ep82-toy-let Posted November 7, 2013 Author Share Posted November 7, 2013 will try that but I don't think its over boosting but you never know Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 14, 2013 Author Share Posted November 14, 2013 did map sensor today, seems a bit better but still not 100%, am swapping ecu next week to see if that is the issue.... as I have tried everything else... :/ Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 14, 2013 Share Posted November 14, 2013 You realise that swapping parts is the most expensive way to diagnose a problem aye? Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 14, 2013 Author Share Posted November 14, 2013 You realise that swapping parts is the most expensive way to diagnose a problem aye? so how else am I supposed to find out whats rong mate? please amuse me? I don't have money to pay 4 a mechanic plus parts, have gone over entire car looking for leaks, etc, have run a diagnostic on it with no codes showing... so please, if you have some idea I havnt already tried id love to hear it Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 14, 2013 Share Posted November 14, 2013 You can test if a sensor works with a multimeter or sillyscope depending on what it is. Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 15, 2013 Author Share Posted November 15, 2013 You can test if a sensor works with a multimeter or sillyscope depending on what it is. I know that, but it cost me less time to just swap it for another one I had. Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 15, 2013 Share Posted November 15, 2013 So you know the other one is good? Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 15, 2013 Author Share Posted November 15, 2013 So you know the other one is good? its got to be better than the old one, came out of a perfectly running car, and if you read the post, you would have seen it made a difference... thanks for your concern anyway. Quote Link to comment Share on other sites More sharing options...
Ranter Posted November 15, 2013 Share Posted November 15, 2013 A lot of mechanics would do the same thing. But it sounds like your gonna need one sometime. Maybe pay one to take it for a drive with a fuel pressure tester? You can narrow it down a lot from that. Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 15, 2013 Author Share Posted November 15, 2013 yea thanks, will have to pay a visit to one soon if I don't sort it by next week Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 17, 2013 Author Share Posted November 17, 2013 anyone know if its safe to gap the plugs smaller than .8mm? that's what I have them set at right now, a lot of other threads ive read blame plug gap for misfire at high boost... the plugs are new, re gapped to .8mm, champion golds, copper core plugs. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 17, 2013 Share Posted November 17, 2013 0.8 is fine. Can go down to 0.6 with no issues. Quote Link to comment Share on other sites More sharing options...
kpr Posted November 17, 2013 Share Posted November 17, 2013 isn't plug gap. factory plugs are 1.1mm and will run up to boost cut, long as the rest of the igntion is working how it should. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 18, 2013 Share Posted November 18, 2013 did you try a *known* accurate boost gauge? the gauge that came in my GTti charade was a cheap repco one, and i bought a new autometer one which read 3psi higher, i was concerned that id done something to raise the boost, so borrowed a second know accurate and top quality hks gauge from a member here and confirmed my autometer was accurate and the repco one was 3psi out. very possible the gauge you have is reading low and your simply hitting boost cut, especially if you have a boost tap installed Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 19, 2013 Author Share Posted November 19, 2013 hi, thanks for that, will try a better one as the one I have is a autogauge one. thanks. Quote Link to comment Share on other sites More sharing options...
ep82-toy-let Posted November 21, 2013 Author Share Posted November 21, 2013 could old fuel cause my issue? my fuel is slightly old, going to drain it out, fill it up with new fuel and run some cleaner thru it... Quote Link to comment Share on other sites More sharing options...
downtrail Posted November 21, 2013 Share Posted November 21, 2013 could old fuel cause my issue? my fuel is slightly old, going to drain it out, fill it up with new fuel and run some cleaner thru it... how old is the fuel? Quote Link to comment Share on other sites More sharing options...
Stu Posted November 21, 2013 Share Posted November 21, 2013 Sounds like boost cut dude. With your front mount change you didn't knock/bend the actuator arm or muck with the vac lines? (Assuming the front cover > actuator line is on?) Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 21, 2013 Share Posted November 21, 2013 i really dont think its old fuel. though the other thing that just occured to me, is that my charade does some weird thing with no air filter, where sometimes if you hit high boost, it will just cut all power violently, im pretty sure this is boost cut, but im not experienced much in the way of turbo cars and problems, but its a common phenomonen with the GTti charades running no filter. so, do you have a filter? Quote Link to comment Share on other sites More sharing options...
Stu Posted November 21, 2013 Share Posted November 21, 2013 I ran filters and no filters on stock turbo setups without any major issues (other than eventual turbo damage from crap going through it). What drop pipe are you running? Stock or custom? Quote Link to comment Share on other sites More sharing options...
