danger Posted March 30, 2015 Share Posted March 30, 2015 //oldschool.co.nz/index.php?/topic/47715-moorepowers-61-impala/ Looks awesome. More info and price on bag set up? Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted March 30, 2015 Share Posted March 30, 2015 this really makes me wanna import a yank tank of my own, very cool. Quote Link to comment Share on other sites More sharing options...
moorepower Posted March 30, 2015 Share Posted March 30, 2015 I purchased the Accuair set up through Joel at Lowrider NZ. https://www.facebook.com/LowriderNZ Joel is a friend of mine so I got a good deal, it would be best to talk to him regarding pricing as there are a number of different set ups. $3000-$4000 is the price range for a basic set up + installation on top of that. I did most of the work myself, its all pretty much bolt in, except NZ certification requires the front shock relocation points and lower a-arm bag brackets in the front to be welded in, rather than bolted. I got a small 3 gallon tank and single compressor as I wanted it to fit above the fuel tank in the boot, where the spare wheel goes, to keep it out of the way. It doesn't offer enough air to play around with it but because I only ride low, it gives me enough air to jack it up once to get the car over a speed bump, then it refills again. If you wanted to play around more, I would suggest at least a 5 gallon tank and two compressors. I am eventually going to get an engine driven a/c compressor and convert it to fill my air tank. A lot of 4x4 guys do this so they can pump their tyres up.It will pump the tank up in about 10 seconds, rather than about 1 minute it takes at the moment. The good thing about the Accuair system is that it can be upgraded to a self leveling system quite easily so you can have 3 predetermined ride heights, at the push of a button, and it will self level so if you have three people in the back it will put more air in the rear bags, to level the car. All I need to do is send the 'brain' of it to the states so they can reprogram it, and they send back 4x height sensors with it, which get attached to each corner of the car and measure the A-arm or trailing arm height. 1 Quote Link to comment Share on other sites More sharing options...
danger Posted March 30, 2015 Author Share Posted March 30, 2015 Thanks man will look into it.Your setup sounds ideal 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted March 30, 2015 Share Posted March 30, 2015 This car gets all of the likes. Love it. 1 Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted March 30, 2015 Share Posted March 30, 2015 did this have some big ass chromes on it a few months ago? I followed similar one out west and fizzled a long side/swooped through traffic to catch up. Quote Link to comment Share on other sites More sharing options...
moorepower Posted March 30, 2015 Share Posted March 30, 2015 Nah not this car. There is another one from out west the same colour as mine with 20's on it and a big block 454 in it, but I don't think his one is running at the moment. Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted March 31, 2015 Share Posted March 31, 2015 trouble bound. are the door card installed? Quote Link to comment Share on other sites More sharing options...
Shakotom Posted March 31, 2015 Share Posted March 31, 2015 This is so lush. Care to share info about HQ springs? Which drop did you select? I've got a big ol GM A body car that needs a few inches taken out of the ride height Quote Link to comment Share on other sites More sharing options...
sidewaysickness Posted March 31, 2015 Share Posted March 31, 2015 Great car! I wonder if your mate at accuair would be interested in doing an oldschool group type deal? I would definitely be keen along with others Quote Link to comment Share on other sites More sharing options...
moorepower Posted March 31, 2015 Share Posted March 31, 2015 The car is sitting on Kings 'low' Holden HQ springs in this photo. The front X member is 80mm off the ground. I cut 40mm roughly off the rear bump stops (still enough meat on them to pass WOFs) so the car was about 10mm or so off the rear bump stops with no one in the car. The result was badass, sore backs and girls suggesting they needed to wear sports bras when riding in the '61 I kept the car like this for about 2 months, then put Kings 'standard height' Holden HQ springs in the rear only. This raised the car in the rear about an inch at the most which was enough to roll around with less bump stop action. The car is now about 40-50mm off the front x member with the air ride in it. Quote Link to comment Share on other sites More sharing options...
moorepower Posted March 31, 2015 Share Posted March 31, 2015 Ill talk to Joel and tell him to make an account on here. He will be willing to do a deal. 1 Quote Link to comment Share on other sites More sharing options...
Shakotom Posted March 31, 2015 Share Posted March 31, 2015 Man that sounds about spot on for what I want. Cheers for the reply! Will be looking into it Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted March 31, 2015 Share Posted March 31, 2015 Forgot to say this is a super awesome car. Looks so right, down low on stockies 2 Quote Link to comment Share on other sites More sharing options...
moorepower Posted March 31, 2015 Share Posted March 31, 2015 Man that sounds about spot on for what I want. Cheers for the reply! Will be looking into it You will just want to check spring diameters. I know hq springs fit 58-64s but not sure about 65 onwards. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 29, 2016 Share Posted February 29, 2016 Top work man. Crate motor just makes it so damn easy. Looks nice and low too. Accolades given. Quote Link to comment Share on other sites More sharing options...
moorepower Posted February 29, 2016 Share Posted February 29, 2016 //oldschool.co.nz/index.php?/topic/47715-moorepowers-61-impala/ Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 29, 2016 Share Posted February 29, 2016 Should move along nicely now. Last year I found that this is a very busy time for the certification people and the LVVTA office, as heaps of people want cert before beach hop. Quote Link to comment Share on other sites More sharing options...
moorepower Posted February 29, 2016 Share Posted February 29, 2016 Im hope I can get mine in time! Im a bit nervous Quote Link to comment Share on other sites More sharing options...
MRWEST Posted March 1, 2016 Share Posted March 1, 2016 Looking good man, I got my accuair elevel setup from Joel as well for my 64, got mine all working in the car now, the Elevel is being a bit of a slut with the sensors but bag setup working manually anyway. 1 Quote Link to comment Share on other sites More sharing options...
