drftnmaz
Everything posted by drftnmaz
yea you can run ke30 or early ke70 87mm steering arms, have to run the ke30 brakes on 30 struts, think they have the smaller spindle...
they are 28mm by ~15mm wide on the inner bearing and 17mm by 15mm wide on the front bearing, and about 70mm from outer edge to edge, i've only got the stub sitting here atm
i haven't got any veriners here, but ke70 looks about 28mm, will try to find my verniers for proper measuring
Purchasing 2nd hand motor - TIPS/HINTS Required.
drftnmaz replied to kseries.rookie's topic in Tech Talk
if you could bolt a starter motor on and do a compression test that would be top of my list the smell inside the rocker cover, can often smell burnt oil when engine has had hard life, or fuel if rings are fucked pretty much always a gamble tho, 20de are worth next to nothing so not that much of a gamble? -
this /\ and murch is the man when it comes to turbos! although he'll try and talk you into a holset, cause there cheap/reliable and make decent power i run a td05hra-16g in 10.5 hot side and i get 220kw on 17psi...(on sr20) with decent cams my tuner said 245kw shouldn't be a problem, twin scroll fucking rules!! have heard the 20g wheels tent to choke abit with the td05 hot side, but haven't tried it myself
the adjuster on the front will normally just be a pot that varies resistance to a transistor inside the unit that varies the voltage to the motor, so measure the motor with multimeter and see whats its doing? it may be supplying 12v and a 5v motor may be fitted? or the transistor has gone bad (not too likely) or the wiring from the pot at the front has been damaged creating a high resistance so telling the transistor to supply more power than it should
sweet! its a cool computer system!
Is there anything out there i can get a 16" 4x114 steel wheel off, they are to be widened, so any offset etc should be workable, even space savers considered as a last resort anyone know of anything out there that runs these factory?
Recommended shops to build a half cage - Auckland
drftnmaz replied to ae85 fiend's topic in Tech Talk
yip thats me -
if your not in a rush i do cages in between other work and im in south auckland, never done less than a 6 point tho, as adding the front stays on later and still guaranteeing 360 degree welds is often hard to do nicely without dropping cage down -
the ones i saw at p-a-p bout a month ago were all 1450, factory ke70 is 1400, so 25mm a side, which is nothing really and will make skinny wheels still look decent... gay stud pattern but kurt shouldn't have a problem fixing that, ta22 is ~1355 so shorter than ke70
try atom fasteners (09) 272 8664 35 Neilpark Drive, East Tamaki its where i get all my 12.9 grade metric fine stuff, i'd imagine they'd send to you with a credit card... prices are usually reasonable aswell
i'd be tempted to wash a little bit of petrol around in there, then do the exhaust pipe trick for 5mins to be safe... i've never tried a diesel tank tho
i've done a few and even repairs on race cars in rushed conditions and always just use the exhaust trick, i was pretty dubious of it at first but it works awesome, hardest bit about tanks is cleaning the swarf/crap etc out at the end
custom wound coils are ~$250 for a pair
i have a mate with a huge list of all there rack-ends and lengths, when i see him later this week i will inquire if he has listings of balljoint tapers... tbh i doubt it as there are so many different ones and most are non-standard (tooling wise to ream out new arms) i've made tooling to do nissan tapers (i make steering arms from steel) so i could ream your arms out to suit a nissan outters to keep things more standard if that helps? (they use a m14x15 thread) i will measure tapers if you want to see if this is a option
you need to shorten the strut tubes so they keep the ae92 inserts tight and ALSO gain the extra 40mm of travel, then goto somewhere like snell springs and get some firmer springs made to suit the height you want, put it all together and you can even be legal at a decent height, and drive nice! factory spring rate is ~85pd, which is fuck all, the ke70 i did for a customer last week i made 250pd springs to suit (also fitted a shock with superior valving to control such a high rate in a light car)
was digging through some photos and found a couple of other tanks i've done for people, one was a injected twin-turbo HQ..
yea mod up your tank, i don't run a surge tank in my d1 car, just tank baffles (quite a few of them) just find a factory tank and cut it up, copy design etc heres one i did for a customer not long ago, cut up a skyline r32? tank, notice the internal bowl added from the other tank and then flange added for bolt-in ease
awesome!
yea in suck-through you don't need to do anything to the carb, just jetting to provide more fuel to suit better afr's oh and your not meant to put carb or inlet pipe lower than the intake, due to fuel pooling in the pipe, so your intake run should always run downwards, but have seen a few that don't and still seem to survive
i've done a few carb turbo, draw-through and suck-through, each has it own problems and good points... as said above timing is the biggest issue, limiting the mech advance can work, changing springs and weights to suit can also work, easiest is locking it and finding a almost happy medium, on K series engines i would lock it around 18degrees, but alot of other factors/combos came into play, locking it ensured you had power when you backed off the gas and got back on it (ie skids) can also jimmy a adv/retard solenoid onto the dissy if your keen enough, locked dissy 4k's would get me 6-9months of giggles before spinning bearings etc on suck-through you need the right type of turbo, it has to have a carbon seal or the fuel will kill the rubber seal quick smart cause the vacuum is too high having the throttle across the turbine... there are ways to lessen the effect, but just get a turbo with carbon seals in the first place SU's are my pick for easy tuning on suck-though, anything blow-through requires a power-valve and boost enrichment to compensate for what the carb can't tell, also need to pressurize the float to keep everything equalized, so fuel pressure also needs to be rising rate... suck-though you can still keep the factory mech fuel pump etc
yea i don't run water through mine either, optional extra etc... (only BB turbos really need water)
Brennan's, ke70 Corolla, 3sge Beams powered.
drftnmaz replied to Brennan's topic in Project Discussion
yea i went through it a little while ago, had a customer with ae86 everything and struts were a abortion so i remade using some late ke70's struts i had as spares.. i may have some late model hubs kicking around if you wanted to adapt some other brakes?
