CaMpylobacter Posted July 1, 2013 Share Posted July 1, 2013 Was there ever a model of vehicle (probably commdore) with both a 202 and a/c? I want an a/cpump, bracketry, and pulleys off one if they exist... Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 1, 2013 Share Posted July 1, 2013 If any version, likely to be a VK, so black 202. Quote Link to comment Share on other sites More sharing options...
sheepers Posted July 1, 2013 Share Posted July 1, 2013 try your local marina. they would have a pretty good supply of 202's. 9 Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted July 1, 2013 Share Posted July 1, 2013 Injected enigines seem to have them Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 1, 2013 Share Posted July 1, 2013 A quick google suggest that they all did (VB-VK) but they would be Aussie ones as opposed to NZ ones. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 1, 2013 Share Posted July 1, 2013 To convert into compressor to do tyre pressure on landy? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 1, 2013 Share Posted July 1, 2013 Going to be hard pressed to find but they are out there - just need to look really hard. In all honesty you would be better off and much easier to score a dive bottle and 2 stage reg then make some sweet brackets to hold it and airlines in the tray - refills cost $10ish. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 1, 2013 Author Share Posted July 1, 2013 badass. yeah if they're not common then divetank would be the go if anything. will hit up spraks dad. hah. Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 2, 2013 Share Posted July 2, 2013 Didn't the Royal have fancy stuff like AC? Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 2, 2013 Share Posted July 2, 2013 I could pro ably find you something, seems reasonably common here in Straya. But you should just fit a york you pussy, bet you have heaps of space. 2 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted July 2, 2013 Share Posted July 2, 2013 yeah that^ /either way onboard air will be lush Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 2, 2013 Share Posted July 2, 2013 Get durty to find you a lush York from a Volvo. Or ask seedy I he has one from my crown? Or whoever owns the wag now? There was a couple floating around with the criz. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 2, 2013 Author Share Posted July 2, 2013 che. yeah got a million rooms. Have electric compressor which works like a boss but engine driven air is much more king. those hori bolt on pulleys to give accesory drive look like they might be a bit of me. will do something. giz a york durty/seedy. 1 Quote Link to comment Share on other sites More sharing options...
durty Posted July 3, 2013 Share Posted July 3, 2013 che. yeah got a million rooms. Have electric compressor which works like a boss but engine driven air is much more king. those hori bolt on pulleys to give accesory drive look like they might be a bit of me. will do something. giz a york durty/seedy. will have a dig in the shed, I had a couple left around that I had robbed bits off when rebuilding them. Will see if I have enough to make a whole one Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 3, 2013 Author Share Posted July 3, 2013 ^ would be EPIC Quote Link to comment Share on other sites More sharing options...
