SOHC Posted October 22, 2018 Author Share Posted October 22, 2018 Needs a heat sink on the rectifier, it gets very hot, they assured me it would only get warm, also I got replacement belts they had the same numbers as the old ones but are too small, I had the same problem with the belt for the hydrolic pump, I think its the brand, I didn't have this problem with PIX belts. Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 30, 2018 Author Share Posted October 30, 2018 7 Quote Link to comment Share on other sites More sharing options...
SOHC Posted June 19, 2019 Author Share Posted June 19, 2019 Seriously thinking about selling this to fund mechine work on my ford engine, not sure what it’s worth? Small tractors seem to go for a lot I gess it’s worth more that $1500? 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 7, 2019 Author Share Posted September 7, 2019 Dragged some pine logs from a tree that fell down, if you get stuck this thing digs holes till it’s down to the diff in the ground. 7 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 7, 2019 Author Share Posted September 7, 2019 7 Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted September 7, 2019 Share Posted September 7, 2019 Neat, whats it like running the rotary hoe? I wanna hear it loaded up working. Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 7, 2019 Author Share Posted September 7, 2019 30 minutes ago, johnnyfive said: Neat, whats it like running the rotary hoe? I wanna hear it loaded up working. The jockey wheel for the depth of the rotary hoe is missing so I cannot use it well or it goes to max depth, it would be easy enough to make. Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 7, 2019 Author Share Posted September 7, 2019 Also today the horn jammed on, it has never worked, the button dosnt even move but I had to drive past people with it blasting away like some arsehole. 4 4 1 Quote Link to comment Share on other sites More sharing options...
