Sign in to follow this
Ashkellybarr
Ash 85 crumpy yarns
Yeah that things awesome!
not much to be honest
ive picked up a 5sp box to replace the 4sp.
Just tidy it up and daily it. Do the under body, maybe see if EFS do new leafs and shocks for it.
missing some bits and bobs so I’ll put up a list soon
Share this post
Link to post
Completely understand how you feel bout this
I’m the same with mine
mines rough though and diesel and slow as hell
should prolly do a build thread for it
Share this post
Link to post
Yeah mines gutless as well, but tbh I went out to muriwai today with a mate and his mate.
actually held up pretty well.
Mates terrano diesel turbo and a td42 saf with serious turbo and suspension setup.
had a drag race and I had the jump on them until 60kph.
loghtweight and A/T’s worked pretty well on the harder sand.
hit the dunes and did a couple climbs, defiantly down or torque but I was actually surprised what the 33yr olds single cam, single carb  thing could do.
did a scrap metal run the other week and got it on the scales. Mates rodeo was 2 ton.
the crumpy was bang on 1500kg with tools and the diy angle iron tray.
thinking with an alloy motor and alloy half tray it could get down to 1400, witch isn’t bad for a daily 4wd that with a bit more grunt would be reasonably capable
Share this post
Link to post
Quote
when straight to BNT off Lincoln where the hotty behind the counter sorted me out.
Always a good day when she doing the deliveries
  • Haha 1
Share this post
Link to post
C clips in the free wheel hubs?
Don't Chuck the old ones, make sure the ones with holes clear the sliding part of the freewheel hub.
Need some like these with a flat endvacuum_grip_70a_pliers_lockring_48_f_cropped_inset2_w560_h309.jpg.8cd3c9398846c17e9b23baf55fc08867.jpg
Share this post
Link to post
Cheers will double check that! And defiantly the right tool for the job! I asked some mates if they had any like that but no luck.
ended up using my rounded ones, but holding a flat head against one side of the clip with the side of my hand so it opened more on the other side.
while levering the screw driver and holding the c clip plyers in one hand I got a flat head in the other hand to try hook under the lifted side.
lots of cursing as you could imagine
Share this post
Link to post
front an rear diff heads are the same in these things.  front is just a rear  running backwards.  so yeh  any rear head or center will fit front.   cv's are weakest part
Share this post
Link to post
Awesome cheers kris! Will keep an eye for another LSD.
my thoughts were to look out for a half decent LSD for the rear then swap the sloppy factory one in the front. Maybe shim it back to factory spec but nothing to fancy, just enough to help off road.
Share this post
Link to post
I have a set in Papakura. Too late?
Share this post
Link to post
