Everything posted by yoeddynz
plus one for electric pumps. I've not used one but everything I have read about them makes so much sense. I have allowed for the fitting of one in the back of my Imp by making sure the pipes layout would suit plus added some wiring in place just in case the Datsun pump wasn't up to the job of pumping coolant to the front etc. When I last looked up the prices the Davies Craig pumps, with the electronic controllers have really dropped in price. Certainly not at all excessive for what they do and the quality of product.
Ha- yeah I had found that a while back. So much info on the techwiki datto1200 site. Sadly I think my WOF guy would spot a twink head on my Datsun engine and say" no - you're pushing it now Alex" -
Wow Tom. So many bits to look at. That's my evening sorted. I'm an erring towards using the edis setup now - I reckon the Ms1 was supplied to Rob setup for that. I'll plug the ecu into my laptop and run it up to see what's what. Figuring is already been loaded with a firmware, hopefully extra code. From what I've read the edis stuff is pretty reliable. Grant? - I've been offered an a15 for $100. I think the complete engine. I cw no idea on its condition but worth a punt at that price. But I'm also waiting on someone else who might have some spare parts. Luckily I have two twin side draught inlet manifolds to hand - one for my early round port engine and one for the later oval port heads (Including a15 as well?) I'm sort of hesitant to split this engine as its running so well for an unknown unit. However if I was to get a spare head then I can tidy it up, new guides, valves etc if need be and use it to mock up the inlet. But I'd also have make a new set of headers to suit the different head and stud pattern Also quite interested to see what a straight swap to injection would be like without touching the engine. -
Well its been a while since I've updated this thread. Mid July was where I last posted up anything of worth. Little Imp got parked up in the corner of the workshop so leaving anough space for our neighbours to make use of the shed while we took off to England for a decent holiday. Hannah got to catch up with her family, we both did heaps of cycling and running, had plenty of sunshine and beer plus I got to go along to the retro-rides gathering 2019! As I always do I had a fantastic time there and came away with boosted Mojo and lots of ideas. Before leaving the UK I ordered a few spare parts for the Imp... We got back to NZ in September, just in time for the start of spring. The Imp was sitting there tucked away, a tiny little puddle of oil under the sump just like a good little English car should have... First job was to fit the shiny new lenses. Hannah jumped straight into that, an easy but so very satisfying job to do... We then took the steering rack out and fitted the new centre gaitor. Hooray for a rack that holds oil... Having decided I was pretty happy with where the temp gauge needle sits once fully warmed up I carefully measured the resistance across the potentiometer I'd been using to adjust it. I then made a little joining lead fitted with a resistor of the same value. This replaced the adjustable item and should be it for the temp gauge. At some point in the future I may well make a new instrument cluster to suit the dash as I rather fancy having a rev counter in a place that I can actually see it ok. We have been driving the Imp since getting back to NZ as much as possible. On its first journey out since back I got this pic... We've had a few decent trips including a one really neat drive all around the local valley roads and hills, some gravel roads etc. Its so fun to drive. I'm really getting more confident with the handling and how to get the most from it. The engine seems fine and loves a good trashing. The carb is still a bit iffy with that worn out primary spindle still allowing some air to sneak in. I have ordered a new carb from China and will see how it goes. It was cheap enough to try and when I eventually fit injection I can sell the carb on. Whilst out on that really fun drive I got this photo. Shame I only had my phone as the sky was quite moody... After lots of driving I checked the plugs. They look fine with what I think looks to be a good colour... I thought it better to fit the fire extinguisher I bought before our holiday. It tucks away neatly behind the drivers seat... In other news I have been collecting many different parts needed for a conversion to fuel engine management. I just scored another megasquirt one (2.2) ecu plus a full loom and some edis bits - this time from our mate Rob in return for me doing some machining work for him... I need to decide on a few bits needed and also in which direction to go for the inlet layout. Maybe Itbs but maybe a plenum with a single tb. I foolishly dillydallied about when there was a full set of cbr900 ITBs on trademe for $55 including injectors and loom and subsequently missed out on them. At the time I wasn't sure about the suitability but for that money I could have made them work. Not sure on ideal throttle size but they were 40mm each which given the Datsun only has 30mm inlet valves I figure they'd have been plenty. Then I would have had all of the doorts! I'll keep looking... I'll be using a 36-1 trigger wheel, also supplied by Rob. Luckily there is ample room to mount it on the back of the main pulley. Both MS1 ecus I now have use the earlier version 2.2 board which don't have built in VR conditioner circuits. I can make a VR conditioner board and use VR sensor, of which I have many. Or I could use the Edis setup (which has a VR conditioner built in and uses a VR sensor) that came with the MS1, of which I suspect the ECU has been supplied already configured to use. I have never used Edis before. Hmmmm? Its a bit ugly and clunky though. I dont like the quite large ignitor box I'd have to sit somewhere. Or I can go with a Hall sensor but then I'll have to locate one from a wreckers- but what car? As usual I want to do this conversion as cheaply as possible because its just more satisfying for me that way. In my first few casual searches it seems that they are quite pricey and can be a bit frail or temperamental in use? More research is needed, of which I must say I do find to be one of the most fun parts of modifying! Oh also - I fitted a new speedo cable and now have a speedo needle that doesnt wibble-wobble all over the place. How thoroughly modern!
- 98 replies
- 32
yoeddynz replied to azzurro's topic in Project Discussion
Pop in for a coffee on your way through. Then take the west coast and have a coffee at 808s place once over the haast pass. Then stop by at crazy Tim's for another coffee. Sorted. -
I'm liking that mismatched bonnet look. But then look at my wagon... Urbun camo door cards next?
I'm sure @Slacker_Sam.Will deal to him with a suitable tool selected from repco. Sam- is he the same guy who used to have all the cars near motueka, in view from Peter tallys mansion?
After you told me about this thread when we met in Blighty 2 weeks ago, I've finally sat down and read it. I wish I'd found it earlier. So cool. Top work on the sympathetic rebuild. It looks great. Also-So neat that Dennis went along to leadfoot with you. I could picture him having a great old time. Presuming he's still able to drive it is there any plan to find a location where he can do so? Fuck I love small cars, especially sports cars that handle well. This car is all that. Thanks for sharing.
It would be a shame to ruin the sweet lines of the 99 with pins. Please persevere. I'm sure between now and the time you actually need to go for a wof you'll have found spare parts elsewhere to sort it.
Cool saw. Would be so handy. What's for me curious is how big is the top drum/wheel? From what I can tell it must have two wheels on top and the blade must be far more flexible then a normal wood bandsaw...
@bean.101 I couldn't find a discussion thread. So here goes. I'm loving all the engine machining stuff. It's bloody interesting and well appreciated I think by many on here. Please keep those posts coming and add even more info about! I like all the different machines and It's good too see where ones money goes when ya leave an engine at a reconditioners to be machined. Will you be adding stainless valve seats to help it cope with unleaded? Alex.
#Auckland weather?
That's a bargain for a good flywheel.
Oooohhh. It is suitably wedgey to go along with your previous cars isn't it. I'll find some pics when home but my brother owned a TVR S3 with the later 2.8 efi cologne engine. He had it since about '96. Was the second owner and bought it from Paul Matty cars in chch. I'd drive down to chch from Blenheim on a Friday night in my supercharged MR2 and we would spend all weekend hooning around the hills in banks peninsula and do midnight drag racing with all the lads along Moorhouse Ave etc. Dems da days He moved to Blighty so hannah and I would look after the TVR. Some sweet drives over to Nelson etc. Taught me many things about power oversteer in the wet and being quick with the wheel. fuck it was fun and the v6 sounded fantastic. Low point was being fair and squarely beat in a drag race against a (twin turbo?) v8 diesel prado thing up the gentle Annie hill out of Nelson. Oh how they laughed. Red faced me. We sold it to some fella from chch who had started a TVR club I think.
Your workmanship on the infilling around the tank is great! It's looking very factory. Damn I need to get or make myself a bead roller.
Great work there. I've been waiting for an update. Man you'll be itching to get back to it now you've done by far the most critical part of the conversion. The flywheel looks good. Is that a fidenza? How much did that cost? If I do decide to fit either the klze or the kfde I have laying about here into my wagon (rather then the duratec) I'll have probably use the k8 flywheel I have. It's not as light as the cromoly one that was in the first viva but at least lighter then the standard 2.5 items.
Hayden's Datsun 720 4WD project discussion
yoeddynz replied to WhangareiKE70's topic in Project Discussion
Faaaaaark @ that crash. Seeing that only goes to put another nail in the coffin for our van. Ours is a 4wd hiace too. It puts the willies up me when we find a tourist coming round a corner on our side so I tend to drive it in super slow cautious mode. But not much one can do when a drink idiot crosses a centre line etc. We've been planning a replacement for many years now, similar to what you're doing but with an old Bedford truck cab. Anything that ends up higher and with an engine in the front eh. I hope your back recovers awap and it all comes right. Really interested to see your tiny house build. It's certainly something we'll see more of as house prices get ever more ridiculous eh! -
He's a bloody helpful fella him.
- 41 replies
- land rover
- 109
- (and 4 more)
I will when I get back. Its been carefully placed in a show box for many years. I'd also scratch built a Volvo f10 cab out of cardboard when I was about 12-13 or so. Working interior lights, proper cloth upholstered seats etc. It even had a opening fridge with a teeny model of a can of coke in it. I'll look for photos when I'm back. Looking back at that, building such things at that age.. Hmmm. Maybe I was on the spectrum or whatever the trendy thing is.... Or just a young truck loving nerd
Anyone here into building 1/24 trucks? I've been scratch building a tnl freighting merc skip truck. Probably the oddest truck to want to build but it just appealed to me about 27+ years ago when when I started on it. As a youngling I'd even ridden my pushy many times to the tnl yard in Blenheim and taken photos and measurements of it. It's based on an italeri kit that I have had to shorten the cab on in 3ways. Chassis cut down and converted to 2axles. Scratch built air system, underpinnings etc. I've not touched it in two decades and had a long way to finish. I'll get some photos if interested. Looking forward to quiet modelling times during a storm in a cabin with cups of tea one day
Ditto that man ^ please do nothing more then is needed t to make this legal to drive on the road and roll it as is. Don't even clean the windows.. Except for windscreen. Its so cool!
Yeah we'll do a bbq meet at ours in September. The imp certainly is bright eh! Sort of needs to be ready to spot when it's about as high as the hubcaps on a typical 4wd ute these days.. -
There's two sets of holes. The inner ones are about 142mm pcd. The outer ones are around 159mm. The speakers are pioneer.......so I am figuring that the pioneer covers you have would probably work I'll send you a PM. -
Cheers Ben- I'm guessing you were working up in Richmond heights?
