Zealot Posted July 18, 2007 Share Posted July 18, 2007 No need to change the rear brakes - they're the same in pretty much every pug - afaik the 306 gti6 rears are identical to the 205 rears? Or comparable at least. I've read that running 306 gti6 callipers with the 306 mc and no compensators works well... not sure though. I think it was that way, I could be so incredibly wrong... Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 18, 2007 Share Posted July 18, 2007 No need to change the rear brakes - they're the same in pretty much every pug - afaik the 306 gti6 rears are identical to the 205 rears? Or comparable at least. If there are three different mastercylinder bore sizes i would have thought that there would be three different rear caliper/wheel cylinder sizes? Just guessing. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 18, 2007 Author Share Posted July 18, 2007 No need to change the rear brakes - they're the same in pretty much every pug - afaik the 306 gti6 rears are identical to the 205 rears? Or comparable at least. If there are three different mastercylinder bore sizes i would have thought that there would be three different rear caliper/wheel cylinder sizes? Just guessing. Probably 3 different compensators. 205s with disc rears have some fixed pressure reduction thing, 306s have a load-sensing thing with a spring, then there's the ones with ABS and/or drums to throw in the mix. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 18, 2007 Author Share Posted July 18, 2007 Sorry boe - As far as I am aware there is nothing that you can adjust to overcome a mis-matched bore/stroke/caliper piston arrangement.I haven't done the caluclations on your set up but one of three things will happen: 1) You wont notice a thing 2) The pedal travel will be very short and 'hard' 3) The pedal travel will be too long and 'soft' You need to factor your rear brakes into the equation too. EDIT: You should probably be OK with the fronts. Are you changing the rear calipers too? Not changing rears. My money's on short and hard since it's a bigger m/cyl than the one for those calipers. I don't think I'll mind it that way. Some people who've done it reckon the 205 booster is a bit different, so need to adjust it a bit otherwise it gets ahead of itself and slams on the brakes before your foot touches the pedal. Quote Link to comment Share on other sites More sharing options...
Zealot Posted July 18, 2007 Share Posted July 18, 2007 You still have the 205 MC... so you could try both. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 18, 2007 Author Share Posted July 18, 2007 You still have the 205 MC... so you could try both. CBF TBH IMHO TTYL FTW Quote Link to comment Share on other sites More sharing options...
Zealot Posted July 19, 2007 Share Posted July 19, 2007 Woah. E-rage. MC = master cylinder. You use that abbreviation yourself. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 20, 2007 Author Share Posted July 20, 2007 My first love. Finally got it garaged. Think I'll concentrate on the Pooj for a while first though. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 30, 2007 Author Share Posted July 30, 2007 Browny-gold puddle right below rear brake proportioning valve. Turned out it was actually just dirty water leaking out from a hole in the floor - not sure if that's better or worse. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 30, 2007 Author Share Posted July 30, 2007 ROFL - not quite as dramatic a comparison as I was hoping for. Bottom one is actually 19 mm bigger Quote Link to comment Share on other sites More sharing options...
V8Pete Posted July 30, 2007 Author Share Posted July 30, 2007 Garages r00l. Should've parked it the other way 'round though to work into the night under lights. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted August 4, 2007 Author Share Posted August 4, 2007 Getting there slowly. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted August 5, 2007 Author Share Posted August 5, 2007 Before: After: Widetrack FTW. Haven't taken it for a fang yet - was dark and hungry and would've had to move the Camira to get to move the 306 to get to the 205 'The Castle' stz. Also noticed broken fuel line hose clamp so thought I probably should replace that before I go fanging. Although I did just put in a fire extinguisher, but would rather not have to use it. So now it has 309 GTI rear axle, new pads and rotors all 'round, 206/306 HDI front calipers and 266 mm rotors, 405 T16 master cylinder. Clutch = next weekend/na Quote Link to comment Share on other sites More sharing options...
Zealot Posted August 29, 2007 Share Posted August 29, 2007 BUMP for the 205 thread. Kudos to V8Pete for his help pulling my 309 gti rear beam apart. I've binned one of the needle "bearings" (I use the term loosely) I'll try to snap a pic of the other tomorrow. There was basically nothing left but a pile of maroon dust on one side, and a half bearing shell which was literally nothing more than a semi circle. The other side at least had needles. Which were broken, angled wrongly, etc. Hilarious stuff. I don't think it was actually doing anything at all. Looking into either getting 306 trailing arms, or getting these ones fix0red on a lathe (grooved). Bearings aren't too hard to manufacture (got a friend who can get them done), just working out the most cost effective method. Oh, and DEFINITELY going with phosphor bronze / oilite bearings. I want them to last more than 3 years. Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 2, 2007 Author Share Posted September 2, 2007 Mad Max's Peugeot interceptor Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 2, 2007 Author Share Posted September 2, 2007 Ricky's Trailer Park Boys Peugeot Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 17, 2007 Author Share Posted September 17, 2007 Mi16 clutch and flywheel, interceptor 'box, new linkages and cable = in just in time for trackday. Can actually spin the wheels and not just the clutch now and no more worn synchroness. Held together for 734 km so far. Now I need to clean the bloody garage. Slower than a Daihatsu Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 17, 2007 Share Posted September 17, 2007 maccin boe. have you got coil packs and shit running as well or jsut clutch etc in? also, fuck that shed is so mean. so hospital like Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 18, 2007 Author Share Posted September 18, 2007 maccin boe. have you got coil packs and shit running as well or jsut clutch etc in? also, fuck that shed is so mean. so hospital like Just clutch at the moment. Tossing up doing coil packs and Megasquirt first with standard intake, iron out teething shit, then changing to 4AGE shit later, or get all the 4AGE shit done first then do the whole lot in one fell swoop. I'll take a pic of the yuck I left on the floor on the weekend maybe. Edit: Oh, and new clutch cable pw00ns. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 18, 2007 Share Posted September 18, 2007 Quote Link to comment Share on other sites More sharing options...
