Showing content with the highest reputation on 09/02/20 in all areas
14 points
9 points
7 points
My exhaust had a terrible bracket on it that sucked! My OCD couldn't handle the fact that the two pipes weren't parallel. Over a 400mm section where they run along side each other, the gap was out by 10mm from front to back. I saw this as an opportunity to fix two problems. 1) make it look right to the eye 2) raise the lower pipe by 15mm and the upper pipe by 5mm. This will really help with ground clearance, maybe not completely solve it...but certainly won't hurt. So: Marking out, lifting the holes by 10mm. And looking at the pipes for nice sweeping parallel lines. Success!!! So, lower pipe is now 15mm higher than before, with nice clearance around all the bits you don't want a hot exhaust touching. Happy as fuck! I'm probably going to cut the lower pipe mid span and shorten it by about 40mm to bring it inline with the upper pipe and my frame angle where it heads up to meet the axle. But that can wait for another day.6 points
6 points
6 points
5 points
Took Friday off to get a 4 day weekend and make a serious push on the crown. Some rain and some socialising took a chuck out of my time but still managed to get the shell, hood, boot and gaurds in fill primer. Found a few spots of rust on the bottom of the rear doors so will drop them round to the panel beater to have that sorted, then the doors will get the same treatment. For now, here's way too many photos of a car in primer, but given its never been this straight or single colour in my ownership, I'm getting excited. Blocking back will take a while, but the end is in sight! Then I can start on the manual conversion which I've been slowly gathering parts for and aside from a driveshaft (will get mine modded to suit hopefull) I've got all the bits there. Including a hand brake centre console which is sitting in Japan still and I really need to pay for the shipping to get it here for when I need it...5 points
5 points
4 points
4 points
Ran it for a bit longer today to get heat into everything exhaust and turbo. VGT is weird when you muck around with the vane control it goes from silent to fucking loud! Turbo is doing its thing but engine has got an electronic rev limiter so cant give give it berries to see what it can do, will disable it. Need to get the SU on and some plumbing done3 points
I'm a total storage slut! Love to have a place for everything...and everything in its place. So: Steel/storage racks. I can fit anything from 0.6m to 3.6m lengths of steel/timber. The racks start at 1225mm so I can fit a sheet of plywood or whatever under it leaning against the wall. I feel another shed tidy up coming...3 points
Finally got the wheel tubs spotted in place and sealed against the quarters. I was told by a number of people don’t weld them completely to the quarters as they need to have a bit of flex to them. i haven’t spot welded them to the frame just yet as I need to lift the body one more time so will do that once it’s on for the last time.2 points
The hardest part about driving an EV is telling your parents you're gay. In another 30 years I'm going to be no different to the old Barry's with their bib overalls and trucker caps at tractor/steam carnivals. Burning dinosaurs and telling Barry sharns about the golden age of gasoline. (Meanwhile the much hated and maligned millenials will be the new boomers in training, pissing and moaning about whatever handle they bestow on the pesky kids of that era) Dont forget who you are Alex. Burn dinosaurs till the end..... /ling.2 points
I needed to install the oven I fixed up from a few pages back. Kitchen Tax is real though, people talking about spending all sorts of silly figures on kitchen reno's. I decided to throw it in myself, bar the gas plumbing. I quite like the old cabinetry so I just built up a new cabinet to match the old, save replacing the lot. I also uprated the range plug & switch & shifted the outlets to suit the new benches. A bit of tiling and edging to finish off, but now we can get stuck in to cooking up a few feasts!2 points
Took the plunge and ordered a full set of superpro bushes, also sourced replacement front seats and a new engine/box. Enough to be going at for now..1 point
Simon at Airride NZ has been around for a while, has owned some sweet air bagged vehicles. The kit I got from him (for my 61 Belair) was basically a bolt In kit, which came with the bolt in mounts that meant I didn’t need to modify the spring pockets, only thing I really had to make was front shock mounts which weren’t too hard. im using a very basic system for now, 8 valves and a 7 switch controller. However to get certified I basically ran all the 3 front and 3 rear switches through relays so even if you try to change the corners, it just controls the whole front end. It’s good for cert, but not being able to set the corner heights is a pain, good for cert, but a pain none the less. I have a weak LF shock and to get the ride heights correct I have to raise the car fully up and then lower it to the correct height. Pain in the ass, when I get around to try rebuilding the Belair I’m planning on running an E/Level to make it easier and accurate1 point
Forgot to post this - cheers for the hoon in the imp Alex and Hannah! Was awesome to see you guys in December. that imp is a rad AF little sled and as for the shed set up on the land - epic. that Mazda Ute on the hoist was a thing of beauty too @maxted1 point
My son rocked up with some awesome looking magnesium go kart wheels that will look wicked on the front! Might try find some for the Rear too. As a bonus they should sit it on its guts. Its going to have to run a jackshaft to get power to a usable clutch I'll just buy an Ebay 1" unit and be done with it the clutch can run on the jackshaft instead of the motor as the 1 1/8" engine shaft is a prick of a size.1 point
This guy does control boards for getting rid of the canbus gubbins from leafs https://pandspowerelectronics.ecwid.com/1 point
@yoeddynz Have you ever thought of a leaf conversion? I have been thinking quite a bit about an electric Jag but I'm struggling to find much information. A comment you made about a Testla Imp got me thinking about how a Leaf Imp could work.1 point
The other big reason is getting an even suspension weight on each corner, if someone was not paying attention or was an idiot it is easy to get the car level so it looks fine, but have very uneven settings- like 100psi in the left front and right rear and 20 in the other two, then you have 2 wheels that will lock up under braking, or the car will do weird things going around a corner The book also mentions the twisting on the vehicles structure being an issue which makes sense if it's not a very strongly built car1 point
