hunteds shuvit
mutiny
  • Replies 207
Yeah theres a rubber mount where the torque tube mounts to the body and every chevette I have ever driven makes a bit of a bang sound when you drop the clutch or go between the gears pretty fast. It can be fixed by replacing this mount. Unless you are talking about just a random knock when driving. Not sure what that would be but maybe just check movement of exhaust because it gets pretty tight through the tunnel there.
Is that the two rubber bushs that can be seen when looking from the diff foward, and are attached to the bottom side of the torque tube? And yeh, it only knocks when you are a bit quick on the clutch, and if you hammer it between the gears.
Yea chevettes are about this big l Gemini's are about this big l
Seriously though bowl round one day whilst at work , poke your head under my car and compare, chevette's are piddly.
Have a look at brads build thread and you'll see a stock one (his parts car from memory)
Oh yea If I remember to take them out of boot.. Could piss around one night at work, use tools/hoist there..
And yes its entirely possible that someone put a gemini diff into, almost a straight swap in..
Everything about the gemini diff is larger.
