Jorden
Everything posted by Jorden
  1. Jorden
    PAINT THREAD
    2000 is fine for sure, if RJP is open they sell a 3000 thin finishing pad that goes on a DA and preps well for cutting
  2. Cheers Chris appreciate it, will be ringing up as soon as we are free again
  3. removed the factory radio because I can't hear it over the exhaust anyway and installed the three gauges, water temp, oil press, oil temp. Still need to find a place to mount fuel pressure
  4. recommendations for a dyno tuner/carb guy to get this thing to its full potential? i am in CHCH.
  5. Got it all fired up and running, it sounds amazing. XR292r cam Lift 0.621 / 0.627 in, Duration 292 / 298, it has vic jr heads i have played around with, a super vic intake and an 850 pro systems carb. Ive got a moroso 7q pan and a melling hv pump in it. In the second photo you can see a clear line heading into the drivers door, this is connected to the trans and used to set up the line pressure for the AOD trans. I spent a good amount of time running it in, and have only in the last week changed that oil for some fresh stuff. It runs really well, but i need a new valvebody for the trans, as the shift pattern is 1 D OD meaning i cant hold second gear. With a 3.25 rear end it sits at 100km @ 2100RPM in overdrive haha, im thinking of going to a 3.9 ratio. From take off it has a bit of a flat spot, i dont have an AFR gauge so dont want to play around with it too much, if anyone knows a good dyno tuner/carb guy in chch please let me know in the discussion thread! Would be much appreciated. God i would love a sprintcar style air cleaner on it aswell, the single stack is only on there because its all ive got I also installed an oil cooler as temps were getting too high, its quite a small one and has given me an interesting problem. At cold idle it has 40psi, and at hot idle as its able to flow through it better, it has 50 psi i think ill have to get a bigger one anyway as temps climb too quick after a decent pull, ive heard shorter plates but more of are better than a few long plates for flow. of oil. Such a shame, i managed to get her all ready for the wedding to be cancelled, makes me a bit bummed that i rushed a lot of stuff together and now have to re do things, but i can definitely say, without the motivation the wedding gave me, the car would probably still be sitting in primer right now
  6. I had a couple of mates come over to help put the steering box, brake booster and then motor and trans in. Everything went together fairly easily. Before i painted the car i split the factory looms that usually ran across the firewall, extended them and ran them along the crossmemeber and under the guards etc to hide them. youll also notice the extra bumper.... strength in the first photo When i first bought the motor it was dry sumped, i fucked that off because i didnt really need it and went to wet sump. The block doesnt have provisions for a spin on filter, so im running a remote System 1 filter you can see on the passenger side.
  7. i had the car running with that motor, and before the kaikoura hop i went to do an oil change and found a lot of bearing in the oil. It all got pulled out, rebuilt, and then i lost a lot of motivation to put it all back together. January this year, my friend asked if we could get it ready for his wedding in april, i said yea why not. Here are photos of the panel process, i couldnt find the exact factory blue, so decided on a colour with a bit more of a pop to it. I decided to do the engine bay and door jams all at the same time. Came out alright, it was my second time playing with BC/CC and was lucky enough to get to paint it at work. Most of the car was straight anyway, i had to get the rear window removed to attack some rust, the rest happened really quickly.
  8. Negative Whatever is going to get the most out of the engine
  9. Yea I should be able to fit 3.5" under there, the headers sit fairly low so it'll sit above the level of those, and I can tuck it in the tunnel a bit. So 3" at worst, 3.5 is better, and if I could fit 4" would that be the best?
  10. Different I'm pretty sure mate, mainly found in mustangs, broncos etc American stuff, but I could be wrong
  11. Painted the 9inch blue and put it in And then this weekend after the new trans and headers showed up, i decided to chuck it in and test fit everything. I went for an AOD trans so i got overdrive, and i should be able to run a higher diff ratio while keeping cruising speeds down. Its a pretty tough built one i got from a shop up north. The headers are Hurricane, and completely fowl the steering box so ill have to modify them at work. Our car hoist also serves as an engine hoist. After these photos i mounted the rad, oil cooler, oil filter and fuel pump, its gonna be a busy engine bay!
  12. I'm about to build the exhaust for my new v8. It is a 393, at a guestimate 550 hp at the crank. I have to run a single system in the xf as the fuel tank gets in the way on the passengers side. It'll just be running through one flowmaster super 44. I have twin 3" collectors, what size system is going to be best?
  13. Enford be worth a try aswell, got a full set of bushes for my Anglia off them
  14. thoughts on the new combination team Would love to keep the stacks somehow, ill find a tunnel ram for it one day Got to buy headers and a carb for it, Thinking a mechanical secondary 850cfm, what do you guys reckon? Its a 393 that should have around 550hp
  15. this is what she ended up looking like as i drove it round for 6 or so months, Untill all of the oil decided to exit via the dipstick So i searched for ages for a replacement, and found a 393 windsor that a few of you may have seen on trademe. Its a ford motorsport block with 4 bolt mains, edelbrock alloy heads, scat crank rods pistons, super victor intake and is dry sumped. Came with all lines, tank and pump etc. I also bough an LSD 9 Inch off the same guy. Should be good for about 550hp, Have started taking it apart to re paint the block and check over everything, such a cool pulley setup on the front. .
  16. where you getting your information from mate? Seems interesting that 90% of the modified anglia scene in the UK swap this exact engine in, now, if theyre so shit why would they do that? The car has less than 100thou kms on it and is absolutely fine. This site never ceases to amaze me. Swap will be going ahead
  17. Well... Was getting the 351 ready to drop off to the engine builders (302 in car at the moment) thought I'd double check the stroke and, 3 inches, so it's only a 302. The 351 and fmx I bought off here turned out to only be a 302 and c4 (wasn't worried about box) oh well what can ya do. Slows things down abit, going to have to find a new engine and flick that one on
  18. cheers guys What do we reckon, scoop or stacks? i reckon stacks
  19. Had a couple of bits show up over the past week or so, new ready to run dizzy, leads, tunnel ram, twin 450 Holleys and a linkage kit Sat everything in place and cut the bonnet, only had to cut it once which was a relief. Working on installing the dizzy and cutting leads to length now. Tomorrow ill get the ram sand blasted and paint it black, the spacers are already black and i think ill paint the carbs black too. working on getting a paintjob, really want to get it straight and tidy, within the next couple of months hopefully Aiming to cruise her to kaikoura hop, 15th sept!!
  20. So heres a run down of the conversion now that ive sorted out all of the issues that came up, this is how i did it V8 Base plates Original trans crossmember with tag welded on the front as the c4 mounting bolts are further forward Inhibitor switch is different, this needed to be changed Used the original accelerator cable Cut the heater pipes at the firewall and welded some 90 degree bends on so i can still use the heater Speedo drive/gear is different and simply needed to be switched over by taking the small clip out Trans lines need to be fed down the other side of the car as they are on the other side of the trans, also means i needed to flip the cooler over and move it to the other side of the car the original power steer lines ended up very close to the headers so i cut the ends off mine and got them fitted to another line so i could run them elsewhere The fuel line needed to be pushed back out of the original hole and ran down outside of the engine bay and popped back in infront of the shock tower The shifter for the trans is on the opposite side of the original one, so to keep the column auto shift i used a cable Custom exhaust dual 2.5" with single coby louvred/baffled hotdog on each side sounds very nice but very loud Maybe a few other things but thats all i remember for now
  21. Big things happening, stay tuned
  22. freaked out for a sec there thought i was going to have to take the bastards out again
  23. Last week i priced up a respray and decided to attack all of the rust, dents and scratches. Here it is with the front guards off, the worst rust was underneath them, and you can see half of it sitting on the ground After i fixed the rust i primed and sprayed rubberized underbody spray on the inside of the guards So anyway the guards are back on now, rust has been fixed, the dents and scratches that have been fixed have been primed and there's now only a few little things to do before its ready to be sprayed. [/center] And ive only been pulled up for one random license and breath test
  24. Success! and i only had to buy a whole car to get them
  25. ill more than likely satin black it like the rims, don't worry!
