eskymsport
New Members
Everything posted by eskymsport
  1. why not contact motor sport nz
  2. why on earth would you need to line bore it, you are only changing bolts.
  3. If ordering from burtons, make sure you allow for customs to charge you gst and handling charges. Also if your order is over a $1000 nz you may be required to supply an importers licence no. if asked by customs
  4. are the sigma and ex lancer housings the same
  5. axle spline count is 22, diameter 24mm. housing length 1290mm flange to flange (no axles or brakes)
  6. you look to be right about the EX lancer mounts, have since found pics on the net and it looks right. since i need the diff head and the housing is pretty rusty, i might as well replace the whole lot. is there any difference between 8 and 10 bolt diffs. what do these diff come out in, is it only ex lancer and sigma
  7. I have just picked up a beach buggy that i need to rebuild. the motor and front end is escort, but the rear end has me confused. the diff head is missing so i am trying to identify housing as it has no markings. it is an 8 bolt mounting for the diff head (like escort but about 5mm smaller), it has 114 x 4 pcd axles (jap), it has an A arm bottom link and angled top link with coil springs. any ideas what it might be
  8. is the clutch plate facing the right way, there is a flywheel side and a clutch face side, i would say you have it the wrong way around and it is jammed in there.
