CUL8R
Everything posted by CUL8R
  1. This is a good calculator to help you out; https://spicerparts.com/calculators/transmission-ratio-rpm-calculator https://tremec.com/aftermarket/resources/gear-ratio-calculator/
  2. Simpson beat me to it, but Im sure 50/50 Acetone and ATF is the go to, then working what movement you can day by day. Rather than trying to force it
  3. I would recommend he re-taps all the hubs, plenty of cutting fluid as you go and a new set of wheel bolts. More often than not with the wheel bolts you'll ruin the bolts before the hubs 99% of time at work fixing said issues from similar stories will fix, and torque to spec
  4. CUL8R
    Custom Shocks
    GAZ Shocks in the UK used to do custom ones if I remember correctly, and there was a agent in Auckland I want to say Zep used them?
  5. I've even got a complete long block, manifold, Carb & dizzy you can borrow to mock up
  6. Intech + Holley & XF dizzy???!
  7. Top work on the project, really quite enjoy your updates. I was reading about the Atlantic just the other day and then thinking about this!
  8. I think from memory, Windom, Camry and the weird import Avalon. If I remember the larger capacity is in the Highlanders of same period and maybe Prado? I always thought the 2mzfe was a pretty cool motor 15 years ago, but newer stuff surpasses it now
  9. CUL8R
    Diffs
    Justin Neil Engineering?
  10. Just saw this this afternoon if you wanted/needed another https://www.facebook.com/marketplace/item/927005532692507/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking={"qid"%3A"-751165108593130514"%2C"mf_story_key"%3A"218500138871782863"%2C"top_level_post_id"%3A"218500138871782863"%2C"commerce_rank_obj"%3A"{\"target_id\"%3A218500138871782863%2C\"target_type\"%3A6%2C\"primary_position\"%3A1%2C\"ranking_signature\"%3A4222493596088436965%2C\"commerce_channel\"%3A501%2C\"value\"%3A0.00099415267263071598%2C\"upsell_type\"%3A3523%2C\"candidate_retrieval_source_map\"%3A{\"8743805032381762\"%3A3001%2C\"8588079621290170\"%3A3594%2C\"8696433440443800\"%3A805%2C\"27346751768305622\"%3A805}%2C\"grouping_info\"%3Anull}"%2C"lightning_feed_qid"%3A"-751165864489222210"%2C"lightning_feed_ranking_signature"%3A"4222493596088436965"}
  11. @ Watkins race engines in Christchurch has a LS1 & Auto, he had bought off Osaka imports. Has manual speedo drive converter, ECU (with mild tune) and loom. He'd bought it for a project but then went another direction.. Was wanting 5k for it He also has another LS, Blown with Weiand 6/71 ...
  12. Just if you wanted a cheap bellhousing; https://www.facebook.com/marketplace/item/3516829395120587
  13. Bowden Engine Parts might be worth a try; https://www.bowdenengineparts.co.nz/
  14. ^ That one stopped outside work maybe 1-2 months ago Im pretty sure, I think in the right light I swear I could see a intercooler. Looked pretty good in person, I was winding one of the workers up telling them it was their next job - as they were shaking their heads in disgust
  15. If you get stuck I have a muncie rebuild how to with from memory a section on the Hurst Shifter. (in saying that on youtube there is lots of videos) But basically I would polish up the plates and lightly grease. Have the linkage bushings tight (or if you really want to splurge get spherical rod ends) , and once you know the throw from the lever itself, the hurst housing should have some threaded holes - for a nut/bolt to be wound in as stops - that way you can smash gears as hard as you like against the stops without over throwing the selectors
  16. Mate that blows absolutely, you know where I am if there's anything I can help with
  17. He's based in Kaiapoi now, I think life member of Canterbury Car club, haven't asked him about it in ages Has a De Joux as well
  18. Just to reinforce what you're saying, a relative I think is something like 10-11 time National (?) motorkhana Champ, still has it too;
  19. TBH out that way I would recommend having a chat to Aaron; https://www.facebook.com/asautomotive He does wofs and works on old vehicles anyway..
  20. Skip to 11.30 and it might be of interest to you, Im wondering if its somewhat similar given its around the same vintage..
  21. Do you mind me asking how much/where did you get the flare tool from? Having done enough with the usual $35-50 toledo special over the years I can appreciate those ones like you're using
  22. If you're coming down to Chch Im sure I have a roll of the muffler packing in the garage you can have Alex
  23. Damon @ Rockyauto or Simon @ palmside would be the two blokes Id trust with the carb
  24. Weirdly just saw one on my lunch break the other day; https://www.facebook.com/marketplace/item/737405721698954/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Aad380dd9-862e-41a0-9713-dd4d3a85a1e6
  25. Do these have build/id plates on the LF lower windscreen area ontop of the edge of the dash where it meets the screen? (like on Chevys?) Thats the actual american Vin rather than the NZ alloy type one.
