Evan Posted December 8, 2011 Share Posted December 8, 2011 the diesel foresters run a 6 speed. id assume theyre lower ratios being diesel and all. a turbo legacy box should be fine as the turbod ones make more power than the 6 cylinder.... definately interested in how this works out. Quote Link to comment Share on other sites More sharing options...
keltik Posted December 8, 2011 Author Share Posted December 8, 2011 a turbo legacy box should be fine as the turbod ones make more power than the 6 cylinder.. While this is true, its the shock loading that kills the boxes. On the turbos you get that wee lag on gearshifts, where on the 6 you dont. So it only takes a few badly timed gearshifts and your putting a lot of strain on things. Either way - we'll see how it goes. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted December 8, 2011 Share Posted December 8, 2011 Totally want one of these engines now Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted December 8, 2011 Share Posted December 8, 2011 Question for you keltik, are the 5 speed's in the 2006 stz outbacks (2.5i Nz new) the same box as turbo? It's symetrical awd, but I'm not sure how it sends power to each wheel when you're on ice/snow etc. Don't think it has any lsd's. HIJAK Quote Link to comment Share on other sites More sharing options...
keltik Posted December 8, 2011 Author Share Posted December 8, 2011 Hey boe, the newer stuff is still the same configuration as the older boxes. Manual still has a viscous center with viscous rear diff sometimes and auto has electronically controlled center diff with viscous rear. I dont think any of them had front LSD's from factory until you get to the WRX STI models. Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted December 8, 2011 Share Posted December 8, 2011 That would make sense. You can definatly feel it pulling from the front and back on ice, and it leaves two tyre marks on shingle.. Quote Link to comment Share on other sites More sharing options...
keltik Posted December 10, 2011 Author Share Posted December 10, 2011 Did some more work on this tonight. Have decided im going to mate the box and motor in the garage then wham it in the hole as one unit. Started wiring up the new motor, most of my wiring loom went straight on - had to swap a couple sensors and stripped the new loom to get the pieces i need out of it. So its all coming together. Now i just need a torx wrench of the appropriate size to remove the flex plate and bolt my flywheel on. After that - I can bolt the gearbox on and start cleaning up the engine bay and trans tunnel. Should be on track to install the motor this coming week and have it ready to start the week after. Need to find a throttle body to fit. Im told a AU XR6 one is very close to perfect. Will also be swapping the rear diff to match the box ive been given instead of changing the box. I wanted to do a 4.444 conversion and now im going to! From 4.111 to 4.444 will only give me a 100rpm drop at 100kph cruise due to the gear ratios being different - but most importantly, in theory it should reduce the amount of torque exerted on the gearbox bearings if my fragile little mind is correct. Pics to follow tomorrows update. Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted December 10, 2011 Share Posted December 10, 2011 I have torx things if you still require come Monday arvo Quote Link to comment Share on other sites More sharing options...
keltik Posted December 10, 2011 Author Share Posted December 10, 2011 I have torx things if you still require come Monday arvo I will still require. Were you able to grab that diff for me boe? Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted December 10, 2011 Share Posted December 10, 2011 Most likely/can't see why not. Quote Link to comment Share on other sites More sharing options...
keltik Posted December 10, 2011 Author Share Posted December 10, 2011 Sweet, will have them make it ready for ya Monday morning. Just found service manual for the new engine. This job just got easier. Quote Link to comment Share on other sites More sharing options...
keltik Posted December 11, 2011 Author Share Posted December 11, 2011 Good progress so far today. Heres the new gearbox ready to go in; Heres the new motor ready to go in once the flywheel is on; And the hole for it to all fit into; Pilot bearing was utterly shagged so put in a new one. Flywheel and pressure plate look good so the clutch can go straight back on. Got most of the wiring sorted for the motor too, all the motor harness is there now i just need to do a few new runs to the ECU for the extra solenoids and sensors. Things to be done: * Flywheel and clutch fitted to motor * More wires to be run to ECU * Rear diff to be swapped for 4.444 ratio LSD * Everything stuck back in the car * Throttle body modified to fit or a new one sourced * More wiring! Yay! * BooooooooBAAAAAAAAAAAA down the road Quote Link to comment Share on other sites More sharing options...
keltik Posted December 14, 2011 Author Share Posted December 14, 2011 Tonights progress. Whipped the flex plate off with JohnnyB's help. Required a bit of hammering and a cold chisel to one of the bolts but all sweet. Then proceeded to do a spot more wiring, fitted the clutch and flywheel then hoisted the gearbag onto it. Picture for proof; Sorted out the rear diff issue, turns out the gearbox they sent me had a new bell housing on it and they never removed the sticker - so it IS in fact a 4.111 therefore dont need to change the rear diff. Even counted the teeth on the front diff crownwheel to be sure. Next mission is to wham it in the hole and install throttle body. Quote Link to comment Share on other sites More sharing options...
keltik Posted December 19, 2011 Author Share Posted December 19, 2011 Forgot to update that the motor is sucessfully in the hole. Certainly wont be swinging any cats between the front chain cover and the radiator fans. In fact - youd be lucky to jam a gnats chap in there. Its toighter than Duddley. So chalk up another 2 nights of wiring and dicking around. Spent the evening in the shed doing wiring on the ECU end of things. The problem i have is that when i originally wired the Link in - i wasnt sure if i would be keeping the car, so kept all of the factory wiring in place so i could reuse the factory ECU whenever i please. Since now the car can only run on the Link - i decided to revisit the rats nest of ECU wiring and strip it back to going directly into the link instead of branching to the link and factory plugs. So after stripping off all the electrical tape and figuring out what was what, i saw this; And was all like Nek minnit/5 hours of soldering later; Looking much neater and will makes it a lot easier to stuff everything back under the carpet. Also wired up the VTEK solenoids and new temp sensors and various other electronic wizardry. Just about finished with the wiring now, all the remains is to test each solenoid and sensor to make sure i havnt fucked anything up. Got a throttle body today so will be sorting that in the next couple days. Drivetrain is completed, which means all thats left to do is; * Install modine oil cooler thing * Fill with coolant and oils * Make a spacer plate for the throttle body and bolt that on * Figure out where to attach the throttle cable * Get tuned * Do skids Quote Link to comment Share on other sites More sharing options...
keltik Posted December 26, 2011 Author Share Posted December 26, 2011 Progress pics; Its in! Not what i'd call heaps of clearance but i didnt have to move anything This is chilling in the glove-box and all wired up, initial sensor checks show everything is working as expected Still needs a wash tho So ive got to the point where all i can do is wait for enough money to finish the project. Filled it with coolant and oil today - just need gear oil and a throttle body sandwich plate and its good to go. I'd estimate 2-3 weeks before i can fire it up. Quote Link to comment Share on other sites More sharing options...
fuel Posted December 26, 2011 Share Posted December 26, 2011 did you purchase new headers for it or using factory stz? Quote Link to comment Share on other sites More sharing options...
keltik Posted December 26, 2011 Author Share Posted December 26, 2011 At this point i havnt fitted headers, the factory ones look a bit poo-er than expected so might get some flanges cut up the same time as my sandwich plate. Then i can go to my mates place in Rotorua and copy the ones on his race car. Quote Link to comment Share on other sites More sharing options...
Evan Posted December 26, 2011 Share Posted December 26, 2011 Did you put those stickers on the doors? Quote Link to comment Share on other sites More sharing options...
keltik Posted December 26, 2011 Author Share Posted December 26, 2011 Yeah then i took them off since they looked gayer than expected...but never got round to removing the glue....i should probably get round to that. Quote Link to comment Share on other sites More sharing options...
Evan Posted December 26, 2011 Share Posted December 26, 2011 yea looks ewww. Quote Link to comment Share on other sites More sharing options...
