J-W-G Posted November 11, 2012 Posted November 11, 2012 Love it man. Keep her standardish with wide steels on it and youve got a keeper Quote
hulse12 Posted December 5, 2012 Posted December 5, 2012 Sick! Keep it original as, maybe a lil lowering and widened rims! Primo example of a escort! Quote
Guest camo_78 Posted April 17, 2013 Posted April 17, 2013 good to meet you today mate,glad i could contribute to keeping this old girl mint,even in a tiny way photos dont do this car justice,its tidy as hell in person,even on a rainy day 1 Quote
danger Posted January 8, 2014 Posted January 8, 2014 I've been seeing this down by the wharf a lot. Wondered who owned it Quote
Bistro Posted April 6, 2014 Posted April 6, 2014 Lookin super clean man! Nice ride hight too. Always fond of the escorts Quote
Benno Posted April 28, 2014 Author Posted April 28, 2014 I've just bought a worked crossflow for it, but I need to get a carb for it. I'm wanting to get a cheap weber for now then save up for some sidedraughts or have a play with bike carbs in the future. I've been offered a crossflow manifold and a weber 32/36 DGAV off a 2.0L pinto. Is this carb going to work as I want it to? Will need to re-jet obviously, was planning on jetting it to same specs as this to get it running then have a play with a wideband. From some research it seems that some people don't have any issues at all with these carbs, others say that they don't idle properly and aren't right for the engine. Quote
J-W-G Posted May 2, 2014 Posted May 2, 2014 Should be fine with the jets its got dude. Same carb as the ghia and sport 1 Quote
Benno Posted January 7, 2015 Author Posted January 7, 2015 So I need a new one of these for the new inlet manifold. Is for the water jacket. Small end is roughly 13mm, big one 16mm. Ideally a bit longer at the hose connector end. Any suggestions for where to look for one? Haven't looked hard yet, had nothing at the local repco. Quote
Brdflu Posted January 7, 2015 Posted January 7, 2015 Might have a Datsun one in the garage now i think about it. Quote
punkoutnz Posted January 7, 2015 Posted January 7, 2015 I saw these on Trademe recently, see if I can dig up a link. http://www.trademe.co.nz/motors/car-parts-accessories/ford/engines/auction-829583440.htm Quote
kyteler Posted January 7, 2015 Posted January 7, 2015 Hydraulink or a hydraulic hose fitment type place will have something, will likely have one threaded end of elbow and potentially a barbed other end. Shouldn't be hard to get a hold of, just find out what thread, etc. it is/take it in and have some yarns. Quote
bmxnz11 Posted January 14, 2015 Posted January 14, 2015 Nice work man. Do you know the specs of the engine? Still contemplating side drafts or bike carbs? Quote
peteretep Posted January 14, 2015 Posted January 14, 2015 regarding those fittings, I bought one of those aluminium ones, they are pretty trash but I could send mine to you if you want. Otherwise pretty sure a bsp threaded brass fitting should fit good job putting new motor in, dont stop the progress now! Quote
Benno Posted January 14, 2015 Author Posted January 14, 2015 Nice work man. Do you know the specs of the engine? Still contemplating side drafts or bike carbs? Cheers. Not entirely sure about the full specs of the engine, know it has been fully rebuilt (top and bottom end) with a port and polish job, oversize valves and a bit of a cam. Yeah, haven't ruled them out at all for the future. Will get everything running sweet on the 32/36 to start with, then look into my options after my finances have recovered a bit. regarding those fittings, I bought one of those aluminium ones, they are pretty trash but I could send mine to you if you want. Otherwise pretty sure a bsp threaded brass fitting should fit good job putting new motor in, dont stop the progress now! I got some stainless fittings from Hydralink in the end. They are a tiny bit small on the output end, but might be able to take up the slack with a hose clamp though. Won't really know until my hoses get here. Thanks though man! Quote
kyteler Posted January 27, 2015 Posted January 27, 2015 You just need a FORD grille instead of a blue oval one and you'll have clocked MkII front end. 2 Quote
