thegreatestben Posted June 25, 2016 Posted June 25, 2016 I bought a china special CDI like that for a china special scooter and it was shithouse. Went back to stock CDI, all problems sorted. Might be worth a go if you have another CDI. 1 Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 Yeah I think you could be correct. I can't think of anything else to check. How universal are these CDI units I wonder. Will need to try source one. Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 The volts are a little high even with regulator screencast Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 Anyone have a 5 or 6 wire CDI i could borrow for a few hours to determine if mines a dud? Quote
Hayholes mum Posted June 25, 2016 Posted June 25, 2016 Is your fuel situation all good? How dirty is your fuel tank? Do you have a filter? Is it blocked with tank rust? Are your jets full of rusty muck? Could be clogged up jets... happens all the time wuth old fuel tanks and causes running issues that feel like electrical problems, super fune rust particles get past the filter and build up in the carb. Quote
Hayholes mum Posted June 25, 2016 Posted June 25, 2016 I had the same high voltage problem on my GL145 motor... fucked around for ages trying to fix it, in the end i put one of those big honda type 6 wire regulator/ rectifiers on... sorted the problem instantly. This is also whats on mathers engine and it pumps out a smooth 12.8 volts 1 Quote
Hayholes mum Posted June 25, 2016 Posted June 25, 2016 Try another battery too, remember that if you have a dead cell it wont dump the excess viltage to earth and will give you high voltage. Quote
Hayholes mum Posted June 25, 2016 Posted June 25, 2016 Fuck, ive done 3 posts, why not add another.... mathers bike is exactly the same engine, if you wanna come over and do some parts elimination you can do that. Is your intake manifold sealed properly? Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 Is your fuel situation all good? How dirty is your fuel tank? Do you have a filter? Is it blocked with tank rust? Are your jets full of rusty muck? Could be clogged up jets... happens all the time wuth old fuel tanks and causes running issues that feel like electrical problems, super fune rust particles get past the filter and build up in the carb. Good point. It is a clean tank but who knows what's in the bottom that's I can't see will remove carb now. Flip I have a filter in stock too didn't think of fitting it. Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 I had the same high voltage problem on my GL145 motor... fucked around for ages trying to fix it, in the end i put one of those big honda type 6 wire regulator/ rectifiers on... sorted the problem instantly. This is also whats on mathers engine and it pumps out a smooth 12.8 volts OK I will see what other regs I have in stove. This is one of those bigger flat ones fitted at the moment. Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 Try another battery too, remember that if you have a dead cell it wont dump the excess viltage to earth and will give you high voltage. Battery is new from Boyals but it's a 3mah one dono if to small but gets hot so need Voltage dropped on it I guess or it won't last long Quote
My name is Russell Posted June 25, 2016 Author Posted June 25, 2016 Fuck, ive done 3 posts, why not add another.... mathers bike is exactly the same engine, if you wanna come over and do some parts elimination you can do that. Is your intake manifold sealed properly? Thanks for the 3 posts and now the 4th, you are such a caring mum. Yup tested intake seal. Quote
My name is Russell Posted June 27, 2016 Author Posted June 27, 2016 Mega Mega fail of a weekend to the power of 1000. Spent all of Sat and Sun trying to eliminate this miss. Waiting on a replacement CDI that hopefully arrives el pronto for the weekends trip. Huge thanks too Hayholes mum for spending her Sunday helping out, what a women! She did find a critical error with my fuel tank having junk in it so that eliminated one issue. Quote
My name is Russell Posted June 28, 2016 Author Posted June 28, 2016 Fingers mega crossed that the CDI due to arrive tomorrow fix's my engine issues. Thought in the meantime I would tie up some loose ends. image hosting over 5mb free screen capture And a waterproof bag for tent, sleeping bag etc gif image hosting 2nd LED headlight fitted windows 7 print screen free image host Not as good as Hayhole or his mums, but made a small bash guard from a stainless steel strokers hardware door pusher plate, some more work still to go on this if i get a chance. free photo hosting 3 Quote
My name is Russell Posted June 29, 2016 Author Posted June 29, 2016 BUGGER IT Replacement CDI did not change anything It goes so well it first and second gear, then half way through the 3rd gear rev range its just cutting out and will ride along cutting out indefinitely. Going to check; Gearing ratio Remove side cover and check timing marks line up Look at the float bowl level Add Manifold gasket seal Redo all connections Any other ideas? Quote
Chris.QCR Posted June 29, 2016 Posted June 29, 2016 Clean your jets out. If the tank was full of shit there is every bit chance some shit is in there. Cant imagine gearing ratio is that different. And yeah check timing. If all failw take the mega reliable always cooler two stroke !!! 1 Quote
Flauski Posted June 29, 2016 Posted June 29, 2016 I concur with Chris, it won't be gear ratio. Gotta be either carb or electrical. Fuel is easiest to sort so check it all out first. Something as simple as partially blocked carb jets or a lose earth connection can cause same symptoms. Don't know what sort of carbs those Chonda Chinese knock offs have but if its a knock off carb as well - throw it in the bin. The engine doesn't matter so much but the carb does, very very fine tolerances and decent manufacturing are a must for carbs. Ask anyone who has bought / tried to use a cheap knock off carb and you will never hear anything good to say about them. 1 Quote
Seedy Al Posted June 29, 2016 Posted June 29, 2016 Does your fuel tank have a vent in the cap? as in, is the fuel able to flow freely down to your carb, with the fuel cap on? 2 Quote
My name is Russell Posted June 29, 2016 Author Posted June 29, 2016 OK the bikes running like a charm now. As I'm typing this I'm touching all the wood I can find. . . And timber. We fitted a smaller front sprocket at watermark and it ran bether tHan ever. Came home happy as had dinner then thought I better test it on the hill and fuck it. It's back. Soldered all the joins again. Removed chode air filter. And cleaned carb for the zilinth time. Just returned from a Mt Brooklyn roadtrip and everything seems all groovy. Will give it a red rocks fang tomorrow. I'm wondering if the air filter was choking it. Super short type. Thanks for the above adice oldschool and Hayholes mum Quote
BlownCorona Posted June 29, 2016 Posted June 29, 2016 certainly sounds like an intake choke with it only really acting up on high load situations. had similar issues with a scooter not reving out properly and it was because the carb had a pipe on it that didn't have a bell mouth intake and at higher rpm is was choking it off. tiny filter would do the same 1 Quote
