Behold.....loooooongbike - and now shit gets fat
ThePog
You have excellent taste my friend. Your single speed is awesome and the rudge chain wheel is soooo sweet.
Picked one up myself for a dutch style project that i'm working on for the missus.
What have you done for the bottom bracket and what handlebar stem did you use? Do you find the cottered cranks to be a pain and what do you use to get the pins in/out?
  • Replies 205
That is some lush kit you have there....
TBH if the bike will be used for any real amount of time, I would get a square taper bottom bracket for it and find some old cranks to suit. I only say this cos the other bits you have are pretty shiny new so I am guessing it will not be a period resto or anything. All my other bikes have square taper ones (except my wifes bike which is some bling ultegra octolink wizzbang stuff :pukeright: ).
The cotter cranks are pretty shit in reality, I ended up using the crank axle off another real old 10 speed I had, with the original Herc bearing cups etc. The bearing surfaces were fucked on the old axle and the chain spacing was better with the newer one so max win.
If the cotter pins have been fitted/filed correctly then they should come out pretty easy with a hammer, plenty of bike shops still carry new ones anyway.
The stem is a Major Taylor one, fucking hard to get hold of in reality. The dude who sold me the bike gave it to me and he shouldn't have but he is sound.
Also I am pleased to know what that crank is off, I spend 20 mins googling the other day and gave up...
The bike is fairly rooted, and as it's for the wife, she wanted something 'bright and sparkly' and that wouldn't give her tetanus.....
Not necessarily what I would have done if given total control but if it keeps the missus happy and I can bring some OS touches to it, than all is good.
Kind of the look I'm going for and wish Kelly was my actual missus:
So during the last epic tweed run the saddle on the Hercules finally let go, plunging many bad/sharp things into my arsecrack. The leather was pretty fucked and I knew it would happen sooner or later. I ended up stuffing a rag under the the seat to minimise the sag, the rag was red which was amusing for everyone as I looked like I had a prolapsed anus while riding...
So here is my first attempt at leatherwork using the old frame, I reused an old leather tripod seat and finally found some decent sized copper rivets. I formed the new/old leather by just running the thing under a hot tap and holding it in place as it cooled down - worked sweet as you can see;
Oh shit you come up with some lush ideas. How have you painted/coated that one?
Also top notch re leather - was that leather from a saddle already or just a piece that you moulded/stretched on there using the water to soften?
How do you go about stripping the frames - are you getting them dipped or blasted or just elbow grease/wire wheel?
Have you ever come across a really stubborn stem stuck in the forks inside the head stock? I have this on the mrs' empire, and twisting the bars only deforms the weld on the stem
It is electroplated, $120 - was a bargain really as they paint/rust stripped the whole thing as well and it was very very tatty. i would have spent many many hours and lost interest if I had done it myself. Plus I hate black shit falling out of your nose for a day afterwards.
The leather was from an old tripod stool that I cut to the same shape as the flattened out original, just ran it under the hot tap and held it in place while it cooled down, worked 100% more awesomely than I ever expected but I suspect I was lucky to choose some vegetable tanned leather, so win really.
The stem - sounds like you are fucked. I had a bike that took 4 hours with a hacksaw to cut a slot inside the seatpost along the length of the post. Heat might help, I trust you wound out the bolt then smacked it with a hammer to disengage the taper thingy from the stem...?
