Ghostchips Posted December 7, 2017 Share Posted December 7, 2017 i have an autsin diff but BDAkarl or whatever his name was wanted it. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 7, 2017 Author Share Posted December 7, 2017 if he dosnt want it I will buy it, 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 11, 2017 Author Share Posted December 11, 2017 I filled the diff with semi fluid, I am sure thats what it should of had and not oil, its nice and smooth and quite now. Quote Link to comment Share on other sites More sharing options...
Popular Post SOHC Posted December 20, 2017 Author Popular Post Share Posted December 20, 2017 I have a big K341 motor, its physically the same size as the 14 HP but has a bigger bore, they are hard to find, mine had some damaged I needed to fix, I have a new rod, I jusr need a +10 piston and get it rebored and the crank ground. 10 Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 3, 2018 Author Share Posted January 3, 2018 I found another crack in that 341 block and I cannot be fucked with it anymore I am going to rebuild the K321 witch is in the tractor, I whipped it out and pulled the head off to confirm bore size and broke one head bolt in my haste witch I now have to drill out, crank shaft is rooted, someone snapped the threaded end off for the flywheel and arc welded a new one back on but I have another crank, and I would machine it off and drill and tap it for a bolt if I didn't, Still kind of in two minds about building up the 16hp, but I think the 14hp will be a better motor and ether way I can make one out of the 2 but its going to cost some money. Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 11, 2018 Author Share Posted January 11, 2018 I took the orinagle K321 motor from the tractor apart, and ordered a new piston and gasket set, valves and guides, governor gear, and main bearings, I have a new rod to, I chucked the balance gears in the scrap bin like everyone recommended, most motors they have already been ditched, I made a new exhaust pipe as the old one consisted of plumbing fittings and a Mondau muffler, got the old Coby off my Volvo to make a stack exhaust. I will get the block bored and the crank ground when the parts get to nz, stator for the charging system is bad I think but I have another one from the 341, I gave it a bit of a port job, smoothed out the inlet port, it had two big steps witch I smoothed out, and I smoothed the eyebrows round the valves a little, I got rid of the exhaust stub witch screwed into the port and made it about a 1" hole and made a bolt on flange. Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 17, 2018 Author Share Posted January 17, 2018 1 Quote Link to comment Share on other sites More sharing options...
Popular Post SOHC Posted January 17, 2018 Author Popular Post Share Posted January 17, 2018 Someone here sed I must make a stack with a flap a wile ago. I spent about 2 hours making a rain flap then found they are only $11.00 but I gess I would spend 2 hours going to get it, I bet it will just fume me wile I am driving? 12 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted January 18, 2018 Share Posted January 18, 2018 Stacks are awesome, until you roll down hills, puhuhuhu. Quote Link to comment Share on other sites More sharing options...
Mof Posted January 18, 2018 Share Posted January 18, 2018 Have you got enough counterweight to give a nice ting-ting-ting at idle? 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 28, 2018 Author Share Posted January 28, 2018 Block is away being bored and new guides fitted and crank ground, I wont see it for a wile as I am sure they will take there time. Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 28, 2018 Author Share Posted February 28, 2018 Didn't really take any photos but its all back together, did two heat cycles on the engine today, it would be all done but I need 2 grub screws to hold the front pulley on, engine dosnt clatter or smoke like it use to, I got rid of the counter balance gears in the motor as they are shit and time bombs. Also made a trailer, I need one of those hitches for it tho. Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 28, 2018 Author Share Posted February 28, 2018 New valves and bored +10 thou & block decked 7 Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 28, 2018 Share Posted February 28, 2018 Will it do a skid? 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 28, 2018 Author Share Posted February 28, 2018 14 hours ago, Nominal said: Will it do a skid? if you somehow prevent it from moving like chaining it to something it would, it will climb a tree otherwise Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 28, 2018 Author Share Posted February 28, 2018 I have lots of new and used Kohler engine parts if anyone needs, especially ring sets and rods, I have stacks of them. Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 3, 2018 Author Share Posted March 3, 2018 6 Quote Link to comment Share on other sites More sharing options...
Mof Posted March 3, 2018 Share Posted March 3, 2018 Needs a mini plow to tow behind it 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 4, 2018 Author Share Posted March 4, 2018 On 3/3/2018 at 17:48, Mof said: Needs a mini plow to tow behind it I just built a mini trailer for it but I need a hitch to complete it, I will get some photos tommrow. I have an old single furrow plow that I found that could be made to fit but I have no use for one, I need to make something to get rid of the hump with develops in the middle of our driveway Quote Link to comment Share on other sites More sharing options...
Mof Posted March 4, 2018 Share Posted March 4, 2018 A row of furrow plows And a finger wheel rake 3 Quote Link to comment Share on other sites More sharing options...
