37 Ratrod options
GT_Escortina
hey im looking for a engine for my 37 austin
at the moment i thinking 3.8 V6 Holden, 2.3/3.0 ford V6 or a ea81 turbo
Also needing a diff so if anyone in chch knows of a cheap Subaru justy 4x4 rear diff and sub frame would be mint
and what are the laws on how far the rear wheel are aloud to stick out as i would like to fit these 255x35x18s on the rear
toyota hemi 4v would be a great motor. Being all alloy would shine up well too.
So would the Daimler, but minus the SU carbs :P.
Personally, I think a v8 made from two 4age's (silver tops) would a great project.
But, if it was me, I'd just buy a 289 or 350. perhaps a 302 or 351. So many parts available, engines come up cheap all the time, dress up parts are easy to find and cheap.
Dont get me wrong, I love 1uz-fe's and toyota engines in general, but a dirty ole v8 is the only way to go in a hot rod like that.
But .. if your looking for kinky
http://www.trademe.co.nz/motors/car-par ... 577619.htm
http://www.trademe.co.nz/motors/car-par ... 148592.htm
http://www.trademe.co.nz/motors/car-par ... 609423.htm
http://www.trademe.co.nz/motors/car-par ... 250173.htm <-- thats what I would use.
- but, I would install EFI, and injectors, and use a aftermarket ecu on it. but, .. I'm that kinda guy :pirate:
http://www.trademe.co.nz/motors/car-par ... 293512.htm
http://www.trademe.co.nz/motors/car-par ... 812432.htm
http://www.trademe.co.nz/motors/car-par ... 107812.htm
^ there were two types of V4 ford, one sucked, one was quite rad. Foget which was which, but one was german, one was essex.
I like the idea of the diesel or the pontiac motor, but for cheapness and rad power/lightweight and easiness of parts and finding one.
There is only one answer...
Rover V8
Now it has been said you can all go about your business in anticipation of a Austin Seven pick up with a rover V8
that will be all
Daimler V8 and manual box and Rambler 304CI V8 i do like and would love put a sidevalve v8 in her but sadly i have set a really low budget of $1200-$1500 to get her drivable for rangiora car show
may have a 2.3 V6 and auto lined up for fuck all :D
also justy diff is out too weak have got my eye on this tho http://www.trademe.co.nz/Browse/Listing ... =419962167 a little wide so will need shorting (have ask to relist)
she not very wide at the wides part of the cab is only 1100mm
I think with a _really_ low budget, a 202 and trimatic would be my choice. a 2.3 v6 tina motor doesnt have that .. look, that .. style. a 202 with a rusty chrome air filter would.
OR
or, you could use 8 trained and harnessed children with oddly flat heads mounted inbetween the chassis rains where the american steel should be in cardboard tubes so you can call it a 8 cylinder flathead.
I bet if you whip them they would go faster. Just Sayin.
