Spencer Posted July 10, 2013 Share Posted July 10, 2013 Go away VG. Quote Link to comment Share on other sites More sharing options...
keltik Posted July 10, 2013 Author Share Posted July 10, 2013 Getting blacktop ones because they are cheap and plentiful. As for plenums....I havnt decided yet if I should run one big one in the center and angle the throttle bodies or run 2 separate plenums. I really don't know anything about these things. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 10, 2013 Share Posted July 10, 2013 Depends how the manifolds work out! In my imagination I think of the ITbs or trumpets crossing over to get a decent intake length and one big plenum over the whole lot, the a central intake from above the radiator or something. Quote Link to comment Share on other sites More sharing options...
keltik Posted July 10, 2013 Author Share Posted July 10, 2013 Depends how the manifolds work out! In my imagination I think of the ITbs or trumpets crossing over to get a decent intake length and one big plenum over the whole lot, the a central intake from above the radiator or something. Don't forget ive got a 3ft gap between inlets. Would be some hoooooooge runners to cross them over. Will have to read up on how these things work. Quote Link to comment Share on other sites More sharing options...
JoKer Posted July 10, 2013 Share Posted July 10, 2013 removable dual-purpose plenum for tuning/Car shows/max dort Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted July 10, 2013 Share Posted July 10, 2013 Go away VG. Live a little Spenno. Quote Link to comment Share on other sites More sharing options...
ODB Posted July 10, 2013 Share Posted July 10, 2013 Quote Link to comment Share on other sites More sharing options...
keltik Posted July 10, 2013 Author Share Posted July 10, 2013 Pic so fellahs can visualise engine bay without going back through the thread; Quote Link to comment Share on other sites More sharing options...
keltik Posted July 10, 2013 Author Share Posted July 10, 2013 Im starting to wonder how much power there is to be gained versus one huge throttle on the current manifold. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 10, 2013 Share Posted July 10, 2013 I wrote a bunch of shit then lost it, the ITB's won't unleash mega power at all. Usually the benefits are had by tuning your intake runner length to better suit your mods (ie move it up the rev range slightly) the other gains are from a less restrictive intake/airbox system, hence if you leave your throttles flapping in the breeze with filter socks you have wasted most of the gains from the conversion. There is also throttle response to be had, but yea thats a added bonus. Making manifolds won't be fun with that kink in the front port! in an ideal scenario you would have them all packaged nicely and aimed to a central air box, that over the radiator intake is sweet, you would incorporate something like that going straight into the central plenum. Nice cold air, correct intake length, winning, making it happen is a bit harder than typing it out though. Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 10, 2013 Share Posted July 10, 2013 None, but heaps more throttle response. Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 10, 2013 Share Posted July 10, 2013 Also there is heaps of tech that goes int to an airbox, But basically Spence has got this. Quote Link to comment Share on other sites More sharing options...
keltik Posted July 10, 2013 Author Share Posted July 10, 2013 Well its not like im in a real hurry for the ITB's. Exhaust is the important one to finish before my cert. Only takes 10mins tops to take the intake manifold off on this thing so I can play around getting the new ones to fit without taking the car off the road. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 10, 2013 Share Posted July 10, 2013 Delete the AC, Power Steer and alternator and the ITB install will be a piece of cake? 3 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted July 11, 2013 Share Posted July 11, 2013 As I said, the only thing you really gain, is awesome sound! haha. Quote Link to comment Share on other sites More sharing options...
keltik Posted July 11, 2013 Author Share Posted July 11, 2013 Actually the front cylinders only kink to run around the ancillaries. If I just have all of them pointing straight up and run 2 smaller plenums, this will work and be pretty easy. Then I could pretty much mirror my current above rad intake scoop and have 1 for each bank. Would need to massage the AC lines but that's all easy. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 11, 2013 Share Posted July 11, 2013 Yea that will work, but will you have the height to run a decent intake length? see those factory intake runners, stand them up straight out of the port and I guess they would be out of the bonnet. You will be wanting to probably run a intake length from port to end of trumpet about the length of the factory setup, probably a couple inches shorter. Quote Link to comment Share on other sites More sharing options...
keltik Posted July 11, 2013 Author Share Posted July 11, 2013 Hmm yes theres really not a lot of height spare at the front Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 11, 2013 Share Posted July 11, 2013 6 holes in the bonnet and foam filters on the ITB's is the ONLY solution... 6 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted July 11, 2013 Share Posted July 11, 2013 THE GREAT ONE HAS SPOKEN! 1 Quote Link to comment Share on other sites More sharing options...
