Bombsquad Posted February 4, 2011 Share Posted February 4, 2011 So once i again I have another top notch european car with issues, Car is a 95 Audi a4, and problems are plentiful. Firstly central locking is very tempremental, its run off a vacume system, Can anyone tell me what produces the vacume? Is it a pump? if yes where. Secondly, transmission is computer controlled automatic, 90% of the time itll be good as gold, but occasionally you'll start it and put it in gear and i will stick in first and not shift through the rest of the gears. Computer has been replaced recently with a good unit, so is there a sensor or something somewhere that could play up? And lastly sometimes when you start the car it "chugs" runs poorly then stalls when you go into gear as it doesnt have the power to move, I havnt seen it do this but my missus assures me it happens. The really hard thing about these issues is that all happen randomly and seemingly unprovoked so i have no idea whats up with it. Anyone got any ideas? Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 4, 2011 Share Posted February 4, 2011 im going to say the central locking is due to a vacum leak. mercs run the same system. just check all the vacum lines you can see. google that shit, should be helpful Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 4, 2011 Share Posted February 4, 2011 It's VAG product. sadly all euros get tarred with the brush that seems to be VAG lemon-ness. that's all I know vaccuum will be supplied form the inlet manifold. may be a tank somewhere which 'stores' vaccuum. and hoses throughout the car, with some solenoids. Auto VAG is shit. Quote Link to comment Share on other sites More sharing options...
Raizer Posted February 4, 2011 Share Posted February 4, 2011 My guess with the locking is the electrical unit in the drivers door is fucking out. The vacuum comes from an electric pump that should be under one of the seats (from memory it was under the back seat in the older Audi's like 100's, looks like one of those little compressors you get at super cheap) If the design didn't change much from the 80s/early 90s cars then the locking system air lines will be hard green plastic that I doubt will be leaking, although these are joined with rubber vacuum hose (black with green stripe) that could have perished and split. The lines themselves from memory run either in or along the sills then up the A and B pillars. Quote Link to comment Share on other sites More sharing options...
R100 Posted February 4, 2011 Share Posted February 4, 2011 We just fixed the central lock on an Audi A4 at work last week. They run a vacum pump under the rear seat. Turns out the pump was faulty and its a sealed unit. Not economical to repair. We found a good second hand pump. Total job came to just over $600. The pump was neary $400 on its own. Quote Link to comment Share on other sites More sharing options...
R100 Posted February 4, 2011 Share Posted February 4, 2011 The best thing to do to fix your car is slowly replace everthing until it becomes a jap car. Quote Link to comment Share on other sites More sharing options...
H05TYL Posted February 4, 2011 Share Posted February 4, 2011 ie: 2JZ swap followed by JZX100 chassis swap. Quote Link to comment Share on other sites More sharing options...
Bombsquad Posted February 4, 2011 Author Share Posted February 4, 2011 Haha yeah I wanted to get a diesel laurel but nooo euros are so in right now. I dont think it has a vacume leak for the locking because sometimes it works fine and other times it doesnt, in theory if it was leaking it would not work all the time. I will attempt to pull apart the drivers door and have a look, because when the locking decides not to work it wont work off the key either Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 4, 2011 Share Posted February 4, 2011 pump under the seat seems so retarded. shit son. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 5, 2011 Share Posted February 5, 2011 Why do they run vacuum locking? Quieter? Electronic actuator clunks are too annoying for some people? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted February 5, 2011 Share Posted February 5, 2011 getting kinda ot, but what is VAG? I always thought vag was an abreviated way of saying pussy. But cunts here say VAG is fail, and pussy is all good. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted February 5, 2011 Share Posted February 5, 2011 vw audi group was down at a vw specialist the other day putting the airbag light out on the passat and giving it more boost, he told me that there are alot/ALOT! of euros coming into the country from japan that have close to double the kms on the clock. this probably explains why they have alot of issues here the passat itself has a odo of 35k and an ecu reading of 52k and yes 90's vag locking systems are shit you will find soon that only the passenger door will open off the key and all euro autos(/all autos) are poos as for the stumbling idle could just need a fault code check and be something simple Quote Link to comment Share on other sites More sharing options...
Simon Posted February 5, 2011 Share Posted February 5, 2011 ^ Actually VAG stands for Volkswagenwerk Aktiengesellschaft (a.k.a VOLKSWAGEN AG) not VW-Audi Group. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted February 6, 2011 Share Posted February 6, 2011 Mom's had 3 A4's each one had the gearbox replaced in under 10,000km Quote Link to comment Share on other sites More sharing options...
rxsumo Posted February 7, 2011 Share Posted February 7, 2011 Secondly, transmission is computer controlled automatic, 90% of the time itll be good as gold, but occasionally you'll start it and put it in gear and i will stick in first and not shift through the rest of the gears. Computer has been replaced recently with a good unit, so is there a sensor or something somewhere that could play up? This sounds similar to a issue I've encountered with the auto trans'. Issue with the BMW boxes, is that the clutch packs are made of an "organic material", as the material ages, fibres fall off the clutches find their way into the oil, and no doubt block or partially block the transmissions injectors and solenoids. One of my 535s would lock in first when cold, taking between 2 and 3 kms to start shifting normally, unless the car was idled until it was warm. If you forced an up change, the box selected a neutral position....so no drive at all. All we did is have the trans serviced, flush and filter....Hutt Automatics basically said...no warranty...it could last a week, or years....after 9 months it was still shifting fine. Not sure if it applies to VW, but I'd be guessing the box is a ZF one, so the technology is probably pretty much the same Quote Link to comment Share on other sites More sharing options...
ryanfels Posted February 8, 2011 Share Posted February 8, 2011 Mom's had 3 A4's each one had the gearbox replaced in under 10,000km Lol why did she have 3 of them then Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 8, 2011 Share Posted February 8, 2011 she's american Quote Link to comment Share on other sites More sharing options...
drtdvl Posted February 8, 2011 Share Posted February 8, 2011 Nope she's kiwi. Ryanfels, they where new - once the gearboxes where replaced they where ok. I wouldn't buy one, but she loved it. She had an 04 hardtop, then an 04 soft top, then an 06 soft top Quote Link to comment Share on other sites More sharing options...
mikuni Posted February 8, 2011 Share Posted February 8, 2011 Nope she's kiwi. Would that not make her a "mum" then? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 8, 2011 Share Posted February 8, 2011 lel you're a yankee aren't you heath? god knows. audi is bad though. 2 stroke dkws are sweet. but they're pre-union Quote Link to comment Share on other sites More sharing options...
