eskie77 Posted February 4, 2011 Share Posted February 4, 2011 hey,im considering repowering my 77 escort pannel van.what engine can you fit with minor mods and puts out a decent amount of power ??Also thinking bout a 5speed gearbox, Any help appreciated thanks Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 4, 2011 Share Posted February 4, 2011 pinto and 5 speed gearbox.. Quote Link to comment Share on other sites More sharing options...
Simon Posted February 4, 2011 Share Posted February 4, 2011 13bt drillport. Quote Link to comment Share on other sites More sharing options...
eskie77 Posted February 4, 2011 Author Share Posted February 4, 2011 No,wont do a rotary sorry and want more modern than the pinto Quote Link to comment Share on other sites More sharing options...
Simon Posted February 4, 2011 Share Posted February 4, 2011 fare enuf Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 4, 2011 Share Posted February 4, 2011 Well if you don't want the original Kent or a Pinto then you'll need more than minor mods then.. Unless you determine making engine and gearbox mounts along with a new drivehsaft as "minor mods" Quote Link to comment Share on other sites More sharing options...
QCADTA Posted February 4, 2011 Share Posted February 4, 2011 have a look under ford in user projects. as said, anything more than a pinto is a bit more than minor. Quote Link to comment Share on other sites More sharing options...
eskie77 Posted February 4, 2011 Author Share Posted February 4, 2011 yeah i probably shouldnt of put minor mods,i want to put a more modern engine in it and get more power and a five speed box.Im a mechanic by trade so do all the work myself except for the cert .... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 4, 2011 Share Posted February 4, 2011 Search the project threads - there are a plethora of Escort projects in there with all kinds of twin cam injected motors.. viewtopic.php?f=17&t=11892 take a look under the ford section and click click BOOM!! Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 4, 2011 Share Posted February 4, 2011 2l zetec & 5speed Sierra box is easiest for injected Dohc if wanting to keep Ford. Well apart from the cossie engine which will almost bolt in but will cost ya a fourtune. Needs: - Some slight flywheel mods - Water pipes re routed - Focus steel sump modified - Some meke loom triming/shortning/tricking and standard ECU or aftermarket ECU OR run twin 45 webbers - Engine mounts - New extractors - Driveshaft mods Or you could run a mazda/ford Fe engine + mazda 5 speed and do similar mods. Actually any engine would require similar mods just depends what you like. 4age is common but boring. Do yoiu want turbo, na, 4cyl, 6, Ford, using the car for what... what do you want? Also, have a search, there are 12 millions threads about this. Gaz Quote Link to comment Share on other sites More sharing options...
eskie77 Posted February 4, 2011 Author Share Posted February 4, 2011 thanks heaps for all your help ill have a look at the threads Quote Link to comment Share on other sites More sharing options...
cletus Posted February 4, 2011 Share Posted February 4, 2011 non turbo sr20 would be cheap. have seen one in an esky and dont think it was too difficult to get it in Quote Link to comment Share on other sites More sharing options...
spanners Posted February 4, 2011 Share Posted February 4, 2011 s2000 motor, would be epic. Or maybe one of those sr20ve of whatever they are? Quote Link to comment Share on other sites More sharing options...
shizzl Posted February 4, 2011 Share Posted February 4, 2011 if you want a newer motor with reliability and minimal mods then go with a 4age.. cant get more simple with them.. use a ke70 driveshaft and get a flange adaptor hub made up or get a custom driveshaft made up. cut n shut the manifold to remount the throttle body if its a fwd motor. new mounts and get the wiring modified so its a 3 wire hook up.. new fuel pump and ya done... 4age rwd extractors fit in aswell.. i was surprised how easy it was when i did my one.. Quote Link to comment Share on other sites More sharing options...
shizzl Posted February 4, 2011 Share Posted February 4, 2011 http://www.trademe.co.nz/Trade-Me-Motor ... 893434.htm own it with this... oh and you can use a k50 box,theyr allright if you dont thrash them and theyr cable clutch,the escort cable fits it too Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted February 5, 2011 Share Posted February 5, 2011 with that beast i would give a k50 just days to live, even driving slowish Quote Link to comment Share on other sites More sharing options...
R100 Posted February 6, 2011 Share Posted February 6, 2011 Mazda MX5 engine and box. Cheap reliable easy to find, small and compact. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted February 6, 2011 Share Posted February 6, 2011 there was a 1J powered one on Trademe a while back.. that would be more my style.. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted February 6, 2011 Share Posted February 6, 2011 Recon and make a mint/wild orig 1600 kent IMO is way cool. Quote Link to comment Share on other sites More sharing options...
kiwitina Posted February 7, 2011 Share Posted February 7, 2011 I have to second Gaz and say 2L zetec. theres stacks of info out there about doing it. and more and more stuff available to get it done easier. Have a look at this zetec to escort guide. http://www.classicfordmag.co.uk/2010/01/28/how_to_zetec_into_mk1_and_mk2_escort/ Quote Link to comment Share on other sites More sharing options...
