Rusted Posted January 27, 2011 Share Posted January 27, 2011 Just collected a P610 180B datto. Got it home on dark, turned the lights on and it started to disco. Bright blue flashing crossed over with the flare of yellow light. Now no lights at all, the ciggie lighter takes 5 seconds to get glowing hot and loss indicators. Start at fuse box then work my way to...? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted January 27, 2011 Share Posted January 27, 2011 Man, i can't understand any of that. Quote Link to comment Share on other sites More sharing options...
Escorto. Posted January 27, 2011 Share Posted January 27, 2011 Drunk post? Get home and headlights break. Consume!, i would Try looking for the headlight relay, see if its working. Where were the sparks coming from? Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted January 27, 2011 Share Posted January 27, 2011 Time travel occured? Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted January 27, 2011 Share Posted January 27, 2011 was it flashing blue from the fuse box? any rust holes in the firewall? Quote Link to comment Share on other sites More sharing options...
Rusted Posted January 27, 2011 Author Share Posted January 27, 2011 Heatstroke TBH. Spent all day moving the orange burnt out wagon complete with frozen brakes and parked in corner. 5 hours all up for that girl then done run to Kawerau to collect the blue thing. II turned the lights on, The car when into disco = Massive blue electrical sparks from the car. All lights when dead. Quote Link to comment Share on other sites More sharing options...
JoKer Posted January 27, 2011 Share Posted January 27, 2011 Where were the sparks coming from? Massive blue electrical sparks from the car. from the car do you really need more info? where else would they be coming from haha Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 27, 2011 Share Posted January 27, 2011 Fair question i say . . . ie anywhere more specific as to where exactly they were coming from. under dash, by the battery, by the fuse box, under the bonney, on the roof, on the fuel tank etc Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 27, 2011 Share Posted January 27, 2011 Hah, Joker is taking the piss man. Did you pick up the P610 as a parts-er or another to use as a driver? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted January 27, 2011 Share Posted January 27, 2011 Ok picking up what your putting down now Quote Link to comment Share on other sites More sharing options...
Rusted Posted January 27, 2011 Author Share Posted January 27, 2011 More specfically from every lightbulb in the car. As they have been blown to bits. Thought the police had found me... All the headlights- Melted. All the brsake lines- Melted Indicator bulbs are fine and no go. I have reverse lights. Obviously has been a problem in the past as where the 10A fuse was suppose to go, it had been replaced with a 25A... Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 27, 2011 Share Posted January 27, 2011 VR and/or bad earths. Quote Link to comment Share on other sites More sharing options...
Rusted Posted January 27, 2011 Author Share Posted January 27, 2011 Time travel occured? And alien abduction. Ky, VR=? VR-Phil? Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 27, 2011 Share Posted January 27, 2011 Voltage Regulator. Puppy should be External on that bitch, likely fucked/maybe well fucked causing explosions. Either way it sounds alternator/VR/bad earth related. Quote Link to comment Share on other sites More sharing options...
mikuni Posted January 27, 2011 Share Posted January 27, 2011 Voltage regulator/Alternator. This thread rules by the way. edit beaten. Ruling thread call still stands. edit edit replace fuse with larger fuse/bolt/replace all bulbs and try again while videoing it for us to enjoy? /don't do this Quote Link to comment Share on other sites More sharing options...
shizzl Posted January 27, 2011 Share Posted January 27, 2011 disconnect the alt and see if shit works... im also keen to see this disco light show... Quote Link to comment Share on other sites More sharing options...
Escorto. Posted January 28, 2011 Share Posted January 28, 2011 Was the car running when you had a disco? if not would rule out Alt/Voltage regulator. Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted January 28, 2011 Share Posted January 28, 2011 $5 bucks on bad earth Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 28, 2011 Share Posted January 28, 2011 not entirely sure how a bad earth would cause 60000volts amps watts or power to blow all the lights in a car , i know it can stop them from working and melt the cables. tbh i reckon its what happens when anything goes wrong with a car , BHG. Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 28, 2011 Share Posted January 28, 2011 also wtf brake lines melted :S Quote Link to comment Share on other sites More sharing options...
