Rubber Steering Coupling (escort/capri)
RT
Yeah I'm on my 2nd urethane one - the holes ended up oval which caused the steering to slip and graunch when tight turns at low speeds (ie parking). Could be due to proximity to the pipes. Only replaced it with another urethane cos it was convenient.
Not sure where you could get rubber ones
I've probably got an old one here if it's any use. Alternatively I've got a gp.4 one if you want to replace it?
The old one wouldn't be much use unless it was in better cond than mine. Mine is ok, but it looks pretty old and I'd like to replace it whilst the engine is out. What is the gp.4 one? If it's new and it's rubber I'm keen!
yes they use a small UJ like a diff.
i can get a group 4 from rallydeisgn in the u.k for you
Group 4 Coupling - Forged Steel $42.80 + postage
Group 4 Coupling - Pressed Steel $38.15 +postage.
but if you can use you old one for now Jon ill be ordering some things
within the next 2 weeks so i can get one put in with my shit so no postage charge
let me know bro.
