shizzl Posted May 14, 2008 Share Posted May 14, 2008 basically if look under a rotor with the sump off it looks like a barrel,where the front cover mounts to the front end plate has a cavity,thats where the oil pump is,its driven off a chain drive from the eccentric shaft(crank for pistons),theres also a worm drive gear on the end that the dizzy drives off.thats it...the oil pickup mounts to the base of the front end plate.. the only oil that goes into the sump comes from the oil cooler hoes off the passenger side,it dumps into the side of the front cover,....so only the oil pump and dizzy drive gets lubed in there pretty much.. if you look through the pics on my projects page you may see a pic off the bottom of the engine without the sum on it... and yeah i was thinking of using steel tube for the dipstick not rubber.. steels cheaper and easier to work with..thats if i had a welder grrr Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 6, 2008 Share Posted June 6, 2008 i figured out how ill do the dip stick,i took the dipstick and tube off the escort 1300 motor,and ill just weld a 10mm pipe into the sump to fit the escort tube onto...bingo.. ive also decided to redo the engine mounts cos i just cant stand the look of them.. plus the way im doing them now will allow the use of a 12a or 13b later on if needed.. will do most of the new mount design this weekend,and hopefully mount the fuel pump. i come up with a cool idea for seat mounts for the racetchs aswell cos mounting them to the escort rails made them sit too high.. i wanna be below the door like a mofo gangster yo... Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 8, 2008 Share Posted June 8, 2008 well after the effort and success i put in yesterday i thought id have a go at arc welding my gearbox tunnel.. not recommended but it got most of it done. after about 2million spot welds,gay arc eyes now. 16 blow thrus..grrr. ive got the main part of the tunnel welded to the firewall,and just tacked the sides on. but ended up cutting a new hole for the starter to fit in. spot welding with an arc welder is not good for it,and its slow and sucks arse. but im getting there and i dont need to buy a mig FTW.. i wonder if i can get a good enough arc weld going to do the sump aswell? think i might just tack it together and get a panelbeater to finish it off. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 8, 2008 Share Posted June 8, 2008 yeh bro arc is hard on thin steel. the best thing ive found for arc eye ... if you have an optrcs cut wash your eyes with milk it puts a layer on your eyes so it dont feel ilke they are being sanded with 80grit. cars coming along mate Quote Link to comment Share on other sites More sharing options...
rot808 Posted June 8, 2008 Share Posted June 8, 2008 goodest, i wish to listen to this 10app, it will be as awesome as watching some kind of large animals fighting Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 8, 2008 Share Posted June 8, 2008 goodest, i wish to listen to this 10app, it will be as awesome as watching some kind of large animals fighting ^^^^ just for that comment im gonna set idle at 2500rpm! open headers.... should be sick.. just gotta find a workshop manual somehow.....havent been able to find a 10a rx3 manual.only 12a Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 17, 2008 Share Posted June 17, 2008 parts arriving all over the place,clutch slave arrived today.welder arrived the other day,already spent hours on it. just won an auction for a rx2 radiator which will fit mint,so out with the bongo radiator. now to see i can rig up a heater core.. Quote Link to comment Share on other sites More sharing options...
Jase Posted June 17, 2008 Share Posted June 17, 2008 epic bro want to hear it running must by me a mig soon and catch up with the ute Quote Link to comment Share on other sites More sharing options...
Bistro Posted June 17, 2008 Share Posted June 17, 2008 primo progress. do oyuy have an idea when you want er running or are you just doing it bit by bit?? Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 17, 2008 Share Posted June 17, 2008 bit by bit at the moment...no set date to get it going ae.. all i need to do to have it fired up is finish off the sump,and oil pickup. find a long oil cooler hose.fill it with oil,water etc,run fuel lines and mount fuel pump. maybe make an exhaust pretty damn close really ae.. just little things that take time.. Quote Link to comment Share on other sites More sharing options...
Bistro Posted June 17, 2008 Share Posted June 17, 2008 yea thats pretty close in the scheme of things. alot closer that me Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 18, 2008 Share Posted June 18, 2008 ell i have no sump anymore... got so pissed off with it it bashed the shit out of it with a sledge hammer. fukn holes kept blowing through,it wouldnt seal,and its fukn ugly. spent atleast 8 hours on the fukn heap of shit.. gonna go get some 3mm plate to do it instead on the thin bullshit. ggrrrr very bad mood now.. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 18, 2008 Share Posted June 18, 2008 ell i have no sump anymore...got so pissed off with it it bashed the shit out of it with a sledge hammer. Should be interesting if someone wins your auction http://www.trademe.co.nz/Trade-Me-Motor ... 426253.htm Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 18, 2008 Share Posted June 18, 2008 had nothing but tyre kickers and ball scratchers.. Quote Link to comment Share on other sites More sharing options...
eskynut Posted June 22, 2008 Share Posted June 22, 2008 Had a quick look at your pics of fuel system. You might have to watch out the pump doesn't scavenge from the return line causing the engine to lean out. You may have to put the return back into tank. What about putting a small pipe into filler hose below breather? Just a thought. Looking good though. Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2008 Share Posted June 25, 2008 filler neck is rubber,and about 50mm long.. looking into other options for it after your thoughts.. also my rx2 radiator turned up today!!! yeah! its a mint fit. will cut off the factory radiator mount thing escorts have and sit the radiator flush against the front,with the oil cooler behing the radiator. its also came with a elec fan and 2 flexi type hoses...sweet. saved on having to buy those.. designed myself a new sump today,similar shape,but added another 675ml of capacity,bumping it to 4.1L by my calcs.. will cut it out and bend it up tomorrow.. i may even just make up a template and print out the design plans etc and get a panel beater to make it..their fault if it gets warped from heat or they fuck it up i just saw a pic of the escort when i got it(still driveable) gave me a bit of inspiration to finish it to see it totally boned out.. Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2008 Share Posted June 25, 2008 theres actually not alot of stuff i need to do to get it going.. SUMP DRIVESHAFT EXHAUST WIRING just to get it started...so fairly close..was even thinking of putting the stock sump on with the xmember out,connect oil cooler and radiator,do the wiring,put the un-modded headers on just to see if itll run... then its onto the little things: relocate battery to the boot. finish the seat mounts. get speedo cable made. get some guages.not a must yet though. get it low. finish of the tunnel. make it look purty.. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 26, 2008 Share Posted June 26, 2008 Those terminals look like they have something to do with fuel pressure gauge maybe? Also, I'm pretty sure you can't just run fuel line through your car like that, well legally. Is this going to be certed etc? Quote Link to comment Share on other sites More sharing options...
durty Posted June 26, 2008 Share Posted June 26, 2008 thry probably havent heard of certs etc on the west coast. probly still have carless days/ cousin marriages etc. lol Quote Link to comment Share on other sites More sharing options...
eskynut Posted June 26, 2008 Share Posted June 26, 2008 Those terminals look like they have something to do with fuel pressure gauge maybe?Also, I'm pretty sure you can't just run fuel line through your car like that, well legally. Is this going to be certed etc? How do you think rally cars get on? They all have the fuel lines running through interior. Only thing is it has to be stainless braided line or pipe like brake line stuff - no joins on inside either. Quote Link to comment Share on other sites More sharing options...
