SloNLo
Everything posted by SloNLo
  1. i like your combination of Fuck and Yeah in appropriate proportions.
  2. http://users.tpg.com.au/users/loats/technical/ma61/gearboxes.html according to the above page they use the same yoke as the RWD Toyota Axx automatics. a list of which can be found in the link below http://en.wikipedia.org/wiki/Toyota_A_transmission might add a few more options for you.
  3. find out how to clear and reprogram your Garage door so that the stolen garage door opener no longer works, if you haven't done so already. last thing you need is them getting any more of your stuff.
  4. SloNLo
    3TGTE Wiring
    have cut down two full wiring loom's to just 3tgt engine loom's. give me a shout if you have any questions.
  5. could just run a 2mm spacer behind each pad. pins will hold in place and add grease to stop any chatter sounds
  6. http://www.supramania.com/forums/showthread.php?94010-7MGTE-or-1JZGTE-bell-housing
  7. 6 stud hilux redrilled should would work out ok not sure on drum size though
  8. Robinson Instruments they will sort that shit out http://www.robinsoninstruments.co.nz/ri_services.html
  9. try a heat gun/hair dryer to soften the glue/ film makes it peal easier
  10. Thanks man. I must get around to putting up some more recent pics. It's now sitting another inch and a half lower in the rear.
  11. keen for next meet might even have Bike project sorted by then
  12. wip a plug out and check Stroke MA stroke IS 98 mm NA Stroke is 83 mm according to E-nets
  13. you could ask Cletus http://www.oldschool.co.nz/phpbb/viewtopic.php?f=17&t=21943&view=next from the pics in his build up it looks like both the back ports are in use?
  14. will be rocking along to this all going well
