kyteler Posted February 8, 2016 Share Posted February 8, 2016 Are you from Gore? Quote Link to comment Share on other sites More sharing options...
Jorden Posted February 8, 2016 Share Posted February 8, 2016 kaiapoi/gore same breed... Quote Link to comment Share on other sites More sharing options...
Jorden Posted February 8, 2016 Share Posted February 8, 2016 ill more than likely satin black it like the rims, don't worry! Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 15, 2016 Share Posted April 15, 2016 my god this is rad Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 5, 2016 Share Posted June 5, 2016 I'm very late to the party here, and I hate to play devils advocate. But shouldn't there be a cup on the bottom of this spring? 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 5, 2016 Share Posted June 5, 2016 I would have thought so too, apparently not though Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 5, 2016 Share Posted June 5, 2016 jeebus....................... Quote Link to comment Share on other sites More sharing options...
Jorden Posted June 6, 2016 Share Posted June 6, 2016 freaked out for a sec there thought i was going to have to take the bastards out again Quote Link to comment Share on other sites More sharing options...
Jorden Posted June 21, 2016 Share Posted June 21, 2016 So heres a run down of the conversion now that ive sorted out all of the issues that came up, this is how i did it V8 Base plates Original trans crossmember with tag welded on the front as the c4 mounting bolts are further forward Inhibitor switch is different, this needed to be changed Used the original accelerator cable Cut the heater pipes at the firewall and welded some 90 degree bends on so i can still use the heater Speedo drive/gear is different and simply needed to be switched over by taking the small clip out Trans lines need to be fed down the other side of the car as they are on the other side of the trans, also means i needed to flip the cooler over and move it to the other side of the car the original power steer lines ended up very close to the headers so i cut the ends off mine and got them fitted to another line so i could run them elsewhere The fuel line needed to be pushed back out of the original hole and ran down outside of the engine bay and popped back in infront of the shock tower The shifter for the trans is on the opposite side of the original one, so to keep the column auto shift i used a cable Custom exhaust dual 2.5" with single coby louvred/baffled hotdog on each side sounds very nice but very loud Maybe a few other things but thats all i remember for now Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 31, 2016 Share Posted August 31, 2016 ..I think you just out boganed Gore.. 1 Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted August 31, 2016 Share Posted August 31, 2016 ..I think you just out boganed Gore.. Na its not full primer with guide coat yet 1 Quote Link to comment Share on other sites More sharing options...
M Night Shamalayan Posted August 31, 2016 Share Posted August 31, 2016 holy science that looks fantastic 1 Quote Link to comment Share on other sites More sharing options...
Sparkle Posted August 31, 2016 Author Share Posted August 31, 2016 this just got even more amazing. Well done that man 1 Quote Link to comment Share on other sites More sharing options...
dr.wylde Posted September 1, 2016 Share Posted September 1, 2016 phwoar! looking goodmayte 1 Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 1, 2016 Share Posted September 1, 2016 mate. 1 Quote Link to comment Share on other sites More sharing options...
Jorden Posted September 4, 2016 Share Posted September 4, 2016 cheers guys What do we reckon, scoop or stacks? i reckon stacks 4 Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted September 4, 2016 Share Posted September 4, 2016 cheers guys What do we reckon, scoop or stacks? i reckon stacks Stacks all the way 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 5, 2016 Share Posted September 5, 2016 concur, stacks by far Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 5, 2016 Share Posted September 5, 2016 Stacks.. they make me wanna jizz my pants, that and I plan to stack my xc one day.. stacks Quote Link to comment Share on other sites More sharing options...
Jorden Posted September 21, 2016 Share Posted September 21, 2016 Well... Was getting the 351 ready to drop off to the engine builders (302 in car at the moment) thought I'd double check the stroke and, 3 inches, so it's only a 302. The 351 and fmx I bought off here turned out to only be a 302 and c4 (wasn't worried about box) oh well what can ya do. Slows things down abit, going to have to find a new engine and flick that one on Quote Link to comment Share on other sites More sharing options...
