Kiwibirdman Posted June 11 Share Posted June 11 I am planning to build a box to house a 10in sub and a couple of 6x9 speakers that can go into the luggage area of my EJ Holden wagon. I want to be able to remove the box easily if I ever need to take a lot of junk. Does anyone have a good idea of a 6way plug that I could use. I did think of a trailer plug, but there must be something a bit less agricultural. Quote Link to comment Share on other sites More sharing options...
crash Posted June 11 Share Posted June 11 These are pretty good, they come in male / female and panel mount too. Might be a bit bulky and agricultural for what you want though. Have a look at RS Components too, heaps of options there. 1 Quote Link to comment Share on other sites More sharing options...
datlow Posted June 11 Share Posted June 11 Anderson plug would work maybe a 4 way small for speakers 2 way bigger one for sub https://www.jaycar.co.nz/4-way-shell-for-15a-anderson-connector-with-latch/p/PT4436 (Can’t actually see what this one plugs into unless it’s both M&F) https://www.jaycar.co.nz/anderson-sb50-power-connector-50a-6-gauge-contacts/p/PT4420 They have panel mounts for them too 2 Quote Link to comment Share on other sites More sharing options...
ul9601 Posted June 11 Share Posted June 11 amp staying in the car? Quote Link to comment Share on other sites More sharing options...
ul9601 Posted June 11 Share Posted June 11 4 hours ago, Kiwibirdman said: I am planning to build a box to house a 10in sub and a couple of 6x9 speakers that can go into the luggage area of my EJ Holden wagon. I want to be able to remove the box easily if I ever need to take a lot of junk. Does anyone have a good idea of a 6way plug that I could use. I did think of a trailer plug, but there must be something a bit less agricultural. 3 hours ago, datlow said: Anderson plug would work maybe a 4 way small for speakers 2 way bigger one for sub https://www.jaycar.co.nz/4-way-shell-for-15a-anderson-connector-with-latch/p/PT4436 (Can’t actually see what this one plugs into unless it’s both M&F) https://www.jaycar.co.nz/anderson-sb50-power-connector-50a-6-gauge-contacts/p/PT4420 They have panel mounts for them too I'm doing the same except I want to get the amp out as well. 12" and 8" sub and an amp. Will be using the second jaycar link for the amp power (i bought off amazon, 2 sets of M & F and they come with covers, which would be necessary for power. thinking of using either 1st jaycar link, speakon or deutsch for speaker wires and amp remote on. Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted June 11 Author Share Posted June 11 12 hours ago, ul9601 said: amp staying in the car? Yes it is, the amp will be under the floor, so it is only 6 wires that I have to connect. 1 Quote Link to comment Share on other sites More sharing options...
Bling Posted June 11 Share Posted June 11 Speakers should be easy as not much power, something like this? For that factory look. https://www.jaycar.co.nz/automotive-4-way-plugsocket-250-series/p/PP2066 This could be ideal to cover all 6 wires though. Just plug in as needed, lol /jokes! 1 Quote Link to comment Share on other sites More sharing options...
vk327 Posted June 11 Share Posted June 11 speaker signals something like this DT panel moutn socket ? good fro multiple disconnect cycles https://msel.co.nz/deutsch-dt-8-way-bulk-head-receptacle-kit-with-solid-pins/ sub wires small 50a andersen plug or use the larger deutsch DTP connector https://msel.co.nz/deutsch-dtp-4-way-bulk-head-receptacle-kit-with-solid-pins/ 2 Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted June 11 Author Share Posted June 11 Thanks guys some good ideas. Reality is that the speaker box will probably never get taken out, I want to have the option. Quote Link to comment Share on other sites More sharing options...
Bling Posted June 12 Share Posted June 12 Could just go with normal speaker box connections then? Nice and tidy and not bad time wise for connecting. You'll spend more time clutching your back after lifting the sub box out. I assume they would be fine with car vibrations. Sub (haven't checked rating specs), they tend to have holes in the studs so you can fire a bare wire in and tighten it up. Can't see in this photo if the case or not. https://www.jaycar.co.nz/speaker-box-terminals-with-banana-sockets/p/PT3006 6x9's https://www.jaycar.co.nz/2-way-push-connection-speaker-terminals/p/PT3000 or https://www.jaycar.co.nz/4-way-push-connection-speaker-terminal/p/PT3002 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted June 12 Share Posted June 12 Pretty agricultural but what about one of those trailer plugs that has the anderson plug inbuilt? 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted June 13 Share Posted June 13 On 11/06/2024 at 18:53, datlow said: Anderson plug would work maybe a 4 way small for speakers 2 way bigger one for sub https://www.jaycar.co.nz/4-way-shell-for-15a-anderson-connector-with-latch/p/PT4436 (Can’t actually see what this one plugs into unless it’s both M&F) https://www.jaycar.co.nz/anderson-sb50-power-connector-50a-6-gauge-contacts/p/PT4420 They have panel mounts for them too I used a anderson plug/flush panel mount for my sub box. Works perfect 1 Quote Link to comment Share on other sites More sharing options...
