Mike-e Posted August 10, 2010 Share Posted August 10, 2010 nice interheater piping yo Quote Link to comment Share on other sites More sharing options...
lowlancer Posted September 2, 2010 Share Posted September 2, 2010 Mean. I love old shit like that. So dash turbo is still the plan? Quote Link to comment Share on other sites More sharing options...
fuel Posted September 2, 2010 Share Posted September 2, 2010 yep yep full steam ahead with DASH churbro swap - I'll just be running TBI with factory ECU for a while before I sort out multi point and megasquirt. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted September 2, 2010 Share Posted September 2, 2010 MEN Quote Link to comment Share on other sites More sharing options...
ProZac Posted September 17, 2010 Share Posted September 17, 2010 Lub your work. Look forward to see in MPI setup on a dash motor. Quote Link to comment Share on other sites More sharing options...
fuel Posted September 17, 2010 Share Posted September 17, 2010 it'll be TBI for now, but I'm getting a spare DASH inlet mani to cut up and make into an EFI manifold. That's assuming I don't sell it before then. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted September 17, 2010 Share Posted September 17, 2010 Any idea on what caused the ringlands to break like that? Much detonation marks, or just old cast pistons? Quote Link to comment Share on other sites More sharing options...
fuel Posted September 17, 2010 Share Posted September 17, 2010 I would say it was the 16psi+ the engine saw around Taupo track 2, however the Eternas engine held up to the same abuse for no less than three trackdays at that boost level. There's no detonation marks anywhere on the crowns of the pistons, but I did initially have an issue with the engine pinking quite severely once the turbo gear was re-fitted, but it was mostly due to over-advanced ignition timing and was quickly rectified. These pistons use 2mm thick compression rings and the ring land width isn't that big so they are more prone to this happening over the later model pistons with thinner things. Due to the primitive ECI system usually you melt or crack ring lands on pistons 1 & 4 as they run lean while pistons 2 & 3 run richer, however it was piston #3 which did the damage which goes against the grain. Ah well with the HKS forged pistons which run 1.2/1.5mm rings hopefully it wont happen again. Quote Link to comment Share on other sites More sharing options...
Jif Posted January 12, 2011 Share Posted January 12, 2011 That third valve looks like weird growth like a third nipple on an engine Quote Link to comment Share on other sites More sharing options...
fuel Posted January 12, 2011 Share Posted January 12, 2011 your face looks like a weird growth on your shoulders. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 12, 2011 Share Posted January 12, 2011 Crap that Dash head setup is so awsome for the time. I Like a lot. I havnt really followed this build, like many, however that is shit that eninge cost you heaps more than expected, still, this thing is going to be freaken sweet once going again Quote Link to comment Share on other sites More sharing options...
Spencer Posted January 12, 2011 Share Posted January 12, 2011 Sweet yo, going to lush that head up as well? Quote Link to comment Share on other sites More sharing options...
fuel Posted January 12, 2011 Share Posted January 12, 2011 the head has been rebuilt before in the past, it looks fairly clean and has numbers engraved over the rocker arms and shafts etc for placement. I can see newish valve stem seals fitted too. besides, I'm pretty much flat broke thanks to the bottom end, I don't think I could justify spending another few hundy on the head, especially when things like valve stem seals, valves, inlet manifold etc are specific to the DASH head and they no longer make spares for it! Quote Link to comment Share on other sites More sharing options...
Spencer Posted January 12, 2011 Share Posted January 12, 2011 Oh yup if its reasonably fresh then thats gravy Quote Link to comment Share on other sites More sharing options...
Ranter Posted January 13, 2011 Share Posted January 13, 2011 There are still a few head sets left in NZ, not cheap though. Probably not worth when the main difference is an inlet gasket and some valve stem seals V2040K part number through I think NZ Gaskets. (via Ripco) Quote Link to comment Share on other sites More sharing options...
fuel Posted January 13, 2011 Share Posted January 13, 2011 yeah, it's mainly the inlet manifold, valve stem seals and the rocker cover gasket which is different. I just kept the intake manifold attached, valve stem seals have already been replaced, and rocker cover gasket can be re-used - am using the normal SOHC head gasket which cost all of $20+GST. Quote Link to comment Share on other sites More sharing options...
Mike-e Posted January 17, 2011 Share Posted January 17, 2011 can modify that I/C piping if you want nilly Quote Link to comment Share on other sites More sharing options...
fuel Posted January 17, 2011 Share Posted January 17, 2011 sweet bro cheers, will see how I get on! Quote Link to comment Share on other sites More sharing options...
spanners Posted March 8, 2011 Share Posted March 8, 2011 Please tell me you want that black W/B stazza on TM Quote Link to comment Share on other sites More sharing options...
fuel Posted March 8, 2011 Share Posted March 8, 2011 it's definitely a widebody but nah not that black one, not so keen on being LHD and lethargic 2.6L engine. This one is a UK-spec model with 2.0 and under 60km on the clock. Quote Link to comment Share on other sites More sharing options...
