cute wee gem Posted June 17, 2008 Share Posted June 17, 2008 I know this has been covered but wanted an opinion for my setup. Will 5mm ID steel lines will be enough for the Bellett engine? I'm not sure what power it'll make but stock + aftermarket ecu they seem to make about 75-85rwkw The stock Piazza lines are 8mm OD but then 3sgte lines are 8mm OD aswell. Which makes me think 5mm will be fine? Is rubber hose running full length (i.e swapped for original steel lines) ok? Quote Link to comment Share on other sites More sharing options...
V8Pete Posted June 17, 2008 Share Posted June 17, 2008 Rubber the whole length would cost a fortune and I'm pretty sure it's not legal. Quote Link to comment Share on other sites More sharing options...
filthy one Posted June 17, 2008 Share Posted June 17, 2008 na full rubber aint legal mate .. go to a brake place get some truck brake tubing its 8mm id steel you can bend it easy to suit your floor & is easy as to mount the brake shop will have clamps all you need to do it drill 4mm holes in ya floor & the push in .. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted June 18, 2008 Share Posted June 18, 2008 Rubber the whole length would cost a fortune and I'm pretty sure it's not legal. I brought a 10m roll of EFI hose from supercheap for $70 when I talked to them on the ph I didn't believe it was EFI hose at that price. In the past I've paid $70 for 3m. I'm running rubber hose the full length of the van and that's how it got certed and never it's had an issue with the WOF either. So I thought it must be legal??? Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 18, 2008 Share Posted June 18, 2008 The last 2 WOFs i got on my Esky it had rubber hose the full length, IMO its a lot safer than the plastic hose Ford used on UK models Quote Link to comment Share on other sites More sharing options...
Mike-e Posted June 18, 2008 Share Posted June 18, 2008 efi hose is usually phenomenally expensive, rapeco charge a scratch under $50 p/m Quote Link to comment Share on other sites More sharing options...
Toucan Posted June 18, 2008 Share Posted June 18, 2008 If both cars originally used 8 wouldnt it be safest to go with that? Why do you want 5mm? I have rubber in my car but as said not sure if its legal an would cost millyens Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 18, 2008 Share Posted June 18, 2008 Hose Supplied in tauranga have cheap as hose i paid $6 a metre for 8mm Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 18, 2008 Share Posted June 18, 2008 i got non efi hose 7m for $15 yeah.. efi hose i used to get at $10 per M.. Quote Link to comment Share on other sites More sharing options...
forced Posted June 18, 2008 Share Posted June 18, 2008 Probably depends on your pump as well and whether it's sucking or pushing. 8mm OD lines are good for over 300Kw at the hubs. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 18, 2008 Share Posted June 18, 2008 i got 3/8th steel bundy for 30bux for a 6m roll. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted June 18, 2008 Author Share Posted June 18, 2008 If both cars originally used 8 wouldnt it be safest to go with that? Why do you want 5mm?I have rubber in my car but as said not sure if its legal an would cost millyens Bellett is 5mm. What I reeeeally wanted to know is if the stock lines would be big enough, they're not exactly the most powerful engines. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted June 18, 2008 Author Share Posted June 18, 2008 Doesn't really matter when I think about it, might aswell just use the 5mm stuff as a return. lol Cheers for the answers though Quote Link to comment Share on other sites More sharing options...
Jase Posted June 18, 2008 Share Posted June 18, 2008 i ran the stock gemini lines when i ran my g200w was fine, but 5mm for return shud be sweet and then a bit bigger for your main Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 19, 2008 Share Posted June 19, 2008 are you allowed to run fuel lines inside the car? i was gonna run mine along the bottom of the tunnel and up through the firewall where the heater pipes used to go.. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted June 19, 2008 Share Posted June 19, 2008 You must be able to - there's plenty of manufacturers who do it. Sure scoobies're like that, Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted June 21, 2008 Share Posted June 21, 2008 if its braided...you can run it anywhere Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 21, 2008 Share Posted June 21, 2008 rubber..3/8s non efi. Quote Link to comment Share on other sites More sharing options...
Guest Armourking Posted June 24, 2008 Share Posted June 24, 2008 yup i've got -8 braided line running inside the car looks sexy as but cost F**king heaps we also put it in the rally car we built but be warned we have both noticed that they must let some fumes out as both cars smell a bit of gas anyway here's some pics, be warned again this cost around $1500 to do Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2008 Share Posted June 25, 2008 wholy crap...thats sexy as,but super expensive.. what do you think is the best way to put a return line fitting into a tank?i cant put it in the filler neck cos its rubber.. do i just drill a hole in the tank,screw it in and weld around it? by the way my tank is empty Quote Link to comment Share on other sites More sharing options...
