pies Posted February 9, 2007 Share Posted February 9, 2007 right. sick of this fucken engine now. PS broke for the second time this morning. but that aint what themain prob is its damn hard to start and once its going, try to turn it off and it runs on like a bitch. what do i need to smash/replace to fix it? Quote Link to comment Share on other sites More sharing options...
isnowi Posted February 9, 2007 Share Posted February 9, 2007 sounds like your timing is out. Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 9, 2007 Share Posted February 9, 2007 ^^yuh, or getting too hot then running. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted February 9, 2007 Share Posted February 9, 2007 Definately timing by the sounds Try spinning the dizzy backward or forward a touch if it's electronic, if points, get a timing light slammer Quote Link to comment Share on other sites More sharing options...
EURON8 Posted February 9, 2007 Share Posted February 9, 2007 try to turn it off and it runs on like a bitch. I had a similiar problem with my escort, It would stayrunning after i turned off key and then i started running it on 96 -98 octane and never did it again. Quote Link to comment Share on other sites More sharing options...
pies Posted February 9, 2007 Author Share Posted February 9, 2007 yea... got a timing light. just cant see any damn timing marks lol damn grease Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 9, 2007 Share Posted February 9, 2007 Tune by ear. Starts to run like arse either way and you've gone too far. Then just fine tune to taste. Mmmm, enginey. Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 9, 2007 Share Posted February 9, 2007 ky ...takes 5+ goes at tuning motors to get the ear right haha , yea sounds like too advanced with to lower octance mang , that or your plugs are too hot for the motor Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted February 9, 2007 Share Posted February 9, 2007 Pies I think you should buy the 18RG off've me. do it! Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 9, 2007 Share Posted February 9, 2007 ky ...takes 5+ goes at tuning motors to get the ear right haha , yea sounds like too advanced with to lower octance mang , that or your plugs are too hot for the motor Yeah, but you've got to start somewhere. Might as well be now. Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 9, 2007 Share Posted February 9, 2007 true stz^^ ..used to tune escort every w/e ended up being a pro/ backyard master at tuning it , was also very good at changing carbies Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted February 12, 2007 Share Posted February 12, 2007 its damn hard to start and once its going, try to turn it off and it runs on like a bitch. Is this where I say get a pinto..... oh wait I'm not a hater Like the other guys said timing or octane is probably it. Other causes can be the Run on valve/solenoid is bung or needs adjusting (some cars have them some don't). Hot spots in the combustion chamber like carbon build up or cracked valves. Are you running a hot plug if it's too hot this could also be causing the run on. Check the timing, full up with 96 or 98 if it's still happening give the carb a slow trickle from the garden hose with a fast idle to steam clean the combustion chambers. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 12, 2007 Share Posted February 12, 2007 Check the timing, full up with 96 or 98 if it's still happening give the carb a slow trickle from the garden hose with a fast idle to steam clean the combustion chambers. ^ straight from waitangi day no doubt. that's rangi shit Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted February 12, 2007 Share Posted February 12, 2007 Check the timing, full up with 96 or 98 if it's still happening give the carb a slow trickle from the garden hose with a fast idle to steam clean the combustion chambers. ^ straight from waitangi day no doubt. that's rangi shit It's cheaper than the BS upper cylinder cleaner and it works a treat. You'd be surprised how much water they can drink. Ever seen a head pulled from a car running water injection? From: http://en.wikipedia.org/wiki/Water_injection_(engines) An interesting side effect that has been reported by some is that water injection effectively "steam cleans" the engine interior, resulting in less carbon residue buildup. Glowing hot carbon deposits are a known cause of knocking. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 12, 2007 Share Posted February 12, 2007 pies would be thw guy with hose on fll tit though. I hear ATF down the carb has similar effects. I'd be happier rocking that eh, even then, sketchy and pox. that carbon's gotta go somewhere hen it falls off... into ring grooves, stuck on valve seats etc etc.... Quote Link to comment Share on other sites More sharing options...
pies Posted February 12, 2007 Author Share Posted February 12, 2007 pies would be thw guy with hose on fll tit though. water blaster cunt. high pressure. like turbos. id rather run 48psi over 12. mad drift yo! Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted February 12, 2007 Share Posted February 12, 2007 haha, I have never heard of someone running shit down the carb....... did you turn that thing on the side of the carby you fool, bet you did Allan Quote Link to comment Share on other sites More sharing options...
pies Posted February 12, 2007 Author Share Posted February 12, 2007 turned it like, 0.5 of a degree ages ago. started playing up about a week later. you told me that wouldnt do shit anyways Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted February 12, 2007 Share Posted February 12, 2007 we can have a timing light sessision if you want? Quote Link to comment Share on other sites More sharing options...
pies Posted February 12, 2007 Author Share Posted February 12, 2007 we can have a timing light sessision if you want? ive got one here. i just cant see any timing marks lol besides... i dont have any beam atm Quote Link to comment Share on other sites More sharing options...
