GT_Escortina Posted October 15, 2011 Share Posted October 15, 2011 make them if you can the my very first bike carb set up $550 (8 years ago)to make the manifold thought fuck that.So i got a job in a welding workshop and learned how to alloy tig weld and have made my own 10-12 hours work. bike carb are the way to go i see your bidding on some R1 carbs at the moment give these guys a ring. Ive got 2 sets from them for $210 per set including postage GP Honda. Mt Maunganui (07)5746688 Quote Link to comment Share on other sites More sharing options...
fordcapri1980 Posted October 15, 2011 Author Share Posted October 15, 2011 will do thanks mate!! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 15, 2011 Share Posted October 15, 2011 ^ do the stock them quite often? cause thats a damn tidy price Edit: whats the smallest size bike you should be looking at for a 2000cc engine? i see alot of 700cc bike carbs but im pretty sure they will be a little small. r1s sounds like the go tbh.. Quote Link to comment Share on other sites More sharing options...
anglia4 Posted October 15, 2011 Share Posted October 15, 2011 that is a fricken sharp price. I got 2 sets of ebay for about that much, I thought it was cheap as chips haha Quote Link to comment Share on other sites More sharing options...
GT_Escortina Posted October 15, 2011 Share Posted October 15, 2011 yeah they had 6 sets at the and had them listed on trade for $200 buy now they were missing the throttle positioning unit which you dont need anyway.. also sure blackbird and gsxr1300 are 40mm too ive only fitted bike carbs 1300 1600 kent engine frist set were 32mm on a 1600 and work fine Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 15, 2011 Share Posted October 15, 2011 we have just done rot808's for what I think is around $450 excluding time I think the guys with 2 litres generally go for r1 carbs Quote Link to comment Share on other sites More sharing options...
fordcapri1980 Posted October 15, 2011 Author Share Posted October 15, 2011 $what was 450? Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 15, 2011 Share Posted October 15, 2011 the whole job Quote Link to comment Share on other sites More sharing options...
fordcapri1980 Posted October 15, 2011 Author Share Posted October 15, 2011 oh wow thats awsome, Quote Link to comment Share on other sites More sharing options...
7ESKY9 Posted October 16, 2011 Share Posted October 16, 2011 im just having a manifold built for my 2l pinto in mk1 escort going 2 b running gsxr 1100 40mm carbs will post pics when done. Quote Link to comment Share on other sites More sharing options...
fordcapri1980 Posted October 16, 2011 Author Share Posted October 16, 2011 would be kool if ya gave me manifold specs Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted October 16, 2011 Share Posted October 16, 2011 are 38mm carbs big enough for a 1300? http://www.trademe.co.nz/motors/motorbi ... 145668.htm Quote Link to comment Share on other sites More sharing options...
R100 Posted October 17, 2011 Share Posted October 17, 2011 I put bike carbs on my old hillman imp. Had to run a header tank above the carbs to gravity feed them with a return line to the main tank. Sounded nice at max revs ! Quote Link to comment Share on other sites More sharing options...
phatt20 Posted October 17, 2011 Share Posted October 17, 2011 are 38mm carbs big enough for a 1300? http://www.trademe.co.nz/motors/motorbi ... 145668.htm plenty big enuf, i had 38mm cbr900 carbs on a 5k , could go as small as 28mm on a 1300 without restricting it . trouble with going too big on the carb size is making the manifold taper/bend/flow well from 40 odd mm down to the much smaller port dia (on k motors anyway) ya dont want to ream the ports out too much to tey match them as velocity/low end will suffer. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 17, 2011 Share Posted October 17, 2011 is a header tank required for all bike carbs or just some? i always thought you just ran the factory fuel pump and an fuel pressure regulator if need be Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 17, 2011 Share Posted October 17, 2011 just use a fuel pump Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted October 17, 2011 Share Posted October 17, 2011 ^ standard carby car fuel pump, bike fuel pump(exist?) or electric fuel pump? Quote Link to comment Share on other sites More sharing options...
Toucan Posted October 17, 2011 Share Posted October 17, 2011 From the first page... http://www.classicfordmag.co.uk/category/features/tech-guides/and click on bike carbs Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 17, 2011 Share Posted October 17, 2011 a standard mechanical pump should be fine I think for most situations, rot808's car is using the standard pump and appears to be fine Quote Link to comment Share on other sites More sharing options...
phatt20 Posted October 17, 2011 Share Posted October 17, 2011 depends on the carbs, the cbr900 ones were brand spankers and they leaked with the factory pump, and a facet. i ended up using a factory motorbike electric inline one and it worked mint. Quote Link to comment Share on other sites More sharing options...
