cute wee gem Posted May 3, 2008 Share Posted May 3, 2008 Since I'm poor, I'm making a mild steel intake. (not for the gem) Basically what I need to know is what coating I can use that won't be effected by petrol and will prevent it rusting on the inside. I was thinking por15? On a bit of a budget build so yuh. Quote Link to comment Share on other sites More sharing options...
Esprit Posted May 3, 2008 Share Posted May 3, 2008 POR15 will do the trick nicely. You could also powdercoat, which would be easier and possibly cheaper, but the finish won't be as durable as a properly-applied POR15 finish. Quote Link to comment Share on other sites More sharing options...
sentra Posted May 3, 2008 Share Posted May 3, 2008 just do nothing/paint it with a spraycan if your on a budget. its not going to go anywhere/if your lucky it may go a tinge of brown inside if you leave it sitting for 10 years yo. por15/"wattyl rust kill"/powdercoating looks sexy tho. matty b ftw. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted May 3, 2008 Share Posted May 3, 2008 I wa going to try this, but just did it in stainless in the end http://www.hpcoatings.co.nz/turbos.htm Quote Link to comment Share on other sites More sharing options...
tortron Posted May 4, 2008 Share Posted May 4, 2008 soak and rub the thing in oil, or anchor wax Quote Link to comment Share on other sites More sharing options...
fishtailfred Posted May 4, 2008 Share Posted May 4, 2008 Carb or injected? If carb, do nothing is fine, If injected, rattle can some zinc primer on there. The petrol will wash away the paint where it touches it, but the bits the petrol touches won't rust anyway (oily residue from the additives). Nothing wrong with mild steel intakes anyway Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted May 4, 2008 Author Share Posted May 4, 2008 Injected. Cheers guys, seems like it wasn't such a bad idea after all Quote Link to comment Share on other sites More sharing options...
V8Pete Posted May 4, 2008 Share Posted May 4, 2008 Only reason I went stainless was the only MS tube I could find was like millions of mm wall thickness. Could've just been looking in the wrong place. Quote Link to comment Share on other sites More sharing options...
fishtailfred Posted May 4, 2008 Share Posted May 4, 2008 Mines all 1.6mm : http://i50.photobucket.com/albums/f323/ ... 0_4432.jpg http://i50.photobucket.com/albums/f323/ ... 0_4360.jpg Mine will never see any fuel, so it's all painted with primer and black in and out. Fred. Quote Link to comment Share on other sites More sharing options...
sheepers Posted May 4, 2008 Share Posted May 4, 2008 don't paint it with POR 15. POR 15 is useless at sticking to smooth surfaces, like a piece of mild steel for instance. the paint will end up inside your engine which isn't the best place for it. sheepers. Quote Link to comment Share on other sites More sharing options...
tortron Posted May 4, 2008 Share Posted May 4, 2008 which is what metal ready is for most new steel has a coating on it too Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 4, 2008 Share Posted May 4, 2008 I would do it in gun blue. If you can't afford a gun blue kit then reaaly old, buggered engine oil that is full of carbon can help. Basically get the manifold red hot and dunk it in the old oil which will soak into the steel. Best to look up the actual method as I have never done it Quote Link to comment Share on other sites More sharing options...
tortron Posted May 4, 2008 Share Posted May 4, 2008 i remember doing that in 3rd form metal work with some key rings or something we made just heated it up then bam in the oil, then rubbed oil into it Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 5, 2008 Share Posted May 5, 2008 don't paint it with POR 15.POR 15 is useless at sticking to smooth surfaces, like a piece of mild steel for instance. the paint will end up inside your engine which isn't the best place for it. sheepers. Quoted for truth. POR15 peels of new steel like a banana skin Quote Link to comment Share on other sites More sharing options...
Esprit Posted May 5, 2008 Share Posted May 5, 2008 Quoted for truth. POR15 peels of new steel like a banana skin Thing with POR15 is you need to use their kit. Some Marineclean and some MetalPrep will make it work wonders. I did the rocker cover and oil cap (mild steel pressings) on the TR7 in that about 7 years ago. After soaking in oil, suffering knocks and general wear and tear it looks every bit as shiny and unmarked as it did the day I painted it. Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 5, 2008 Share Posted May 5, 2008 in engine oil meeeeaaaannn rugged carbon steel ftw rofl would stop it from rusting though i spose member doing similar thing in engineering at tech made carbon steel took ages and all just to shatter my piece drawing big doodles on the picnic table by automotive Quote Link to comment Share on other sites More sharing options...
Mike-e Posted May 5, 2008 Share Posted May 5, 2008 powder coat. cheap, minimal effort and a great result, tis a no brainer Quote Link to comment Share on other sites More sharing options...
Jase Posted May 9, 2008 Share Posted May 9, 2008 or get it zinc/nickle plated not that expensive and tough as and the don't miss any spots, zinc is all good or zinc nickle ie crome if you're poor (most of the money is in the polishing after the dips so you could ask to do that yourself) Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted May 14, 2008 Share Posted May 14, 2008 or get it zinc/nickle plated not that expensive and tough as and the don't miss any spots,zinc is all good or zinc nickle ie crome if you're poor (most of the money is in the polishing after the dips so you could ask to do that yourself) nickle is put on normally before chrome Quote Link to comment Share on other sites More sharing options...
spanners Posted May 14, 2008 Share Posted May 14, 2008 i gonna be a ponce and say HPC Quote Link to comment Share on other sites More sharing options...
