CUL8R Posted February 28, 2009 Share Posted February 28, 2009 Righto, basically scored myself a Cressida - but has a punctured fuel tank Derby car so needs to be able to withstand severe whacks The hole is basically the size of $2 coin (just a tad smaller).. Whats the go on fixing them? Im not stupid enough to even think about welding it, so epoxy/cold solder? That or I might just get a small Race tank/cell and mount that along with an efi pump inside it.. Quote Link to comment Share on other sites More sharing options...
peteretep Posted February 28, 2009 Share Posted February 28, 2009 just drain it then weld it Quote Link to comment Share on other sites More sharing options...
toyabusa Posted February 28, 2009 Share Posted February 28, 2009 DO NOT "JUST DRAIN IT AND WELD IT" !!!!!!! An empty tank is more dangerous than a full one!! Quote Link to comment Share on other sites More sharing options...
Simon Posted February 28, 2009 Share Posted February 28, 2009 Iv welded a few tanks, I drain them and take the pump out then stick a hose from the exhaust pipe of a car down the filler hole and let it push out all the petrol fumes and also fill the tank with carbon dioxide. Let the car idle for like 5-10 mins pumping carbon dioxide into the filler pipe and out the pump hole. Never had one blow up. Quote Link to comment Share on other sites More sharing options...
T-Rex Posted February 28, 2009 Share Posted February 28, 2009 DO NOT "JUST DRAIN IT AND WELD IT" !!!!!!!An empty tank is more dangerous than a full one!! Hard out, drain, dry, fill as much of it as you can with water, weld it. Quote Link to comment Share on other sites More sharing options...
filthy one Posted February 28, 2009 Share Posted February 28, 2009 Yep bro just fill it with water to absorb fumes & you'll be sweet or use kneed it cos thats fuken amazing stuff i used it on my mk1 fuel tank & it never leaked!!! Quote Link to comment Share on other sites More sharing options...
FLAWLES Posted February 28, 2009 Share Posted February 28, 2009 agreed need it is sweet fixed many cast tractor sumps and strangly enough it holds and lasts too Quote Link to comment Share on other sites More sharing options...
forced Posted February 28, 2009 Share Posted February 28, 2009 I fixed the tank in the Z. Flushed it out, used detergent. Did it several times, then filled with water, turned upside down with the filler on . Didn't weld it but brazed a patch over the rotten part after grinding it to clean it up. Steve Quote Link to comment Share on other sites More sharing options...
sentra Posted February 28, 2009 Share Posted February 28, 2009 rivet a plate with gasket maker over it? its a derby car Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 28, 2009 Share Posted February 28, 2009 agreed. either fibreglass it or just do what ^ he said Quote Link to comment Share on other sites More sharing options...
japawagons Posted February 28, 2009 Share Posted February 28, 2009 The hole sounds like it's big to solder... Soldering usually works quite well. But welding or braising would work... As long as u clean that thing out and don't blow yourself up. Quote Link to comment Share on other sites More sharing options...
84_S12 Posted February 28, 2009 Share Posted February 28, 2009 Solder it, like with a patch a big soldering iron and solder Whatever way you do it, be tuff and do it with a durry hanging out your mouth Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted February 28, 2009 Share Posted February 28, 2009 just flush it with some water mate a few times then fill it up about 3/4 and weld the fucker. will be sweet for what you and it for dan Quote Link to comment Share on other sites More sharing options...
84_S12 Posted February 28, 2009 Share Posted February 28, 2009 If you do it that way purge it with an inert gas like nitrogen Quote Link to comment Share on other sites More sharing options...
tortron Posted March 1, 2009 Share Posted March 1, 2009 derby car = pop rivits + ally sheet + gasket goo +skidz on Quote Link to comment Share on other sites More sharing options...
tortron Posted March 1, 2009 Share Posted March 1, 2009 also - duct tape the shit out of it Quote Link to comment Share on other sites More sharing options...
Yowzer Posted March 1, 2009 Share Posted March 1, 2009 I'v heard a story where some guys temporarily fixed their fuel tank with some chewing gum after a rock punctured it. Could always try that with a cardboard plate ductaped over top. Quote Link to comment Share on other sites More sharing options...
84_S12 Posted March 1, 2009 Share Posted March 1, 2009 I saw on MacGyver when they temporarily fixed their fuel tank with some chewing gum after a rock punctured it. Could always try that with a cardboard plate ductaped over top. Quote Link to comment Share on other sites More sharing options...
Rusty Posted March 1, 2009 Share Posted March 1, 2009 find a plastic bung about size of hole and silicone da cunt on and shell be right Quote Link to comment Share on other sites More sharing options...
CUL8R Posted March 1, 2009 Author Share Posted March 1, 2009 Apart from the fact petrol eats silicone, yea it'll be sweet.. Anyway have decided on using a homemade fuel cell brother has, and a efi external fuel pump.. Quote Link to comment Share on other sites More sharing options...
