Steel tank is one of the obvious differences plus the oil injection gear (if there is an oil tank accessed from under seat.
You can always grab the engine number, if it's DX200G***** then it's the road one (DX200E***** would be offroad)
I'll try to find the model recognition pdf's
  • Replies 72
A few things have been happening lately with the KDX. Since I had it sitting in a drawer I fitted an O2 sensor and wideband gauge to see if it will help with tuning my new carb. Manufacturer advice is to locate the sensor on the upper half of the belly of the chamber and to expect a shorter life span. I had a few bungs so put one where it was convenient at the end of the belly.
I hooked it up to the battery pack under the seat, hose clamped the gauge to the bars,  calibrated it then fired it up.
Seems to be doing something and doing it consistently. Current carb needs jetting to suit my exhaust changes but I won't bother with that one yet.
I should have cerakoted the cases and cylinder silver when I had them apart, I could at least do the sidecovers, they are the worst of it at least. Where can you buy it from?
A few bits have arrived so I whipped the carb off.
Some new jets to try
and float bowl, aliexpress special so will see how long it lasts
and some new reeds
  • Like 8
Clean sheet wof, as it should since it was only complied 6 months ago.
I have swapped back to the OG smaller carb for now, I hadn't made much progress with tuning the bigger carb so it was a bit gutless in comparison. I tried a few combos from the KDX jetting database (155ish main, 42 pilot) but it was flat up in the revs.  A previous owner had removed the carb bowl overflow tube so I'll sort that first then try again nearer the end of summer.
The wideband wasn't much help for anything other than idle, expansion chamber magic would have it reading all over the place, don't know if a different spot would give a better reading, some of the 2t snowmobile crowd have them working fine but I can't be bothered trying any further :)
  • Like 8
  • 3 months later...
  • 5 months later...
Quick poll
I have some black fork guards too, what are peoples opinions
Stock
or black (ignore dropnuts in the background there)
