shandawg
About shandawg
  • Birthday 20/04/1977
  • Gender
    Male
    Auckland
720 profile views
shandawg's Achievements
Advanced Member
Advanced Member (3/5)
200
  1. I was! Can still get it if needed
  2. I could chuck that on my mill and clock each hole - would be bang on
  3. Let me know if you need a hand converting
  4. If anyone here has drawings of mazda rotary housings and rotors I would be super keen to get a copy! not having much fun with the trochoidal curve thingys..
  5. Someone up there will surely have some ISO 46 hydraulic oil lying around. for a Jack the difference will be negligible. any engineering workshop or earthmoving crowd should have loads and would probably be happy to sell you a litre for stuff all
  6. I sell this stuff in 1L, 5L and 20L containers for wholesale
  7. So you're the bastard that beat me to those let me know if you don't end up using them I could still be keen to take them off your hands
  8. Not many if any of mine either, got there a bit late due to locking my keys in the boot
  9. Compressor Oil! Depending on what type of compressor it is dictates what type of oil you need. I carry ISO 68 compressor oil (which covers most common compressors) in 4L packs at my place if you need some
  10. I'm sure you did, but did you use proper LSD oil?
  11. Yep I have Total Rubia S 30 SAE 30 monograde in 5L and 20L packs, OS deals as always
  12. They look a bit like BBS E26
  13. I have a couple of open ones if you get stuck, last R200 Long nose clutch LSD I sold on TM went for $900!
  14. FYI Your oil needs to be ACEA C3 spec
  15. The Toyo Proxes 4's on my 1600 lasted 3 years with an SR up front, unless you're doing skids or the toe is really bad you should still get ok tyre wear
