ESKIN8R Posted July 24, 2010 Share Posted July 24, 2010 Right, so about to order a bit of kit from the UK Coilover kits are cheap, reckon thatd be overkill for a mk2 escort van to be used daily with a pinto? Looking at gaz shocks aswell, how do these compare to the likes of munroe etc?? And panhard rod? Worthwhile upgrade? Quote Link to comment Share on other sites More sharing options...
Simon Posted July 24, 2010 Share Posted July 24, 2010 I think definitely over the top for a daily. You will need to cert them. Why do you wan't to upgrade the panhard rod? Only necessary if you are slamming it heaps to get the diff back in the middle. Surly you can get decent lowering springs for it and some new shocks and it will handle 5x better as it is just with new harder shocks. Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted July 24, 2010 Author Share Posted July 24, 2010 Well I can get the gaz shocks for pretty much the same price as the ones in NZ, munroe etc Doesnt have a panhard rod or rear swaybar or anything, its going to need to be certed anyway due to engine coversion. Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 24, 2010 Share Posted July 24, 2010 Gaz shocks are good, Munroe are shit. If you can get some Gaz gear for the same price as Shitroe, go for it. Quote Link to comment Share on other sites More sharing options...
Simon Posted July 24, 2010 Share Posted July 24, 2010 Oh crazy. I'm not familiar with them. Do these things have leafs in the back? If your going coilovers you'll need a panhard rod. If you can get it all cheap then why not. Cert will cost the same. Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted July 25, 2010 Author Share Posted July 25, 2010 MacPherson struts in the front, rear leaf springs, the coil over kits convert the front stuts to coilover $40 for kit per side and they can do springs to suite for around $40 aswell. So yeah pretty basic, just wondering how much benefit panhard rods provide? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 25, 2010 Share Posted July 25, 2010 Stops the back end flying around. Leaf springs don't need them as the leaves locate the rear end. Coils need them otherwise the back axle will fly out side to side. Unless ya have some triangulated rear end setup or something, which will be harder to do. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 25, 2010 Share Posted July 25, 2010 Get tramp bars before panhard as tramp is more a problem with 2L conversions. only fit one tramp bar also as two can cause more problems than good. unless your wheels are close to the guard? then get panhard get gas adjustable lowerd ones if planning on lowering poss convert from angled to upright shocks if so needs to be decided before shocks ordered obviously Whats your budget? All that stuff on burtons is super cheap if you just look at price but postage costs even more than the items themselfs they only send air mail, stupidly expensive! 1K doesnt go far by the time you get it here i learnt Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted July 25, 2010 Author Share Posted July 25, 2010 Get tramp bars before panhard as tramp is more a problem with 2L conversions. only fit one tramp bar also as two can cause more problems than good. unless your wheels are close to the guard? then get panhardget gas adjustable lowerd ones if planning on lowering poss convert from angled to upright shocks if so needs to be decided before shocks ordered obviously Whats your budget? All that stuff on burtons is super cheap if you just look at price but postage costs even more than the items themselfs they only send air mail, stupidly expensive! 1K doesnt go far by the time you get it here i learnt Do you think the standard mk1 style gaz adjustables as supplied by burtons would handle a couple inches of lowering? Would probly use blocks anyway which wudnt affect the spring platform height anyway right? Dont wanna convert to upright. Budgets not overly high for the suspension, more going to engine. Already ordering heaps from Burtons anyway so dont think the postage price is guna change that much by chucking these few bits in. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 25, 2010 Share Posted July 25, 2010 Would probly use blocks anyway which wudnt affect the spring platform height anyway right? Yeah good point as shocks fix at leaves so for blocks should be fine, not sure if they can handle re set leaves from standard. I found going from standard to koni shocks was one of the biggest improvements i made on my escort out of any mod, GAZ adj shocks should be even better. 3.5 diff is also way good for road going pinto cruser Quote Link to comment Share on other sites More sharing options...
eskymsport Posted July 26, 2010 Share Posted July 26, 2010 If ordering from burtons, make sure you allow for customs to charge you gst and handling charges. Also if your order is over a $1000 nz you may be required to supply an importers licence no. if asked by customs Quote Link to comment Share on other sites More sharing options...
ESKIN8R Posted July 26, 2010 Author Share Posted July 26, 2010 How do you get an importers licence number? Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 26, 2010 Share Posted July 26, 2010 Also GST is going up to 15% very shortly so best make ya order soon Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 26, 2010 Share Posted July 26, 2010 ah thats right forgot on my order i had to pay 120 bloodybucks gst before they would give it to me also Quote Link to comment Share on other sites More sharing options...
zep Posted July 26, 2010 Share Posted July 26, 2010 Make sure you specify all the lengths when you order from Gaz, they manufacture each set of shocks to order so if you just say "for an escort" they might be too long for lowered cars, etc. This is what happened to me anyway and now I have to get mine shortened. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 26, 2010 Share Posted July 26, 2010 Get these they are of the hook with awsomeness! http://www.trademe.co.nz/a.aspx?id=306298198 Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 27, 2010 Share Posted July 27, 2010 Get these they are of the hook with awsomeness! http://www.trademe.co.nz/a.aspx?id=306298198 but they won't fit a van Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 27, 2010 Share Posted July 27, 2010 oops Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 27, 2010 Share Posted July 27, 2010 Vans and wagons have the same rear shock set up as the early mk1s with eye to eye shocks Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 27, 2010 Share Posted July 27, 2010 Already has vertical shocks then bonus! Quote Link to comment Share on other sites More sharing options...
