NicT Posted January 18, 2014 Share Posted January 18, 2014 You must be tight for space if the alternator belt situation is determining your oil hose routing. I thought we were tight with a 1uz turbo in a AA60 Carina.... Quote Link to comment Share on other sites More sharing options...
mjrstar Posted January 18, 2014 Author Share Posted January 18, 2014 Not so much the room its more making sure I get the fittings coming off at the right angles to clear the alternator and belt run.. plus I don't want the hoses looking like an afterthought and all horrible. 1 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted February 7, 2014 Author Share Posted February 7, 2014 A successful day was had, although it was a bit Exhausting the resident Tig master popped in for a visit so it's mostly Tigged with a few bits of Mig here and there... the dump pipe was a total PITA, and probably took longer to get that right than the rest of the system.. there seemed like more obstacles than normal Anyway this must be a better way to spend Waitangi day than protesting and throwing stuff at politicians.. The result is a trimmed down gearbox bell housing, but more importantly a nicely tucked away 2 1/2 system which should do the job well enough.. 7 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted February 18, 2014 Author Share Posted February 18, 2014 Minor update... Wasn't quite as easy as i thought to match up the early and late cambelt covers to not look total rubbish.. In hindsight it might have been worthwhle trying an early model top cambelt cover possibly with some mods to the cam cover for mounting provisions? Which still left part of the original hole for the transverse engine mount.. Although nothing a bit of heat gun action and some spare plastic couldn't bodge up.. Also went back to full length fuel rail spacers for fitment of the larger injectors (Sard / Denso 720cc same as my evo runs) and then modified the rail a bit to fit the injector plugs in anticipation of some wiring happening at some stage.. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 9, 2014 Author Share Posted March 9, 2014 Finally got the front of the engine peiced together with new tensioner and idler, belt etc..as well as a brand spankers crank pulley as these things can tend to delaminate with age.. Then started on adding a birds nest to the engine and interior. Sorted mounting provision for the ECU and figured out where to split the engine loom out, should be pretty quick from here to hook all the loom up, and surprisingly even though the ECU is only ATOM spec even with dedicated wideband input we still have spare channels. Still Need to find some resistors for the injector circuit to have some more ohms. 3 Quote Link to comment Share on other sites More sharing options...
NicT Posted March 10, 2014 Share Posted March 10, 2014 Ditch the cam covers pleeaase Quote Link to comment Share on other sites More sharing options...
fuel Posted March 10, 2014 Share Posted March 10, 2014 love the progress! is there a flexi in the exhaust? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 10, 2014 Author Share Posted March 10, 2014 There is a flexi in my shed, much discussion was had and given the rigidity if the engine/ gearbox mounts the flexi was left on the shelf. Its pre gutted of internal strands if it does need to get slotted in at a later date. Cam (belt) covers? - I don't do bling / shiny so top Cambelt cover will be remaining in place. or do you mean cam (rocker) cover - these are great to keep oil in the engine and everything else out of the engine. 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 10, 2014 Share Posted March 10, 2014 belt cover. I agree. Take it off. A little Bling never hurts Quote Link to comment Share on other sites More sharing options...
AllTorque Posted March 10, 2014 Share Posted March 10, 2014 That's all good until a stone or something flicks up and cuts the cambelt. 4 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 11, 2014 Share Posted March 11, 2014 cut a window and add perspex Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 11, 2014 Author Share Posted March 11, 2014 When you leave flash bits on display it just means the other stuff looks shit in comparison, then you need to re passivate all the attachment hardware then strip the alternator for anodising and before you know it it's going sheepers spec which is beyond my current care factor. Its not intended to be a show car.. 5 Quote Link to comment Share on other sites More sharing options...
NicT Posted March 11, 2014 Share Posted March 11, 2014 Yea sorry cam belt cover When you leave flash bits on display it just means the other stuff looks shit in comparison, then you need to re passivate all the attachment hardware then strip the alternator for anodising and before you know it it's going sheepers spec which is beyond my current care factor. Its not intended to be a show car.. Having my cam gears seen made me feel better about all the money i spent on a 4age head when i looked at them and they looked good. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted March 11, 2014 Share Posted March 11, 2014 Can't see them from the drivers seat... Quote Link to comment Share on other sites More sharing options...
Stu Posted March 12, 2014 Share Posted March 12, 2014 Leave covered, paint everything black.... everything.... Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 12, 2014 Author Share Posted March 12, 2014 ^^ Including the Windows? In other news some more of the body wiring is actually working now.. so useful stuff like lights, wipers and horn should actually have a chance of working even with the bunch of the loom which is now in the bin.... had to srip the innnards of the light combination switch to get the park lights to play the game which was not where I started my problem solving.. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 13, 2014 Share Posted March 13, 2014 ^^ why not, steer with head out of window Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 15, 2014 Author Share Posted March 15, 2014 Managed a quick trip to everyone's favorite car part store yesterday( before the bad weather hit), found some horns, a decent plug for fan connection, an oil cap( the one I have was damaged), a mazda specific relay and some grunty 30a relays for the fuel pump and to upspec the current 10a fan relay which doesnt sound grunty enough to me. Then swung by jaycar for a few additional goodies, such as a battery isolator, and terminals and other electrical shit. Also sorted a 2mm spacer for the water pump pulley to bringthe belt into line. Add that to getting more of the lights working and id say its been successful wiring so far with no escaping smoke. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 17, 2014 Author Share Posted March 17, 2014 Got this sorted last night.. Sorry, maybe this makes more sense... 2 Quote Link to comment Share on other sites More sharing options...
NicT Posted March 19, 2014 Share Posted March 19, 2014 Ballast resistors for spark plugs injectors? (wednesdayitus) Quote Link to comment Share on other sites More sharing options...
