ThePog Posted May 7, 2020 Author Posted May 7, 2020 Just now, anglia4 said: I've had a bit of gear from linearmotion.co.nz when I was at Trinders. Unsure comparatively how it goes against the bank as I never had to pay myself haha I too have spunked quite a lot of other people's money on cool stuff... Quote
EpochNZ Posted May 7, 2020 Posted May 7, 2020 Late to the thread, sorry..... Another contact would be Tony at Atomick Laser in Lower Hutt (www.routercut.co.nz). He has built most of the equipment he runs (2400 by 1200 CNC, 1200 by 1200 3 axis CNC, 2 1200 x 1200 Lasers etc) and is a genuine nice guy to boot. I've looked at that Maslo but I dont know if the accuracy would be there? It relies a lot on the weight of the router to prevent it torquing off all over the place. Quote
ThePog Posted May 7, 2020 Author Posted May 7, 2020 Just now, EpochNZ said: Late to the thread, sorry..... Another contact would be Tony at Atomick Laser in Lower Hutt (www.routercut.co.nz). He has built most of the equipment he runs (2400 by 1200 CNC, 1200 by 1200 3 axis CNC, 2 1200 x 1200 Lasers etc) and is a genuine nice guy to boot. I've looked at that Maslo but I dont know if the accuracy would be there? It relies a lot on the weight of the router to prevent it torquing off all over the place. Cheers, I have just emailed him... Quote
EpochNZ Posted May 7, 2020 Posted May 7, 2020 Just now, ThePog said: Cheers, I have just emailed him... PM'd Quote
JoKer Posted May 7, 2020 Posted May 7, 2020 2 hours ago, ThePog said: What are the rails like? ok here's some pics of My machine : now I'm not saying its the Best machine nor am I an expert It's just what I've got & used and it is OLD as in 1996? Rails the worm screw is the main Drive X axis The Head is in a single sided 'gantry' (probably a proper name for it : I notice todays machines don't have this any more a for accuracy maybe & b for stability) they litterally dont make them like this any more (as seen from the 'back) From the "Front" Rails would be 3m BUT there's 500mm each side supporting the head eg rails extend to here vs the center of the Head / workable area of mine is 2m not sure if that helps at all as yeah single sided and doesnt fit a full sheet (which I will get one day) 1 Quote
ThePog Posted May 8, 2020 Author Posted May 8, 2020 Just now, JoKer said: Yea that is kindof weird, I would have thought the mass of the head would cause some sort of bounce with support only on one side, but I guess the engineers knew what they were doing. Its a real shame it doesnt do a full sheet, there seems to be a big jump in cost to get to that, which I am hoping to avoid. Still you work with what you have as my wife says to me. 1 Quote
JoKer Posted May 8, 2020 Posted May 8, 2020 yea I've been told it is Cast / Heavy & the 7x head tool changer at the back may help balance it bonus is i can hang stuff out the front if I want headaches (not hard : just a pain to do big stuff) 1 Quote
Ned Posted May 8, 2020 Posted May 8, 2020 I got one of the maslow from the first kickstarter batch... Never got it running as everyone was reporting rubbish results and tried converting it to xy and then i found the lowrider and just built that last year Quote
EpochNZ Posted May 8, 2020 Posted May 8, 2020 Just now, Ned said: I got one of the maslow from the first kickstarter batch... Never got it running as everyone was reporting rubbish results and tried converting it to xy and then i found the lowrider and just built that last year What did you receive as part of the kit? From memory you needed to provide your own router? Quote
Ned Posted May 8, 2020 Posted May 8, 2020 I got a reduced kit to save shipping and got just nuts/bolts etc, motors and chains, motor driver, z motor (was optional then) No router. I bought the Bosch POF something or other and modified it to drive itself as the Z axis. It was actually very popular and appear to be the common way to donit now for places that arent the US as they use a different router (110v) Mine was 3d printed at home but some dude got me a baller 3d printed one from straya, and then some dude 5 axis machined me one out of aluminium in the UK. So sweet! Such a shame its not being used hahaha 1 Quote
Stu Posted May 8, 2020 Posted May 8, 2020 Following this with interest! I've got two flat bed routers here at work but have been half heatedly looking to build a smaller 2440x1220 machine for light work (ACM, acrylic and 3mm and under ali). Also interested in the control gear being used - Ive got a Mach4 control system in a box here as a backup for the Icam which is still running the ancient NEE controller which will no doubt grenade at somepoint when its critically required. Quote
ThePog Posted May 8, 2020 Author Posted May 8, 2020 My man who knows says LinuxCNC is the tits, a large range of controllers are supported and a good community forum; http://linuxcnc.org/ Installed in about 1/4 hr on a wee machine I had spare, seems to do what it says on the packet. 1 Quote
EpochNZ Posted May 8, 2020 Posted May 8, 2020 In my mind a CNC Router is "funner" than a laser as you can do real world engineering with them. Grab a sheet of ply and turn out tables, chairs, cupboards, caravan interiors, tiny homes, boats etc. 1 Quote
ThePog Posted May 8, 2020 Author Posted May 8, 2020 I have been wondering about slapping a laser onto it as well, but I imagine the DIY ones would only be good for etching and paper cutting. There are 100w lasers on Ali tho; https://a.aliexpress.com/_dZKA9RJ Be interested to see how thick a bit of steel it would cut... 1 Quote
JoKer Posted May 8, 2020 Posted May 8, 2020 I have a 65w Epilog Laser tucked away (Small engraver 600x400mm bed) only good for 3mm MDF reliably and acrylic (perspex) don't think 100w will cut even thin Aliminuim Quote
h4nd Posted May 8, 2020 Posted May 8, 2020 Crissskes watch your eyeballs. Milliseconds. The fun bit* is that you won't notice at first as the brain fills in little gaps like the one over the optic nerve. Until there's heaps of damage. *Not actually fun. 1 Quote
yetchh Posted May 8, 2020 Posted May 8, 2020 Have you guys seen the shaper origin handheld cnc router? Pretty cool, think its pretty pricey tho £2500 Even better the springa goliath... 1 Quote
ThePog Posted May 8, 2020 Author Posted May 8, 2020 I remembered I had a whole lot of this stuff stashed away; Igus WS rail. I don't have much of the rail itself, but I have heaps of the carriages, enough for 4x sets of 4 which is the usual configuration for this stuff. The rail is hard anodised and the blocks have a plastic insert. They are a cunt to get all lined up nicely without jamming but have no backlash once in place. That's 40mm rail, but you can get 80mm as well which looks about right on the cad model. I've sent an enquiry away, we'll see what pricing is like. 2 Quote
JoKer Posted May 9, 2020 Posted May 9, 2020 there's also this machinery clearance just poped up in my "feed" Quote
Popular Post ThePog Posted May 14, 2020 Author Popular Post Posted May 14, 2020 Some things have arrived... 10 Quote
