thminiman Posted September 18, 2007 Share Posted September 18, 2007 hah, that = my shout Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 Rofl. Megasquirt first or quad manifold etc first? Quote Link to comment Share on other sites More sharing options...
Mike-e Posted September 19, 2007 Share Posted September 19, 2007 give that car a squirt first, once its squirting good, get quads Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted September 19, 2007 Share Posted September 19, 2007 I agree with mike-e. need squirt to make best gains with quads yes? Quote Link to comment Share on other sites More sharing options...
mikuni Posted September 19, 2007 Share Posted September 19, 2007 Need squirt just to make car run on quads. ecu won't know what the fucks going on even if you feed it a signal via a map sensor or plenum and afm. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 give that car a squirt first, once its squirting good, get quads Mean. I agree with mike-e.need squirt to make best gains with quads yes? Ya - was meaning squirt first as opposed to squirt and fanimold at the same time though. Was never going to run quads without squirt - just thinking of doing squirts first to find any problems etc. I can see myself soldering something in the wrong hole or something so will do squirts first. Is using the brake booster line for MAP sensor a good idea? Hmmm... 1. Squirt 2. + coil packs 3. + quads or combine 1 and 2? Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2007 Share Posted September 19, 2007 Yea seen factory 16v toyota ecu try to fuel quads leans out then way to rich due to way different vacuum. So get squirting I get all my gear from here http://www.glensgarage.com/catalog/megasquirt-kits-c-1.html What kind of pick up does the pug run for spark timing? cam/crank sensor? hal effect or optical etc?? need to figure out what your best spark options are fuel is easy spark can get fiddly Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 Anyone on here done/doing MS and knows what to buy to get spark and squirt? Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 Yea seen factory 16v toyota ecu try to fuel quads leans out then way to rich due to way different vacuum. So get squirting I get all my gear from herehttp://www.glensgarage.com/catalog/megasquirt-kits-c-1.html What kind of pick up does the pug run for spark timing? cam/crank sensor? hal effect or optical etc?? need to figure out what your best spark options are fuel is easy spark can get fiddly Crank angle = will have to be wasted spark? I've got 8 Chev LS1 coil packs. I assume I'd have to trigger two at a time. Edit: It actually has a distributor/rotor etc, but I've put in a later flywheel with 60-2 (I think) timing teeth. Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2007 Share Posted September 19, 2007 buy the v3.0 board and run the extra code then need to decide a pick up for spark. Need to have a otp convo about this Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2007 Share Posted September 19, 2007 yea use the VM921 high current drivers to run them, what pick up does the pug have factory? Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 yea use the VM921 high current drivers to run them, what pick up does the pug have factory? The inductive type I think. Not sure what the proper name for it is. Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2007 Share Posted September 19, 2007 had a quick look on the MS forum pugs run a Bosch VR sensor the v3 board has a VR sensor conditioning circuit built in so shouldn't be much dramas to set up a wasted spark system. As long as it provides a clean signal for triggering would be nice to scope it and check it out Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 Chur So is this what I need to add to my shopping basket? MegaSquirt II ECU kit v3.0 and VB921ZVFI Ignition Coil Driver Kit (x2 or 4?) Is it worth getting... MegaSquirt Relay Board kit and MegaSquirt Stimulator kit v2.2 ? Anything else? Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2007 Share Posted September 19, 2007 relay board kits for noobs not needed, and the stim is sweet for testing but Ive just used a loom with sensors plugged in to test but stim makes life easy Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 19, 2007 Author Share Posted September 19, 2007 How many VB921ZVFI Ignition Coil Driver Kits will I need? Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 20, 2007 Author Share Posted September 20, 2007 Also, Universal Wiring Harness Kit (by RS Autosport) [800-1150] $53.00 Ya or na? Quote Link to comment Share on other sites More sharing options...
thminiman Posted September 20, 2007 Share Posted September 20, 2007 probably worth it for the amount of effort i imagine it will save Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 20, 2007 Author Share Posted September 20, 2007 Mean, what's your credit card number? Quote Link to comment Share on other sites More sharing options...
thminiman Posted September 20, 2007 Share Posted September 20, 2007 hah, you think 53 bucks is alot!? Quote Link to comment Share on other sites More sharing options...
