I’m making up a couple of roll cage thickness bars for support to run from the firewall to the front of the chassis.
made the firewall pieces out of 3mm plate.
I need to sort the front end out now before I go any further on the tilt front as the front struts will impede the internal cross bars I need to put in.
Looking for an Lj torana front suspension if anyone knows of one.
Started work on the lower bracket for the pivot points.
This piece will follow the curve of the front sheet metal and be mounted where the front pan and fenders bolt together.
using a 25 x50 x 2mm bar with drilled and filled holes.
