SHGWAG Posted April 30, 2012 Share Posted April 30, 2012 So my daily AE111 superslut Levin is having a wee issue. The hand brake light keeps comming on intermittantly, it doesn't seem to be related to anything, other than it sometimes comes on when I accelerate - espeically when I head up hills. It used to do this around two years ago, then it just went away. It functions normally when putting the handbrake on / releasing the handbrake. Actually after reading this post - how is the handbrake light triggered? Could it be a faulty micro switch? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 30, 2012 Share Posted April 30, 2012 Top up your brake fluid.. The sensor in the resevoir activates this light also - as you are going up hill it is draining the fluid away from the level sensor and causing light to come on... Quote Link to comment Share on other sites More sharing options...
xsspeed Posted April 30, 2012 Share Posted April 30, 2012 theres a push to make switch thats activiated when you pull the handbrake up - remove the console and you will find it Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 30, 2012 Author Share Posted April 30, 2012 KK, that's one thing I hadn't thought to check - cheers. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 30, 2012 Share Posted April 30, 2012 Was my thought also Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 30, 2012 Share Posted April 30, 2012 Yup it will be low brake fluid Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 30, 2012 Share Posted April 30, 2012 I agree - I reckon it'll be brake fluid Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 30, 2012 Share Posted April 30, 2012 Seen it 100 times, its a trap for noobs. Check pad wear too as obviously the fluid drops with wear Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted April 30, 2012 Share Posted April 30, 2012 Semi related question, do the black top ECU's suffer from leaking capacitors like the silver top ones do? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted April 30, 2012 Share Posted April 30, 2012 from memory common BT is something in them blowing - refer to toyspeed faq on ecu stz - and they are less susceptible to leaking caps (though probably still possible/probable) Quote Link to comment Share on other sites More sharing options...
xsspeed Posted April 30, 2012 Share Posted April 30, 2012 http://www.my-acoustic.com/Car/ECU/20vM ... roblem.htm Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted April 30, 2012 Share Posted April 30, 2012 Thank you sir, I may have to whip the ECU out for a nose, as the car does a few odd things which I feel are ECU related. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 30, 2012 Share Posted April 30, 2012 Burn outs? Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted May 1, 2012 Author Share Posted May 1, 2012 Definately not the brake fluid, I'll check the pads in the weekend. It did pass a wof last month and nothing was mentioned RE: pads. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 1, 2012 Share Posted May 1, 2012 Na I only said check pads if brake fluid was low they dont cause a light. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 1, 2012 Share Posted May 1, 2012 other options are then just the shitty switch on the hand brake Or even the fluid might need changing. get that one some times Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted May 2, 2012 Author Share Posted May 2, 2012 Fluid hasn't been changed in over a year, so that may be the problem. Really I should just sell the damn thing, but in the 4 years I've owned it, it's never broken down. (It has needed a new battery after it sat for 2 months however.) Quote Link to comment Share on other sites More sharing options...
Bling Posted May 3, 2012 Share Posted May 3, 2012 I'd put money on handbrake switch over old fluid. I just don't see them being that smart / my fluid would be a few years old no issues. Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted May 3, 2012 Author Share Posted May 3, 2012 Pdeal has become a little spongy, and it's doing it more regularly.. Will chuck it up on the hoist over the weekend and inspect pads / Fluid change. It's done this before, but it just went away. Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted May 6, 2012 Share Posted May 6, 2012 sounds like you're outta fluid then, hence light being on. Quote Link to comment Share on other sites More sharing options...
