  • Replies 197
Straight pipe that goes directly under the centre of the frame and dumps just in front of the rear wheel so you can pre-oil your path for burn-outs.
Nothing.
You can buy carbs set up with the adjustments on the left or right, that's just a blank for the where the idle screw would be, you will likely either find another one or a cast boss that's opposite the air screw too.
Ah ok chairs! I can only find an idle adjusting screw on the outside of this carb.
The bike has a bit of a miss so re done the earth's and will re test this evening. I love electrickery
Also can't seem to get voltage regulation derp derp
Ordered some CT shocks, but when they turned up they didn't match the length advertised so got some of these, Anyone else keen on sweet jumps?
13514234_10157206469075725_1535921755_n.image free hosting
Also, turns out these DRC front wheel chock are the correct width and diameter for making rear hoops! life hack?
81210002.jpghost image
Ordered one of these for an LOL to see what they are like,
451308319.jpgimage hosting 30 mb
Got a XR200 manifold on the way, just need to find a nice muff.
349577551.jpgimage ru
New gold chain, battery and tubes also ready for fitment yuZ!
I'm just waiting to hear back from the seller he reckons he might have sent the wrong ones which I semi doubt. If he does have some 350 long, would like to use them for the next AX100 project I have lined up to statt after this one. Will get back to ya.
HELP OS
The motor revs freely at a stand still but under higher speed load it splatters quite badly, like a flat spot when it feels like it should pick up and go.
Have tried 3 different coils, double twipple quad triple checked all connections, played with fuel mixture, changed throttles, disconnected regulator, disconnected battery, all making no difference.
Could it be the 100cc exhaust choking it? It seems quite a large diameter but well muffled.
Running out of trouble shooting ideas :s . . . . lost count of Brooklyn test runs.
