to post Share on other sites
CUL8R 909 Posted June 22, 2020 Report Share Posted June 22, 2020 Ah whoop, sorry XF and EA/EB etc inlets are fine to use 1 Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 27, 2020 Report Share Posted June 27, 2020 (edited) Looking for 2 wire XD dissy, flywheel and maybe an EA vee belt front pulley setup Edited June 27, 2020 by MACKAZ Quote Link to post Share on other sites
CUL8R 909 Posted June 28, 2020 Report Share Posted June 28, 2020 There's a guy I know down here with a Falcon clutch and pressure plate - he may have a flywheel too? Was running Falcon, but converted to HQ box Edit *He's sold now sorry* 1 Quote Link to post Share on other sites
d.p.n.s 2,440 Posted June 28, 2020 Report Share Posted June 28, 2020 Yessssssssssss. 4.0 straight 6 goodness.. 1 Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 28, 2020 Report Share Posted June 28, 2020 1 hour ago, d.p.n.s said: Yessssssssssss. 4.0 straight 6 goodness.. Glad you approve Sir. For time being I will get it running carbed. Will attempt the turbo at a later date Quote Link to post Share on other sites
d.p.n.s 2,440 Posted June 28, 2020 Report Share Posted June 28, 2020 Just now, MACKAZ said: Glad you approve Sir. For time being I will get it running carbed. Will attempt the turbo at a later date Yeah easiest way mate.... the stock car lads have been running them carbed for agers now ay....work well . Quote Link to post Share on other sites
MACKAZ 3,053 Posted June 28, 2020 Report Share Posted June 28, 2020 Yep. Had a EL in my one. Plenty of life after 6000rpm, something a 3.8 hasn't got 2 Quote Link to post Share on other sites
