Popular Post Datsun280z Posted February 9, 2017 Popular Post Share Posted February 9, 2017 Dont think this car is old enough for the main forum, 1989??? So I decided to get another project to muck around with to stop me pulling things apart on the 280Z plus Craig is building lots of cool shit and I am jealous. Requirements were it had to be Nissan, be cheap, have 4 seats (the 280Z is not overly family friendly) and be cheap. I have always liked the old Z32 300zx's so decided to go down that path, they are a love it or hate it car but Im cool with that. Upsides of the Z32 are obviously you can pick them up for next to nothing these days, there are lots of spare parts available for them and they are quite a lot of car for the money. The downside is they are are a bitch to work on due to engine layout/space restrictions, you have to pull the engine to change the washer fluid. Plan for this thing is just a fun budget build, use cheap or second hand parts where possible, take to the odd track day and drive it. So knowing it was probably a stupid idea i started looking around and found cheap semi tidy 2+2 NA manual in Christchurch. So site unseen, Craig and I jumped on a plane flew down, met the guy at the airport, dropped some cash on the thing and road tripped it back to Aucks which was mint. When we picked it up Mean trip home The car has over 200K Kms on it and leaked oil from every seal imaginable, interior was filthy and it had an horrific pitstop special exhaust system that was stupidly loud and totally shit. Good points were body was fairly tidy, came on some rough 18x9.5s, gearbox felt ok and car drove pretty sweet. At home with the 280 When i got it home the first thing that needed attention was the bio-hazard of an interior. It was disgusting, the drivers seat was torn and the dash was lifting around the windscreen air vent which I believe is fairly common. Every old 300zx has a torn drivers seat which looks crap, i wanted to keep the seats as they are cool 90s retro with motors in them so decided to re skin the drivers seat. I found a tidy passenger seat online then proceeded to strip it down and swap the skin over to the original drivers seat. This was a mission that took forever, I dont recommend. Spare passenger seat I found after ripping it to pieces lots of scrubbing out years of filth, ended up with two fairly tidy seats with no rips etc. They are still wet in this pic One non torn drivers seat back in the car Rest of the interior got a full on scrub down, it was unreal how much crud came out of everything. I also pulled out the dash and glued down the area that was lifting around the air vent. Another job I did was to tidy up the vinyl trim on the rear quarter panel interior trims that were torn. Next job was address the ride height. The car was rocking full on 4x4 spec stock suspension which had to go. Cheapest option I found was some dodgy ebay style coil overs, yep they are probably made from recycled watties baked bean cans but they were cheap so they were in. Threw them in and adjusted height to something that looked more respectable There is still scope to go lower but looks better for now The car came on a set of 18x9.5 +15ET china spec Cosmis wheels. They were were in a pretty sad state with some curbing and stone chips etc. In an ideal world I should replace them with something decent but thats not happening so decided to tidy them up as best I could. You have to be a mogul when you are racing modern...WTF Spent a fair but of time sanding down all the chips and marks. Then sprayed gloss black to hide the evidence. They look 100 times better than they did so they are staying for now. Need to change the wheel nuts to something non chrome Old mate Craig had a super legit set of Defi gauges gathering dust on his shelf so i stole them, hacked up the center console and made them fit. Gauges are worth more than the whole car, cheers bro! Next thing to address is the engine. The tired VG30DE had to go, it was leaking oil real bad and is slow. I had initially thought of throwing in a RB25 for something different but by chance ended up getting hold of a supposedly low km VG30DETT twin turbo motor for super cheap from the Mrs uncle who randomly had it sitting around in his shed. Fitting a VG30DETT into a NA Z32 is meant to be relatively straight forward, you can use the NA loom etc. My car is factory manual, the NA and TT gearbox internals are identical but the TT version has a slightly larger bell housing, the internet told me it should all fit somehow... The turbo engine had been sitting in his shed for years so was looking a little worse for wear. It turned over freely so figured I would take a chance on it. This was how it looked when i got it home. I also tracked down a complete stock intercooler plumbing kit I gave it a good de-grease and waterblast then started stripping things off to tidy it up a bit. I didnt know anything about VGs so was going to be interesting. I ordered a timing belt kit, water pump and rocker cover gasket kit from the states. Then proceeded to pull things off, clean, sand, prime, paint, refit, repeat... Fitted new timing belt, idlers, water pump, thermostat etc Painted up the timing covers so they look a but different, every VG i have seen has the stock black covers. The stock T25 turbos looked in fairly good condition, no large amounts of shaft play and rotated nice and freely I ordered a set of dump pipes from ebay in the states, they were ridiculously cheap and seem OK. Painted the water inlet and outlet pipes black just to mix things up from the normal alloy finish most are Pulled the injectors and replaced the o-rings and pintle caps Painted the fuel rail gloss black Nissan engineers were on acid back in the 90s and decided to try and include lots of crazy technology into the VG engine. The engine has an exhaust recycling system to reduce emissions on startup. It is known to fail over time so I deleted it and welded up the pipe on the manifold. I also removed the PCV plumbing and welded up the ports on the rocker cover. I will be using an external oil breather tank. I also deleted all the additional water cooling lines that run under the plenum. Again these apparently begin to leak over time and arent needed. I stripped down and painted the plenum exoxy gloss black to match the rest of the engine colors. Also painted up the heat shields and other small bits, waste of time really as you will never see any of it. The factory NA engine mounts from my old engine were shot, they had cracked right through. I found some cheap nolathane ones online, I made some alloy heat shields for them as some threads online said the nolathane mounts can fail due to heat. Also replaced the rear main seal while everything was apart I reused the flywheel from the old NA engine, it is smaller than the one that comes with the TT motor but it fits with my gearbox so had no option there. NA VGs use the same clutch layout as RBs so I fitted a heavy duty Clutch Industries RB25DET clutch. Out came the tired old DE, getting at some of the plugs was a real bitch. You really need to be the size of a leprechaun to work on these engines. removed the gearbox and its 20+ years of grime Used degreaser and oven cleaner to clean it up as best I could Engine and gearbox mated up, ready to go in car In goes the DETT Boom Factory twin turbo cars have a stock external oil cooler, NA versions dont so raided Craigs parts bin again. Added a few AN fittings and sorted. I was going to used the stock intecoolers that I scored but ended up buying a dirt cheap ebay split front mount cooler for some stupid reason. I think it is a copy of the Greddy version? It is a tight fit, had to cut away some of the plastic bumper support to make room Then I made up a set of cooler pipes to fit by cutting up the stock ones I had, combined with some silicone joiners it worked out pretty sweet My car came with a china spec Greddy copy twin mushroom intake pipe I needed to fit an oil breather tank somewhere in the engine bay so decided to run with a small batter setup and combine that with a breather. Knocked up with this disaster Painted up and installed Will do the job Next job was to make up an exhaust. The dump pipes i bought off ebay included mid pipes so i was one third of the way there. Picked up a bunch of 2.5 inch bends and mufflers etc Started piecing it all together, just tacked in place to suss out the layout Went with a crossover section and two small mid resonators Once i had the layout sorted welded it all up and painted. Fitted the NA loom up to the motor. Some of the old coil plugs were broken so replaced them with new ones. I had to relocate the lower radiator mounts as the TT radiator is narrower and thicker than the NA version. I had one small issue with one of the loom grounds resulting in no power to the coils but once I sorted that the engine fired up nicely which was awesome. Used a consult cable to make sure everything was working as it should. Adjusted CAS to match engine timing to ecu timing. Oil pressure seems good, temp OK and idles nice and smooth so fingers crossed. I am waiting on a few small parts to arrive, alloy radiator as the factory one I have is a bit sketchy, factory fan shroud and radiator top mounting brackets. I have taken for a few drives up and down the road an everything seems OK so far. Car is only on wastegate boost at this stage (7psi) but I have a profec boost controller installed so will have a play with that and turn it up a bit. Washed it for the first time in forever, was such a mint weekend 280 got a clean also Next step is tidy a few small things and get a new warrant for it. Then I will fit a wide band to it and may have a play with the ECU using Nistune software or romulator. I will need to upgrade the injectors at some stage and it will need a bigger fuel pump also. Fun times 34 Quote Link to comment Share on other sites More sharing options...
~Slideways~ Posted February 9, 2017 Share Posted February 9, 2017 This is cool, totally a project I want to have. Was thinking of doing something stupid like a 4 cylinder turbo, just because. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted February 10, 2017 Share Posted February 10, 2017 Would it be rude to ask what kind of $$$ a non turbo manual one of these sells for now days? I have heard they're a bit tight to work on too. Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted February 10, 2017 Share Posted February 10, 2017 Some much awesome! Always wanted one since I was taken for a hoon in one in the late 90's. So rad. Edit: there's a V8 one that cruises the North Shore IIRC. 1 Quote Link to comment Share on other sites More sharing options...
Datsun280z Posted February 10, 2017 Author Share Posted February 10, 2017 8 hours ago, RUNAMUCK said: Would it be rude to ask what kind of $$$ a non turbo manual one of these sells for now days? I have heard they're a bit tight to work on too. They are around the 4 to 5K mark mate depending on condition etc. Yea engine bay is cosy alright but not all that hard really. 1 Quote Link to comment Share on other sites More sharing options...
Datsun280z Posted February 10, 2017 Author Share Posted February 10, 2017 15 hours ago, ~Slideways~ said: This is cool, totally a project I want to have. Was thinking of doing something stupid like a 4 cylinder turbo, just because. They are a really nice car to drive, good bang for buck i reckon. Quote Link to comment Share on other sites More sharing options...
sheepers Posted February 10, 2017 Share Posted February 10, 2017 Super great detailing as always. great job man! Quote Link to comment Share on other sites More sharing options...
Datsun280z Posted February 11, 2017 Author Share Posted February 11, 2017 7 hours ago, sheepers said: Super great detailing as always. great job man! Cheers bro! Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 11, 2017 Share Posted February 11, 2017 Wait a minute.. do you have two batteries in there? Quote Link to comment Share on other sites More sharing options...
Datsun280z Posted February 12, 2017 Author Share Posted February 12, 2017 21 hours ago, flyingbrick said: Wait a minute.. do you have two batteries in there? Yea two small sealed 12v batteries in parallel. Craig hooks me up with them for the sharp price of free. I run two in the 280 also. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 12, 2017 Share Posted February 12, 2017 Awesome! Have been googling stuff like this recently (because for some reason I never do things the easy way) Can ya tell me what they are? Quote Link to comment Share on other sites More sharing options...
Muncie Posted February 12, 2017 Share Posted February 12, 2017 I had a TT Z32 11 years ago bought it with a blown auto box no one wanted to work on it so bought tools and a box out of a Nissan cima and threw it in. Tight to work on but not that bad. There's a guy on the nz 300zx forum's who writes chips for them that are real good mine with a single 3.5" exhaust sat at 12 psi with no boost control and was utterly lethal. Great work great car. 2 Quote Link to comment Share on other sites More sharing options...
Datsun280z Posted February 12, 2017 Author Share Posted February 12, 2017 3 hours ago, flyingbrick said: Awesome! Have been googling stuff like this recently (because for some reason I never do things the easy way) Can ya tell me what they are? these guys bro https://www.osibatteries.com/p-1002-enersys-genesis-pure-lead-g12v16ah10epx-0769-2003-g16epx-battery-16ah.aspx Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 12, 2017 Share Posted February 12, 2017 I wonder what amps they can output for cranking .. anyway, cheers! Quote Link to comment Share on other sites More sharing options...
srf Posted February 12, 2017 Share Posted February 12, 2017 Should be same specs as this. http://www.odysseybatteries.com/batteries/pc680_series.htm Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted February 14, 2017 Share Posted February 14, 2017 On Friday, February 10, 2017 at 17:45, RUNAMUCK said: Would it be rude to ask what kind of $$$ a non turbo manual one of these sells for now days? I have heard they're a bit tight to work on too. Workmate picked up an NA auto for $700 the other week, be a good base for a turbo/manual swap, if pedal boxes are easy enough to find. 1 Quote Link to comment Share on other sites More sharing options...
1963 AP5 Posted February 14, 2017 Share Posted February 14, 2017 If anybody is interested I know where there is a N/A 2+0 car just sitting with rego on hold. It used to be mine and I have considered offering to buy it a couple of times but can't really justify it. It is a real shame to see it just sitting in a driveway unused as it was a real nice car not that long ago as you can see from the photo. If anybody is interested in saving it I can let you know where to find it. Its in the Auckland area. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 15, 2017 Share Posted February 15, 2017 What do you think it's worth? Quote Link to comment Share on other sites More sharing options...
1963 AP5 Posted February 15, 2017 Share Posted February 15, 2017 Pretty sure you could get it cheap. Bit of a sad story on this car it was actually stolen from my garage and the dirty rats who took it did some damage to the interior and took the nice wheels etc. At the time I foolishly took the cash from the insurance company and let the car go. The chap that has it now purchased it from the insurance company and I understand he has another 2+0 donor car with all the required interior parts but he has never done anything with it. It hasn't been officially on the road for ages but I understand the rego is on hold and it's still a runner so could and should be saved. PM me if you would like more info and I would be happy to go and knock on his door as I drive past it most days. I would be very happy to see this car find a good home. Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 15, 2017 Share Posted February 15, 2017 Man, if I was closer I'd get the 2-seater for sure. Seems like a good option so long as the reg is still on hold. 1 Quote Link to comment Share on other sites More sharing options...
